#1174223 - 04/21/07 10:18 PM Aiming Headlights
Bob_G Offline
Does anyone here know how to aim the headlights? We just bought a 94 Crown Vic XL with 26,000 miles on the clock. Every thing is great except the headlights. The right side is low. I removed the panel above the headlight and did not see any adjustment screw.
Thanks for any help, Bob
#1174291 - 04/22/07 12:34 AM Re: Aiming Headlights [Re: Bob_G]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
I think its called as LX? Unless its an f series truck with a CV body on it.
2002 CV P73
#1174527 - 04/22/07 01:41 PM Re: Aiming Headlights [Re: coldfusion11]
Bob_G Offline
Thanks for the corection. Now, can you help with my question? If not, I guess I can to the wrong site.
Bob
#1174530 - 04/22/07 01:53 PM Re: Aiming Headlights [Re: Bob_G]
98VicP71 Offline
13.97@99MPH
Loc: ATL
I am interested in how to aim them as well.
#1174557 - 04/22/07 03:00 PM Re: Aiming Headlights [Re: 98VicP71]
ktwohig9 Offline
Loc: Quincy, MA
Take a look at the pics in the following link
Link
The black bars that he shows removal of...there are screws going into that bar from the headlights. Those screws have black plastic strange shaped heads. by loosening or tightening those is how you adjust your headlights.
Edited by ktwohig9 (04/22/07 03:02 PM)
2007 CVPI Wedgewood Blue Metallic - 114K miles
#1174565 - 04/22/07 03:25 PM Re: Aiming Headlights [Re: 98VicP71]
Da Governator
98+
http://www.redpulsar.us/~coldfusion/adjustment2.html
RIP 2vmodular
#1174566 - 04/22/07 03:27 PM Re: Aiming Headlights [Re: dRock96Marquis]
Da Governator
Bob_G:
to the forums!
Sorry you got a smart-ass first reply
here is an exceprt from the Ford Service Manual on 92-97 lamp adjustment:
Headlamp Aim
Perform headlamp aim adjustments with Rotunda Headlight Aiming Kit 107-00003 and Headlight Aiming Adapter 107-00011 or equivalent. To aim the aerodynamically styled headlamps, the adjustable aimer adapters provided in the kit must be used. Adjustment aimer adapter positions are moulded into the bottom edge of the headlamp lens. Headlamps can be adjusted from inside the engine compartment by rotating the adjusting screw by hand using a hex-head socket.
Set and lock the adjustable adapters, attach each adapter to its mechanical aimer, and aim headlamps per latest instructions in the kit. All headlamp adjustments should be made with a half-full fuel tank, plus or minus 3.785 liter (one gallon), the vehicle unloaded, the luggage compartment empty (except for the spare tire and jacking equipment) and recommended pressure in all the tires.
The equipment in Rotunda Headlamp Aiming Kit 107-00003 or equivalent can be calibrated to accommodate a slight slope in the floor, making it usable almost any place in the garage. However, area must be reasonably flat.
In my honest opinion, most small garages only charge like $15-$20 to aim your headlamps. I'd just get it done somewhere
You can play with it some by removing the access panel and then feel around for the mounts, then turn to adjust.
RIP 2vmodular
#1174613 - 04/22/07 04:55 PM Re: Aiming Headlights [Re: dRock96Marquis]
RedPanther Offline
Loc: S.E. Michigan
Around here they do it for free, but if you go to a dealership, they charge $50
-2000 Grand Marquis HPP w/ Flowmaster 50s, 17"Mustang Rims, and Pioneer receiver (Wrecked)
-1996 Lincoln Mark VIII Base, 90k miles. 2.5" dual exhaust with XXpipe, 17"American Racing wheels
#1174800 - 04/22/07 10:17 PM Re: Aiming Headlights [Re: dRock96Marquis]
Bob_G Offline
 Originally Posted By: dRock96Marquis
Bob_G:
to the forums!
Headlamp Aim
Thanks for the welcome. As for the SA answer, there is always one in the crowd.
Bob
#1174815 - 04/22/07 10:36 PM Re: Aiming Headlights [Re: Bob_G]
Central50 Offline
Loc: Long Island, NY
Bob_G:
to the forums!
Headlamp Aim
Bob
Don't mind him, he is a SA n00b. They are a different crowd.
#1175027 - 04/23/07 10:22 AM Re: Aiming Headlights [Re: Central50]
98VicP71 Offline
13.97@99MPH
Loc: ATL
Thanks for the info guys.
Moderator:  BigMerc96, Quasar
7 registered (2007CrownVic, 07LandYacht, Bellwestern80, iarias_, oldgreejunker, 1 invisible), 94 Guests and 95 Spiders online.
a_d_a_m 229
BigMerc96 144
Ezbok58a 104
dpk 100
EZlivin11 97
RF_Overlord 96
Chaplian 92
Ponyguy 88
JeffBoudah 87
SocalSam 80
