#1222984 - 06/30/07 01:03 PM Huh?? I have air shocks?
DMF Offline
Loc: Atlanta
Just acquired a pair of AA527 replacements for my '99 P71 that started bouncing like a pogo stick. I just got under it, and discovered that the old rear shocks have both lost their retainers and insulators.
Furthermore, each shock has an air fitting on the side of the dust tube. They are fat, white, and have a big number stamped on the side - 729767 - with no manufacturer. The little black nylon tubes connected to them were obviously routed by someone other than the factory, and seem to connect only between the shocks.
What are they?
Would it make sense to re-connect the existing shocks (I think they were okay before they disconnected) and return the new ones?
99 P71
85 Mustang GT
#1223031 - 06/30/07 03:34 PM Re: Huh?? I have air shocks? [Re: DMF]
Blue95 Offline
Loc: Past the Horizon
Sound like someone installed air shocks on the back. IMO I would toss em and install the new replacement shocks. Air shocks are a poor way to carry loads on a vehicle, better to change out the rear springs and use "normal" shocks.
I got a little confused - you first said that the car was bouncing around, then you said that the rear shocks were probably OK? Anyway. my vote is for shock replacement.
1995 P71-SOLD
2002 HPP-SOLD
#1223032 - 06/30/07 03:36 PM Re: Huh?? I have air shocks? [Re: Blue95]
tackleberry Offline
Loc: Las Vegas
i like my air, but when they go im gonna put CVPI springs in its place.
#1223055 - 06/30/07 04:19 PM Re: Huh?? I have air shocks? [Re: Blue95]
DMF Offline
Loc: Atlanta
Yeah, they were fine when they were connected to the car a both ends.
In hindsight, the one must have come loose a few months ago; the other a couple weeks ago. Surprising to me that only one shock did pretty well on its own. I thought one was blown - i.e. weak - but had no idea it was physically detached.
I still can't find anywhere the lines for these "air shocks" were attached other than to the shocks. Where would the air source be, under the hood?
99 P71
85 Mustang GT
#1223063 - 06/30/07 04:26 PM Re: Huh?? I have air shocks? [Re: DMF]
tackleberry Offline
Loc: Las Vegas
dont that come from the trunk on the drivers side, and relays are in the front?
#1223080 - 06/30/07 05:20 PM Re: Huh?? I have air shocks? [Re: tackleberry]
JayP71 Offline
Loc: Pa
If they are aftermarket air shocks who knows where they installed the line. Back in the day that air shocks were cool I....I mean guys would run the fill hose to the someplace near the lic plate. The air lines just T to a air fitting and you add air like a tire...
#1223139 - 06/30/07 07:28 PM Re: Huh?? I have air shocks? [Re: JayP71]
Blue95 Offline
Exactly what JayP71 said. I remember those days .... and guilty of doing exactly that on my 62 Chevy!
Tackleberry I think that you are describing the RAS setup - from what I read, he has standard issue airshocks on the back, but they are not connected to anything.
1995 P71-SOLD
2002 HPP-SOLD
#1223154 - 06/30/07 08:00 PM Re: Huh?? I have air shocks? [Re: DMF]
baravelli Offline
I'm thinking the older Gabriel Air Shocks. You don't have an air compressor so toss 'em.
#1223553 - 07/01/07 01:46 PM Re: Huh?? I have air shocks? [Re: baravelli]
Tony_the_Brit Offline
Tackleberry - he is talking about air SHOCKS not air springs! He has metal springs.
DMF - if you are satisfied that you can reattach the shocks OK then try it and see how it goes. If all seems OK then return the new shocks.
03 Crown Vic LX Sport maroon 1/4 ET = 14.237, MPH = 94.80...243rwhp 284rwtq(SAE) 177,000 m
03 P71 silver 213rwhp 251rwtq 200,000 m
04 P71 Spruce Green 101,000m (SOLD)
04 P73 Dark Toreador 115,000m
07 P71 Arizona Beige 190,000m
11 Crown Vic LX Blue 101,000 m
#1223935 - 07/02/07 01:23 AM Re: Huh?? I have air shocks? [Re: Tony_the_Brit]
DMF Offline
Loc: Atlanta
Found the filler. Schrader valve on the frame bar behind the rear bumper. I wouldn't have enough insulators et al. after returning the new shocks, so I just pulled the whole system off and put the new ones on.
What a PITA! even without having to remove the old shocks. Lord knows what I would have had to do had there been frozen nuts on them. As it is I had to cut through the floor on one side because I couldn't get at the top nut to tighten it.
I've long admired Fords for the ease of maintenance, but this is ridiculous. What do Ford techs do when they have to change the rear shocks?
99 P71
85 Mustang GT
#1224107 - 07/02/07 10:04 AM Re: Huh?? I have air shocks? [Re: DMF]
Blue95 Offline
I used a hole saw and "installed" access holes right above the shocks on my 95 - life was good after that. Also used rubber plugs in the holes. I have always wondered why in the heck Ford did not do that.
1995 P71-SOLD
2002 HPP-SOLD
#1224382 - 07/02/07 05:27 PM Re: Huh?? I have air shocks? [Re: Blue95]
JayP71 Offline
Loc: Pa
When I was in a Jeep club we used to do lifts for people that didn't really know much about them or how to install them. the rear shocks on cherokee's were a PITA...until we started drilling access holes..
5 registered (McVic, Y_K, cvpi_mark, 07LandYacht, Ezbok58a), 40 Guests and 76 Spiders online.
a_d_a_m 213
BigMerc96 148
EZlivin11 105
Chaplian 102
RF_Overlord 99
Moby_Vic 95
dpk 93
charlieD 90
Ponyguy 84
