#1086920 - 12/15/06 04:07 AM 2006 P71 Interior Courtesy Light Disable
PAGJA Offline
Can anyone help with the reactivation of a late model P71 that currently has it's interior courtesy lights disabled? I did a file search and came up with some info but was for older P71's. Does this require a dealer to do a P.C.M. reflash or is there a way to reactivate ourself? Thanks.
#1086921 - 12/15/06 10:37 AM Re: 2006 P71 Interior Courtesy Light Disable
GhostRider Offline
I am sure you need the PCM re-programmed. I guess Ford got wise to the blue wire under the dash.
-Tim
#1086922 - 12/15/06 05:37 PM Re: 2006 P71 Interior Courtesy Light Disable
VinceNDetroit Offline
Loc: detroit area
does not appear so, just looked at the diagrams at a dealership, the wiring is different from civilan vics. the p71 shows no sign of any interior lighting, switches etc.
96,01,02 p71s
#1086923 - 12/15/06 05:54 PM Re: 2006 P71 Interior Courtesy Light Disable
ritcheyd Offline
Loc: West "By God" Virginia
We have been discussing 2006 dark mode on another CV site. Go here:
http://www.crownvic.us/forum/showthread.php?t=25661
2006 Police Interceptor Modifier Guide, 9/2005
Wiring 2-23
Section 2: Wiring
Courtesy Lamp Disable (Dark Mode)
This option offers deletion of the illuminated entry function. Upon vehicle power-up, the lighting
control module (LCM) will not provide interior lighting during entry or exit of the vehicle. The
interior lighting will, however, still operate on demand whenever the dome lamp switch is active. If
the dark car feature is necessary, the assembly plant enables this feature through the LCM. The
vehicle can be reconfigured by entering diagnostics, enabling/disabling the courtesy lamps, and
then exiting diagnostics.
Use the following steps to disable the courtesy lamps:
1. Connect the NGS diagnostic tool with vehicle communication module (VCM) to the data link
connector (DLC).
2. Select vehicle - 2006 Crown Victoria 4.6L.
3. Select Diagnostic Data Link.
4. Select Lighting Control Module (LCM).
5. Select Module Configuration.
6. Select Customer Preference Item.
7. Select Dark Car.
8. Select Enable or Disable.
9. Select Done.
I love the blue connector, but I guess it was too good to be true forever.
2013 F150 XLT
2010 Grand Marquis
1971 Kaiser Jeep 2 1/2 ton
#1086924 - 12/15/06 06:07 PM Re: 2006 P71 Interior Courtesy Light Disable
Park Ranger Offline
Loc: Michigan
What years of CVPI's does the
" blue connector" cover?
In God I Trust......everyone else keep your hands where I can see them.
#1086925 - 12/15/06 09:23 PM Re: 2006 P71 Interior Courtesy Light Disable
ritcheyd Offline
Blue connector: 1995 to 2005.
http://www.p71interceptor.com/lcm/darkcar.html
From 2vmodular's excellent site.
2013 F150 XLT
2010 Grand Marquis
#1086926 - 12/16/06 08:34 AM Re: 2006 P71 Interior Courtesy Light Disable
Clayton Offline
Loc: South Carolina
Let me ask this question. Does your door chime if you leave the keys in the door? If it does, then you have the dark mode enabled "properly". If it does not ding, then it may have been engaged "right".
If its dark mode, then you have to go back to a dealer for the PCM update.
If not, check behind the door panel. There is a single black wire that goes to the top of the door latch mechanism. If this wire is disconnected or cut, it will make the car think the door is always closed. No dome lights come on and the car doesnt chime. Reconnect this wire would restore all benefits.
Clayton
Active duty 2007 CVPI
Moderator:  Chaplian, jmlock, Liquid, Ryan, The_Punisher
6 registered (Tenevic_P71, H3LlIoN, albertaglen, 3 invisible), 87 Guests and 88 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
