#1189712 - 05/14/07 05:29 PM Front end squeak -- stumpped
vicvega Offline
Loc: New York, New York
There is a front end squeak that progresses as the car rolls faster, like squeak squeak squeak squeak squeak squeak squeak squeak squeaksqueaksqueaksqueaksqueaksqueaksqueak. You get the picture. I took off all tires. All pads and rotors are new i checked to make sure nothing was rubbing on the rotors. The weiredest part is that this noise comes and goes. It will do it for a while then it completely goes away. Then it returns unexpectedly. My dad thinks its a bearing or a U-joint. I don't know so that's why i'm here asking for help. Thanks in advanced.
Vic Vega 2003 CVPI 150000 Miles
#1189717 - 05/14/07 05:44 PM Re: Front end squeak -- stumpped [Re: vicvega]
RedPanther Offline
Loc: S.E. Michigan
hmmm.... I have the exact same problem. My brake pads and rotors are pretty new (brake pads are non-oem metallic though). I had the bearings checked and they are fine, apparently the bearings emit a groan rather than a squeak when they go bad.
-2000 Grand Marquis HPP w/ Flowmaster 50s, 17"Mustang Rims, and Pioneer receiver (Wrecked)
-1996 Lincoln Mark VIII Base, 90k miles. 2.5" dual exhaust with XXpipe, 17"American Racing wheels
#1189751 - 05/14/07 06:35 PM Re: Front end squeak -- stumpped [Re: RedPanther]
MDD Offline
Loc: Pickerington, OH
Bad bearings tend to "roar" or moan (not squeak). I doubt it's a bad bearing.
Is it a function of engine speed or forward motion of the car?
1997 Mercury Grand Marquis GS w/ handling package (rear air suspension, 3.27 non-locker rear). 110K miles and going strong.
#1189761 - 05/14/07 06:42 PM Re: Front end squeak -- stumpped [Re: MDD]
Mileaway Offline
Loc: Sacto. Calif.
Youv'e got the new and improved [03] squeak. Swaybar end links maybe/hood latch might actually be it on this one? Try a little shot of wd 40 and see if it goes away.Try one at a time tolocate it.Don't sray too much cause it's not rubber/plastic friendly.
#1190268 - 05/15/07 10:01 AM Re: Front end squeak -- stumpped [Re: MDD]
vicvega Offline
It is a function of forward motion of the car! IT starts around 20mph and as the car goes faster the squeak becomes more of a scrape and more continous. I removed all the wheels, looked at all the bushings, pulled on all the tie rods, sway bar and nothing is loose. I thought it might be somthing rubbing on the rotors but they are clear of anything. I thought it may be the pads but the noise is the same when I step on the brake or let go if it as well. Like I said, I'm stumpped
#1190306 - 05/15/07 11:58 AM Re: Front end squeak -- stumpped [Re: vicvega]
Metallic_Vic Offline
Loc: Atlantic Canada
I've had a bad U-Joint squeak before, while driving try coasting in neutral to take the load off the driveshaft and see if the squeak goes away or changes.
Mine is a 99P74 (4 door of coarse)
#1190317 - 05/15/07 12:19 PM Re: Front end squeak -- stumpped [Re: Metallic_Vic]
vicvega Offline
I will def try that! That's a great idea! Thanks and I hope this works. My dad thinks it's a u-joint. Well see!
#1190330 - 05/15/07 12:48 PM Re: Front end squeak -- stumpped [Re: vicvega]
mblazakep Offline
Insert Title Here
you could also try spraying some WD-40 on the u-joint and see if the squeaking stops, while this will not fix it, it will at least let you know where your problem is.
#1190395 - 05/15/07 02:39 PM Re: Front end squeak -- stumpped [Re: mblazakep]
Dan The Vic Man Offline
Loc: Coon Rapids MN
U joint, maybe a bad tire also.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1190433 - 05/15/07 03:44 PM Re: Front end squeak -- stumpped [Re: Dan The Vic Man]
vicvega Offline
Yeah I thought of this but the tires only have 1000 miles on them. I checked the rims for cracks as well. Will try the WD40 on the U-Joints as soon as I get out of work. If it is, that's not hard to fix!
Thanks again for all your comments and post, I will let you know what I find.
vic
#1190457 - 05/15/07 04:45 PM Re: Front end squeak -- stumpped [Re: vicvega]
Loc: Coon Rapids MN
New tires doesnt mean they arent bad. My dad had a bad tire once and it was brand new and tires plus couldnt figure out what was a matter with it, they did an allignemnt on it twice abd it turned out to be a bad tire that was brand new.
RIP 99 CVPI
#1190464 - 05/15/07 04:52 PM Re: Front end squeak -- stumpped [Re: Dan The Vic Man]
03CrownVicP71 Offline
Loc: Langley
"Some 2003-2004 Crown Victoria, Grand Marquis and Town Car vehicles may exhibit a squeaking or rubbing noise from the front suspension. The noise may be coming from the upper spring insulators. The insulators can be easily inspected from above, without removing the spring/shock assembly from the vehicle. If necessary, replace with revised spring insulator. Refer to Section 204-01 of the Workshop Manual. If no wear is found follow normal diagnostics."
From Ford TSB 04-15-5, may or may not be heplful...
If needed, revised insluator part # is 5W1Z-5415-AA
2003 Vic PI
SCT LIVEWIRE
4R75E Tranny with converter by Edge Racing Converters
Numerous other Mods
#1190618 - 05/15/07 08:27 PM Re: Front end squeak -- stumpped [Re: 03CrownVicP71]
vicvega Offline
UPDATE. I inspected the U joints and WD40'ed them. lol. Ran the car in Neutral and the squeak persisted. Well I went under the car once again and inspected it thoroughly. I found that there is tranny fluid moister I guess from the front seal anyways. I decided to put the car on jack stands on th side of the squeak the right side. Started with the rear. Placed the car on drive, accelerated slightly and behold, the mysterious squeak. Me thinks the rotors have to be resurfaced. The squeak only came from the rear right tire and only while driving forward not reverse. Any comments?
#1190626 - 05/15/07 08:33 PM Re: Front end squeak -- stumpped [Re: vicvega]
Mileaway Offline
Loc: Sacto. Calif.
You ran over a "Hood Rat". Anyone seen Ice T. around lately? LOL
#1190631 - 05/15/07 08:37 PM Re: Front end squeak -- stumpped [Re: 03CrownVicP71]
98Gdmarq Offline
Loc: Clifton, NJ
Hmmm, my sister's '98 MGM makes similiar noises, new rotors/bearings last July. I will have to look into it, and of course lubricate the bushings.
Pantherless-Gave the '98 to my sister, it is still running strong at 199,xxx mi.
Past:
1998 Spruce Green/Gray Cloth MGM LS
1993 Deep Jewel Green/Mocha Leather MGM LS
Moby_Vic 182
a_d_a_m 152
BigMerc96 136
EZlivin11 105
Chaplian 103
White99MGM 98
charlieD 95
RF_Overlord 86
DudeAbides 80
SocalSam 75
