#121654 - 04/24/03 05:58 AM INTERIOR--Speedometer Cable Wiring Diagram??
CajunCrnVic Offline
Loc: Southern Louisiana, USA
I know this might have been discussed here before, but I need a precise answer to this question, so I will ask it now. I have a 2000 CV HPP, with the basic guage cluster (no digital). Is the odometer mechanical or electrical (as in how it gets turns, motor, or cable) If it is electrical, which wire on the cable loom controls it? If the signal were stopped on this wire, would it throw a code in the computer?
Thanks,
Dustin
Edited by Liquid (04/27/04 10:52 AM)
**Personal Car**
2000 Crown Vic P73 HPP
Keyless entry
Keypad on door (hate it)
Lighted footwells
**Patrol Car**
2010 Crown Vic P71
Deputy Sheriff in SW Louisiana
Master Mason
#121655 - 04/24/03 02:49 PM Re: Speedometer Cable Wiring Diagram??
PatFromJersey Offline
Sir Laugh Alot
Loc: Glen Burnie, MD
It's definately electrical, and it gets a signal from the VSS (Vehicle Speed Sensor) mounted in the transmission. On my 99, the signal from the VSS is on pin 16 of the connector on the back of the instrument panel. I'll capture and post the diagram for you when I get home tonight. Not sure about your year. I don't know if the PCM uses the VSS for anything other than the speedo, so maybe you'll have more things go wrong, other than a MIL light. Maybe one of the guru's will step in for that. You may get away with disconnecting the VSS, if it doesn't affect anything other than the speedo. Good Luck.
1932 Ford 5 Window Coupe Project 521/C6
2008 Ford Crown Victoria LX
#121656 - 04/24/03 03:54 PM Re: Speedometer Cable Wiring Diagram??
Mr_pogo Offline
On OBD1 Fords, the VSS signal is used by the trans along with the output shaft signal (OSS) sensor, also on the trans. There is also a VSS fault code. Not sure about OBD2s as info is at work but I would say its probably same.
Symptoms of losing VSS signal is shift busyness on hills.
#121657 - 04/25/03 12:44 AM Re: Speedometer Cable Wiring Diagram??
Sir Laugh Alot
Here's the analog instrument cluster wiring for the 99. The 2000 hopefully, should be the same.
#121658 - 04/25/03 11:31 PM Re: Speedometer Cable Wiring Diagram??
CajunCrnVic Offline
Thanks for the diagram. I will see if it helps my "project" when I get home.
Thanks again,
Dustin
**Personal Car**
Keyless entry
Lighted footwells
**Patrol Car**
2010 Crown Vic P71
Master Mason
#121659 - 04/27/03 12:39 AM Re: Speedometer Cable Wiring Diagram??
2vmodular Offline
Loc: New England
Be warned that disconnecting the odometer with the intent to defraud is a felony in most states and will land you in prison.
In reply to:
http://www.p71interceptor.com
#121660 - 04/27/03 08:02 PM Re: Speedometer Cable Wiring Diagram??
DuendeP71 Offline
Loc: Minnesota
Key term - 'INTENT TO FRAUD'. If he's just changing it to digital, or to a new one, so long as he has a record of it, and shows on the title that true mileage is reflected (or keeps it as the original and can show it) then he should be MORE than fine.
That only applies if you are dropping a new one in to sell the car for more money, in other words, intending to commit fraud. It does not apply to your own cosmetic preferences.
'99 Crown P71
3.55 Traction Lok
Lincoln Leather seats
TODO: Wire seats from the '01 Town car :-)
Moderator:  a_d_a_m, KayTar, Liquid
5 registered (mrti, Gee_Oh_Dee, MIAMI-DADE, Sakoulas, 1 invisible), 45 Guests and 116 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
