#1081595 - 12/07/06 12:03 AM Air Bag code - What does it mean?
GhostRider Offline
Ok today I was driving along and the air bag light started to flash. It flashed 4 times, then 2 times and stopped. then repeated itself 4 more times in that order:
4...2
4...2
4...2
4...2
4...2
After the fifth time, I got a steady burn air bag light. What is the code? What is the problem and how is it solved? Thanks!
-Tim
#1081596 - 12/07/06 12:09 AM Re: Air Bag code - What does it mean?
Corsair Offline
Loc: Port Wentworth,Ga
might want to make sure thats not 24 instead of 42, as i dont find that listed..heres a paste of info sent to me before.
PRIORITY,CODE,COMPONENT/FAULT DESCRIPTION
Highest,No Indicator,Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
,Continuous Indicator,Diagnostic Monitor Disconnected or Inoperative
,12,Low Battery Voltage
,13,Air Bag or Crash Sensor Circuit Shorted to Ground
,21,Safing Sensor Not Mounted to Vehicle Properly
,22,Safing Sensor Output Circuit Shorted to Battery Voltage
,23,Safing Sensor Input Feed/Return Circuit Open
,24,Safing Sensor Output Feed/Return Circuit Open or Low Resistance in a Primary Crash Sensor
,32,Driver Side Air Bag Circuit High Resistance or Open
,33,Passenger Side Air Bag Circuit High Resistance or Open
,34,Driver Side Air Bag Circuit Low Resistance or Shorted
,35,Passenger Side Air Bag Circuit Low Resistance or Shorted
,41,Primary Crash Sensor Circuits High Resistance or Open
,44,RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
,45,Circuit Going to RH Radiator Ground Monitor Splice Open
,46,LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
,51,Diagnostic Monitor Internal Thermal Fuse Blown and Short to Ground No Longer Exists. Short to Ground was Serviced or is Intermittent
,52,Back-up Power Supply Voltage Boost Fault
,53,Internal Diagnostic Monitor Fault
Lowest,Rapid Continuous Flashing,All Primary Crash Sensors Disconnected
1996,2001, and daily drv., 1994 CVPI, 3.55 trac-lok,Go Rhino pushbumper,LED spotlight, J-Mod, plus a few bells & whistles.
#1081597 - 12/07/06 12:14 AM Re: Air Bag code - What does it mean?
GhostRider Offline
its 4 2...from this post , I guess it means
Code 42 - LH Radiator Primary Crash Sensor Feed/Return Circuit Open
Can anyone elaborate on this? How is this fixed?
-Tim
#1081598 - 12/07/06 01:21 AM Re: Air Bag code - What does it mean?
Da Governator
Didn't you install an air-horn recently, Tim?
I think you accidentally bumped the connector loose off the Air-Bag crash sensor behind the grille / on the header panel
RIP 2vmodular
#1081599 - 12/07/06 01:25 AM Re: Air Bag code - What does it mean?
99_03PantherS Offline
Loc: NW side Chicago
arrr she blows!
Jason G.
'81 Mark VI 2 door
'88 Towncar Cartier
#1081600 - 12/07/06 08:51 AM Re: Air Bag code - What does it mean?
GhostRider Offline
Derek, this has nothing to do with the air horn as I didnt get to that project due to snow. I will PM you in reference to this.
Last time and only time I had an issue with the air bag was in May 2003. On May 5, 2003, (91196 miles) the dealer discovered the air bag monitor defective due to light being on. On May 6, 2006 I ordered the Air Bag Monitor for $153.56 (Part Number F6AZ-14B215-AC). On May 14, 2006 (91983 miles) I had it installed.
-Tim
#1081601 - 12/07/06 11:10 AM Re: Air Bag code - What does it mean?
GhostRider Offline
Update: I checked fuses 10, 13, 18 in reference to the Air Bag Module. All ok and not blown. I disconnected the battery and the code is still there.
Derek, do you have a pic of the LH sensor? My Haynes manual is useless to this as usual.
Any suggestions?
-Tim
#1081602 - 12/07/06 11:50 AM Re: Air Bag code - What does it mean?
Da Governator
Lower right corner in the pic below:
RIP 2vmodular
#1081603 - 12/07/06 11:57 AM Re: Air Bag code - What does it mean?
Da Governator
I gotta run out to work for a bit, but when I get back I'll get your the FSM procedure for code 42.
RIP 2vmodular
#1081604 - 12/07/06 12:28 PM Re: Air Bag code - What does it mean?
GhostRider Offline
Thanks Derek for all your help! You rock!
For those that require a visual aide (like me), here are pics of the Crash sensors
LH (Drivers Side)
RH (Passenger Side)
Now, you will notice a red wire in the first 2 pics of the LH sensor that goes across the front (also visible in the RH pic). This is a dealer installed jumper wire of some sort from when they replaced the airbag monitor. An installer once cut this wire (thinking it was for old police equipment) and the airbag light instantly went on so they reconnected it.
So I checked the connections and all seem snug. I really am nervous working on airbag systems as I do not want it deployed on accident.
-Tim
#1081605 - 12/07/06 12:34 PM Re: Air Bag code - What does it mean?
Steve83 Offline
If Ford ever found out that a DEALER patched an SRS wire like that, they'd probably pull their franchise. If you're ever in a wreck & you have ANY injuries related to the airbags, you could win a HUUUUUGE judgement against that dealer, & possibly Ford too, for tacitly allowing them to do it.
AFAIK, no mfr. allows repairs of ANY kind to an SRS harness. I'd take the car back & invite them to replace that harness & fix your airbag light FREE, whether it's related to that wire or not.
#1081606 - 12/07/06 12:41 PM Re: Air Bag code - What does it mean?
GhostRider Offline
you must remember, the monitor was replaced in 2003. That was 3 years ago. Now I am having a problem. I dont know if its related so I cannot prove it.
-Tim
#1081607 - 12/07/06 02:13 PM Re: Air Bag code - What does it mean?
notchjonsn Offline
Loc: Ohio
Sorry guys don't mean to jump in on your post but I also get an air bag light flashing, but it is flashing a code 21. I noticed by one of the above threads that it pertains to a "safing" sensor not correctly mounted to vehicle. what is this and where can i find its location. 96 cv 192400
1996 cv with 173k (SOLD-3/29/2007)199011
2003 Taurus 20k Vulcan
2009 Fusion SAP Tuxedo Black
2008 Escape (lease)
2001 Crown Vic(P71) just purchsed 99k 6/16/09 3.27 (X5)
ex Oakwood Village, Ohio unit
#1081608 - 12/07/06 08:42 PM Re: Air Bag code - What does it mean?
Corsair Offline
normally behind drivers side kickpanel. if the safing sensor detects the crash sensor activate, then allows current to go to airbag to deploy. cant remember the exacts, but thats basically it in a nutshell. perhaps it fell off and isnt grounding now?
#1081609 - 12/07/06 09:10 PM Re: Air Bag code - What does it mean?
Steve83 Offline
It doesn't matter how long ago they patched the SRS system - they're gonna have to fix it. And let THEM tell YOU it wasn't related AFTER they've fixed whatever the problem is at THEIR expense. It's their penalty for letting you drive around with that BS red wire for 3 years. They're lucky it's not your WIDOW or your lawyer talking to them. But don't hesitate to remind them of that if they give you ANY flak about it.
NM117 335
Moby_Vic 147
BigMerc96 121
Ezbok58a 116
Chaplian 116
RF_Overlord 115
EZlivin11 115
a_d_a_m 96
mdnos 96
Ponyguy 93
