#1273859 - 09/09/07 01:58 PM Heater Hose-to-Intake Manifold Nipple
TheShadow Offline
Loc: SoCal High Desert
Hello all. I have a problem with the intake manifold heater hose connection on a '97 CVPI. There is a metal pipe with very fine threads that screws into the plastic pipe on the back corner of the manifold, also very fine threads. That plastic pipe/post is cracked, and the heater hose with nipple still attached blew out yesterday. I thought I could get by for a week or so with a hose clamp around the cracked pipe/post and reseal and rethread the metal nipple back in, until I can afford a manifold.
BUT...here's the weird part: the metal nipple is too small for the plastic! The crack has been tightened so it almost disappears, but there's a LOT of slop in the fit. The threads won't even think about engaging, even when the nipple is bottomed out in the pipe/post. I haven't measured the slop, but I would estimate at least 1/16".
I'm at a loss...did the former owner change something? Are all your manifold to nipple connections set up the same? Anyone run into this before? Could a major amount of RTV or Teflon tape hold the seal for a while (with or without pressure in the cooling system)? Does a new manifold come with the heater hose nipple already installed?
The intake manifold is all plastic, BTW.
Thanks in advance for your responses and HELP!!!!!
#1273917 - 09/09/07 03:51 PM Re: Heater Hose-to-Intake Manifold Nipple [Re: TheShadow]
LSpann601 Offline
Loc: Jackson, Mississippi
yep its comes pressed in...you might as well get a new intake I had the same exact problem with mine
1997 Crown Victoria P71
Mods: Bench Seats | 02 Crown Victoria P71 Steering Gear | Dorman NPI Intake Manifold | PI Coolant Tube | Mechanical Cooling Fan | 98-00 CV Electric High Speed Fan Swap | Flowmaster 40s | 97 Lincoln Town Car Transmission | Suspension Fully Rebuilt
2006 Crown Victoria P71 OLD MS Highway Patrol Car (Wrecked)
2003 Mercury Grand Marquis GS (Wifes Car)
2008 Crown Victoria Police Interceptor OLD NPS Park Ranger Car | Variable Ratio Rack and Pinion Steering (Without Variable Assist Steering) | 17" Wheel Covers | Driver Power Seat Swap | AIRBAG Seats | Vinyl Floor Cover
1981 Chevy Monte Carlo 305ci/700r4 (sbc 408 build in progess)
#1274231 - 09/10/07 01:50 AM Re: Heater Hose-to-Intake Manifold Nipple [Re: LSpann601]
TheShadow Offline
Thanks, LSpann. I was hoping you wouldn't say that...
BTW, can you get me the name and address of the responsible design engineer - I'd (and many others, I'm sure) like to pay him a visit....
6 registered (GrandMarq9807, RF_Overlord, CrownBen, hlbly, ford05, 1 invisible), 178 Guests and 11 Spiders online.
a_d_a_m 188
Ezbok58a 170
charlieD 146
BigMerc96 138
Ponyguy 112
dpk 111
White99MGM 100
SocalSam 85
Moby_Vic 85
Chaplian 72
