#1002904 - 08/12/06 09:28 AM Rear end "clunk"
VinnyT Offline
Loc: SW Va
I'm getting a rear end "clunk" when accelerating hard from a dead stop. Now this is NOT the universal joints on the driveshaft. I know that sound. This is more like the rear spring(drivers side) is loading up and hitting a bump stop or something. I will be going underneath her this evening, but wanted to get some ideas of what it could be. Thanks, V.
2011 CVPI
#1002905 - 08/12/06 05:05 PM Re: Rear end
Ciffer Offline
Loc: Witchataw KS
rear control arms? just a guess
#1002906 - 08/12/06 05:27 PM Re: Rear end
cvpi71 Offline
Mr. Kozmo
don't forget about the rear spring insulatores. When I fist got my 97 PI it was making the clunking noise and gfor the life of me I could never figures it out. When I replaced the rear springs I noticed that the insulator was not seated properly and it was torn and deteriated and springs was rubbing against the metal. A new set of insulator and springs and it went away.
R.I.P Elfy 6/06
97 PI
#1002907 - 08/12/06 08:19 PM Re: Rear end
adam00cvpi Offline
My clunk was teeth of my spider gear getting picked back up in the gear lube.
2000 CVPI 115K Miles, ported upper intake, 70mm throttle body.
#1002908 - 08/15/06 01:34 AM Re: Rear end
Absolut_Justice Offline
Is your Emergency Brake fully operational?
If not, that maybe the problem. Just go with me on that...happened to my Chevy Camaro.
#1002909 - 08/15/06 11:53 AM Re: Rear end
CopNaStang Offline
If your 150% sure its not the U joints, I would guess the rear differential. I would check your springs/shocks, and if neither of these are the cause, I would second guess your U joints.
*2010 Black P7B/ 86K miles/ 3.55 gears
*1989 Mustang GT 5.0 convertible/ 84K original miles/ 1 female owner before my purchase/ no winters/ restored
#1002910 - 08/15/06 01:08 PM Re: Rear end
VinnyT Offline
Loc: SW Va
I know its not the U-joints. It will shift into Drive/Reverse with no clunking. It will already be in drive, with the rear end 'loaded up', I'll hit the gas and then hear the noise. It isn't really a clunk, but a thud.
2011 CVPI
#1002911 - 08/15/06 01:12 PM Re: Rear end
Buck268 Offline
Loc: Grand Rapids, MI
I'd get under there and look real hard at all 4 rear control arms as well as the transmission mount. Does it make the noise when you hit bumps and turn sharp? Possibly swaybar endlink mounting plates...
#1002912 - 08/19/06 04:45 AM Re: Rear end
Orv Offline
Something rolling around in the trunk?
(Don't laugh...I've had 'mysterious clunking noises' that sounded really worrisome that turned out to be some piece of loose cargo.)
1995 Ford Police Interceptor
