#1213063 - 06/17/07 10:18 PM Knocking and Squeaking noise from front end
interceptor859 Offline
Loc: Mt. Sterling, KY
When I am driving at a fairly low rate of speed and I hit a speed bump, or going through a parking lot and hit a little divet there is a sort of knocking noise from the front end. Also, when I am on the highway driving, the front end squeaks all the time. On its worst days, when I shut the door, you can hear a little squeak. I was just messing around, and I stood at the front driver side fender and began rocking the car and I heard that same squeaking noise. I think it might be the shicks, but I am not near as experienced with these things as you guys are. What do you guys think?
2011 Black Crown Victoria LX. 46k miles. 20% tint, stock otherwise. I LOVE IT!!
2008 Black SAP CVPI. Former Iowa City Police Vehicle. 75k miles. 20% tint all around. Flowmaster 40 Series with rear cat delete. SOLD.
2006 CVPI. Former Ohio Highway Patrol. 150k miles. 20% tint all around. Completely stock except center console. SOLD.
2003 CVPI. Full leather interior swap from MGM. Flowmaster 40 series, rear cat delete. 155k miles. Gone. Totaled Oct. 2011
#1213068 - 06/17/07 10:26 PM Re: Knocking and Squeaking noise from front end [Re: interceptor859]
Metallic_Vic Offline
Loc: Atlantic Canada
Check sway bar end link ball joint for wear or looseness and check upper/lower ball joints on the control arms.
Shouldn't be any play on these parts
As for the squeek the hood latch may be give you a squeek.
Mine is a 99P74 (4 door of coarse)
#1213087 - 06/17/07 10:44 PM Re: Knocking and Squeaking noise from front end [Re: Metallic_Vic]
I just went outside and was messing with the hood latch, and I did not hear any squeak in it when i engaged it, but I put some WD-40 on it anyways. After that, I stood at the front fender and rocked the car back and forth, and I could still hear that knocking noise. It sounds like it is coming from somewhere in the middle of the front end. I cannot hear any noise in the shocks, so I don't think that is the problem. Doesn't Midas take your car for a ride and they can figure what is wrong with it and give you a free estimate? Any ideas on what i should do. I am not experienced enough to get under there and try to do it myself, cause I really don't know what I am doing.
#1213153 - 06/17/07 11:48 PM Re: Knocking and Squeaking noise from front end [Re: interceptor859]
Dan The Vic Man Offline
Loc: Coon Rapids MN
Tie rod maybe.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1213157 - 06/17/07 11:59 PM Re: Knocking and Squeaking noise from front end [Re: Dan The Vic Man]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
the squeeking is the hood rubbing on the fenders up by the hood shocks, take a close look and you'll see where the paint is rubbed of and it's a metal on metal squeek. The other prob could be alot of things, you should get it on a lift and check the front end out.
#1213158 - 06/18/07 12:00 AM Re: Knocking and Squeaking noise from front end [Re: Dan The Vic Man]
95merckid Offline
Loc: wichita
i had the same problem i just sprayed the busching on my upper control arms with WD-40 that takes care of most of it the rest is your ball joints squieking
#1213182 - 06/18/07 12:21 AM Re: Knocking and Squeaking noise from front end [Re: 95merckid]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Check the sway bar bushings for play.
#1213334 - 06/18/07 08:51 AM Re: Knocking and Squeaking noise from front end [Re: gord_bolton]
LTDteether Offline
The trouble with some Midas and like places is that they will free estimate you into replacing EVERYTHING. If you don't know about cars, you have to find a mechanic that you trust. Ask friends and associates who they like. Others here may give you more advice about looking for play in the suspension and steering. I don't really feel I should try to do it off the top of my head. A general auto repair manual will also be of great use. If you have a place to work on it, get some ramps and start looking around under the front end. No one can really tell you what is wrong without looking at it and touching it.
'99 GM GS HPP.
#1213500 - 06/18/07 03:09 PM Re: Knocking and Squeaking noise from front end [Re: LTDteether]
VA P71 Offline
Smartass
Loc: CONUS
I've got an annoying squeak in the front end and found out it is the upper control arm bushings....they're starting to shred a little. Open the hood and check the gap in the splash covers where the shocks are, that's where your upper control arm is and rock the vehicle.
2001 CVPI & 2004 Expedition
#1213851 - 06/18/07 11:30 PM Re: Knocking and Squeaking noise from front end [Re: VA P71]
does the ford dealership check out the front end and tell you what is wrong for free? i know that they charge one hour of labor to diagnose an engine problem but what about checking out the front end? anyone know?
#1214324 - 06/19/07 05:54 PM Re: Knocking and Squeaking noise from front end [Re: interceptor859]
it ended up being the sway bar end link on the drivers side making the noise. im gonna go ahead and replace both sides though.
#1214337 - 06/19/07 06:14 PM Re: Knocking and Squeaking noise from front end [Re: interceptor859]
Mileaway Offline
Loc: Sacto. Calif.
Dealers are alot like Doctors-You've got 5 min.Pay at the desk.
#1214386 - 06/19/07 07:07 PM Re: Knocking and Squeaking noise from front end [Re: Mileaway]
jaybird Offline
Loc: San Jose Ca.
how much was it to have them repalced? or how much were the parts?
Its funny I just in the last day noticed, I have the exact same squeaking when I turn the wheel just a little and any bump I hit..It sounds like the heat sheild is hitting something to as I hit bumps? Is that a motor mount? So what do you experts think..I am so thankful for this CVN! I can also see a tie rod? way down benenth the battery and in front on the passenger side looks like a linkage there is a rubber bushing /washer thats hanging by a few threads...ouch..Is that a tie rod? I will need a rebulid to my front end? what does that usually cost? THANKS JAY
2000 CV LX HPP Loaded 3.55 RAR
189K Miles! / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
NM117 335
Moby_Vic 147
BigMerc96 121
Ezbok58a 116
Chaplian 116
RF_Overlord 115
EZlivin11 115
a_d_a_m 96
mdnos 96
Ponyguy 93
