Page 1 of 4 1234>
#1059666 - 11/05/06 11:46 PM Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
Recall that the intention was to have the cowl scoop functional.
So ... Is it of any benefit
Got a new toy - digital infrared non-contact thermometer / temp-guage.
After an hour around-town cruise ( city driving ), some temperature readings ( fahrenheit ) .....
29.8 - outside air temperature.
36.4 - metal zip tube.
143.7 - bottom of heat shield for metal zip tube.
47.3 - throttle body adapter exterior. **
87.8 - intake manifold below throttle body adapter. **
150.2 - upper radiator hose exterior.
** With the engine cover on.
Set-up ...
Preliminary conclusion - Got a C(old) A(ir) I(ntake) system.
-click the Vic-
#1059667 - 11/05/06 11:54 PM Re: Goth Vic (2003 LX Sport) - CAI
dRock96Marquis Moderator Offline
Da Governator
Loc: Frederick County, MD
Too bad you don't have a ScanGauge, then you would know the exact intake air temp!
The cowl compliments the hood lines nicely, good choice!
Judging by the temp of it, that heat shield is very effective, nice work! Did you just use a piece of (18awg?) aluminum and bent it to a curve?
-My Homepage, Panther info & FAQs
My Mint '96 Grand Marquis Supercharged LSE ;\) -
Modifications
Click my car for more Pics!
#1059668 - 11/05/06 11:59 PM Re: Goth Vic (2003 LX Sport) - CAI
hal03GM Offline
Loc: Valdosta, GA
where'd you get the cowl hood from?
Can't spell Grand Marquis without Grandma 2003 Grand Marquis LS K&N FIPK 2 1/4" dual exhaust w/ magnaflows SCT Big Air MAF Excal-2 Steeda u/d 180* thermostat Steeda Underdrive pulleys
#1059669 - 11/06/06 12:04 AM Re: Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
dRock96Marquis - Too bad you don't have a ScanGauge, then you would know the exact intake air temp!
Yep ... However, no matter what the temperature of the incoming air is at the airbox, at least it's not getting significantly heated-up on its sojourn thru the intake system.
Thanks.
Shield Details <<<<< -click-
-click the Vic-
#1059670 - 11/06/06 12:16 AM Re: Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
hal03GM - where'd you get the cowl hood from?
Thread <<<<< -click-
-click the Vic-
#1059671 - 11/06/06 02:03 AM Re: Goth Vic (2003 LX Sport) - CAI
DodgeRider Offline
Formerly 2004CVPIDave
Loc: Kansas City
If you look up those kinds of filter/sheild combos on eBay you'll find that they have some that are conical filter completely surrounded by a shield. Air only enters through hole at end of shield... we could get the air hole on that pretty damn close to the stock location nowadays.... I can see a few guys on here coming up with some CAIs pretty soon.
Real men do it in 4 doors! -
1991 Suzuki Katana 750 (Cyan/Magenta) - 21K - 748cc, 13,000RPM
2006 F150 SuperCab 4x4 (Black) - 55K - 5.4L 3V, 3.73 LSD, Chrome Pkg
2005 Chebby Malibu (2.2L) - 65K - Lady's Car (Mods: RainX, Winter Washer Fluid, Anco Wipers)
#1059672 - 11/06/06 03:53 AM Re: Goth Vic (2003 LX Sport) - CAI
FunkRider Offline
Loc: Hamilton, Ontario, Canada
Those air filters with shields on them do not flow well. The filters are VERY VERY cheap. I wouldn't even put one in my trunk let alone on the end of my intake.
I'm talking about the ones that totally surround the air filter, not what joe has used on his car.
Gone: 2003 CVPI 5spd swap.
#1059673 - 11/06/06 09:16 AM Re: Goth Vic (2003 LX Sport) - CAI
Big_Bad_Joe Offline
Loc: Rochester NY
Joe:
I have used a lot of cowl hoods in my day. The way we used them was to have the air intake for the carb or the air inlet for the throttle body sealed to the scoop so the air was drawm from the outside ambient air temp.. that being the coldest you could get ... anything else being heated by the engine
the other type of hood cutout you see works on the principle of drawing hot air from under the hood....
yours opens to the windshield... tell me how air would get into the engine from there absent a draw? (i.e. and in take plenem actually sucking air?)
I think all your numbers simply reflect a very cold day outside (under freezing) and the thin material of the hoot... with heat loss into the air from that... just my $.02
You still will have heat soak on hot days... but you can measure that in the summer....
not flaming or arguing either.... and no comment on the "paper" thing... just aksing a few questions
Underdrives from ADTR.net
2000 HPP RESURECTION finished 6/6/10 now somewhere in Blacksburg.... borla exhaust ... if you hear it honk
#1059674 - 11/06/06 09:42 AM Re: Goth Vic (2003 LX Sport) - CAI
JCG1 Offline
Loc: Chicago
I'm forgetting whether you have a low or high pressure area right there at the cowl, and there's SOME theory behind it, which I'm also forgetting at the moment. Of course, it's bad as hell, so even if it's not functional . . .
It'll probably keep underhood temps down to some degree too.
I almost impulse purchased one of those laser thermo-thingys after one of our earlier flame wars about CAI's
(or the lack of a real one).
Datalogged air-charge temp runs in conjunction with all the measurements you listed would be cool
Former Ford Projects: 1967 Mustang w/transplant 351W : 1984 302 T-Bird : 1987 5.0 T-Bird : 1989 5.0 Mustang : 1992 5.0 T-Bird : Current: 2000 CVPI
Renegade Racing 4.6 SOHC: Cobra Crank, Manley Rods, Coated Diamond Pistons 10.5:1 comp w/valve reliefs, PnP npi heads, PI intake, Comp Cams, 70mm TB, MM Airbox/80mmMAF/04 Zip, 190lph walbro, FRPP shortys, custom 2.25 duals, Xcal2, Jmod RoadmasterTranz, Dirtyd0g TC.
14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive
Watch a 14.58 @ 94.13 Vid by DJChicago HERE
#1059675 - 11/06/06 09:45 PM Re: Goth Vic (2003 LX Sport) - CAI
kkeegan Offline
anyone have a functional hood scoop with a ram air setup?
Signature removed. See rules.
#1059676 - 11/06/06 10:03 PM Re: Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
Big_Bad_Joe / JCG1
Trust me the cowl scoop sucks
Wanted to know ( forsure ) myself, so right after I got the hood installed, paper streamers were taped to hang over the opening.
At idle and in park, the streamers gently fluttered out from the screen in the opening. Meaning: Under-hood pressure > atmosphere. It blows
While driving, the streamers are pegged and mashed against the screen ( and Yes, the amount of mash while not quantitatively analyzed, was greater in proportion to increased MPH ). It sucks. *Actually it means that there's a high pressure area at the windshield / cowl opening | the engine bay is a low pressure area | ?????
As a BTW ... When the engine is turned-off, even on warm days you can watch ( and feel ) the heat waves coming outa the scoop opening.
-click the Vic-
#1059677 - 11/06/06 10:09 PM Re: Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
While it's not a hood scoop ... ram air set-up .... Read This <<<<< -click-
Any ram air hood set-up would necessitate quite a bit of hacking and/or fabricating to be operational in a Panther. *Not to say it couldn't be done though.
-click the Vic-
#1059678 - 11/06/06 10:11 PM Re: Goth Vic (2003 LX Sport) - CAI
luv-my-2002-p71 Offline
Loc: STAP!
What do you use for wax etc? Jeesh
That is one of the best looking vics I have ever seen.
Is that window tint film on the headlamps??
I also love the Silicone hose upgrade! Nice, valvecovers too.
Damn. Joe what's your 1/4 mile time? Does the hood make any difference?
I wonder if the 5.4 whipple rig would fit!
Got an 03 Marauder with 45K - Very nice indeed -- 14.0250 @ 97.99 with all mods below
FRPP 3.73's - Trick Flow Girdle - Reinhart Trak-Lok with CF clutches - Alcoa MMC Driveshaft Amsoil 75W-110 Gear oil - PML Deep sand cast pan - Magnafine inline ATF Filter - TR6 Plugs - Motorcraft Severe Duty Pads & Rotors - GMS Ropes - EMP Stewart Pump - SG II - Fed Sig CHMSL - Command Auto Rear Rotors - KarKraft plenum spacer - Self installed: 9.5" PI 2800 Triple Disc & Newer Transmission - Tuned by Lonnie at BOC - Genuine FoMoCo Remote Starter with keyless entry - Accufab twin 60mm Tbody - Long Mini Max Trans Cooler - BC Automotive custom VB kit - Heinous billet rear control arms - 2.25 stainless mandrel mid pipes with polished muffled Magnaflow Tru-X
#1059679 - 11/06/06 10:19 PM Re: Goth Vic (2003 LX Sport) - CAI
Tony_the_Brit Offline
Big Bad Joe - if you want to draw air into the hood area - but not get lots of water, bugs, bees, errant birds, pedestrians, etc. coming in with it, then the best way is almost always to place an opening just in front of the windshield. On almost every car this is a high-pressure area - while on most cars the front 1/2 of the hood is a low-pressure area meaning that an opening there will pull air out of the engine compartment.
Just look at where your heater draws its air from.
The fact that the opening faces backwards does not affect this in the least - it simply keeps out the aforementioned undesirable items.
Oh - and someone needs to show this to Sal for Mad Max!
Edited by Tony_the_Brit (11/06/06 10:20 PM)
03 Crown Vic LX Sport maroon 1/4 ET = 14.237, MPH = 94.80...243rwhp 284rwtq(SAE) 158,000 m
03 P71 silver 213rwhp 251rwtq 160,000 m
04 P71 light blue 190,000m
04 P73 Dark Toreador 60,000m
#1059680 - 11/06/06 10:36 PM Re: Goth Vic (2003 LX Sport) - CAI
gDMJoe Offline
Loc: Timbuk3, MI
luv-my-2002-p71 - What do you use for wax etc? Jeesh
*A polish -not- a wax.
Thanks!
Yes ... Static cling ( easy to remove / install ). *Still need to do the headlight black-out.
Thanks! *Part of black and blue under-hood color scheme
It's been a while ( 2 years ) since I've TandT'ed ( Test and Tuned ) at the strip ... 15.1; that was before the 3.55 and TracLok install ( 3.27 and open ) and bunch of other mod's since ( i.e. larger throttle body and spacers ).
Will probably find out next year sometime AFTER possibly installing some re-worked exhaust manifolds ( extrude-hone + ceramic coat ) and then a dyno' tune session ( probably at Alternative Automotive ) to adjust ( and improve ) the existing dyno' tune.
It'd fit and give ya a cool charge as well.
-click the Vic-
Page 1 of 4 1234>
Moderator:  JohnG, dRock96Marquis, Liquid
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
8 registered (Land_Shark, whitela3, u538, GeeMarKee, Flippy328, WSTRLNG, 2 invisible) and 76 anonymous users online.
Amazon!
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
