#1282225 - 09/21/07 02:11 AM Rear Disc Brakes questions!!!~!!1????
~Rob~! Offline
Loc: Jamestown, ND
Ok, heres the scoop I found a 92 crown vic with rear disc brakes and I want to fit them on my 1990 crown vic what will I all need off of it and what will I need to do to my vic to make them work I did a search and came up with nothing useful.
1990 Ford Crown Vic 302 5.0L v8
HO Conversion(e7's air injection humps grinded down), Cold air intake, Electric Fan, 180*t-stat, Smog pump deleted, Glasspacks, A/C removed, bbk headers with dual exhaust, 3g alternator, Battery relocated to the trunk, BBK underdrive crank pulley, Kirban adjustable fuel pressure reg., Custom H pipe, msd coil, 1993 crownvic aluminum driveshaft, A9M mass air, 3.73 gears with trac lok, A9M mass air, 190lph Walbro fp(Cars weight w/o driver 3595lbs.)
#1282268 - 09/21/07 06:41 AM Re: Rear Disc Brakes questions!!!~!!1???? [Re: ~Rob~!]
Black & Flames Offline
Loc: St-Jerome Qc Canada J7Z6W2
If you swap the entire differential housing, everything will fit except the E-Brake cable that will need custom work. I think the brake lines will need light mods also. Not sure.
If you want to swap only the disc brakes without swapping the entire housing, I'm not sure if that's possible ?? If it is, you will at least have to remove both axles in ordere to swap the backplates.
rules
"Oversteer is when the passenger is scared"
"Understeer is when the driver is scared"
Well... My passengers are always scared !
#1282388 - 09/21/07 01:03 PM Re: Rear Disc Brakes questions!!!~!!1???? [Re: Black & Flames]
88grandmarq Offline
4R70W rebuilder
Loc: North Georgia
you can install the entire rear end, but if the car has been sitting for any length time, its best to inspect bearings and spider gears for wear and pitting. axles are notorious for pitting on these cars.
if you want just the rear disc parts, it does require you remove the axles to un-bolt the backing plates from the axle tube.
rear brake lines on rear disc cars are different from cars with rear drum. the fitting on the brake line that attaches the line to the rear caliper hose is also different, you will need to cut the brake line and get the fitting off the rear disc car.
I cut my stock hard lines, installed the correct fittng and reflared the line, then zip tied the rear caliper hoses to the axle tube.
E-brake cables are also different on rear disc cars. I bought cables for a 93 CV to put on, both rears and the intermediate cable. had to cut my stock front cable and use some clamps to hold it together.
I rebuild AOD/AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/pages/North-Georgia-Transmission-Auto-Repair/348414635312478
#1282447 - 09/21/07 02:08 PM Re: Rear Disc Brakes questions!!!~!!1???? [Re: 88grandmarq]
Stanman Offline
Loc: Columbus, Ohio
What years are whole axles interchangeable? I know where I can get a Town Car axle complete w/brakes but I'm not sure what year-looks like a 98-00
Edited by Stanman (09/21/07 02:09 PM)
I may have to grow old but I don't have to grow up!
'91 Grand Marquis
'00 Mustang GT
#1282627 - 09/21/07 06:12 PM Re: Rear Disc Brakes questions!!!~!!1???? [Re: Stanman]
88grandmarq Offline
4R70W rebuilder
Loc: North Georgia
when you say axle, you mean the axle shaft or the entire differential assembly?
axle shafts are pretty much interchangeable, only difference is the ABS cars have a tone ring for the sensor.
On the diff assembly, 92-97 will bolt in. 98-02 uses a watts linkage and will not bolt in.
#1282673 - 09/21/07 07:10 PM Re: Rear Disc Brakes questions!!!~!!1???? [Re: 88grandmarq]
DuceAnAHalf Offline
Loc: Pinellas Park, Fl.
when i did rear disc on my car i used the rear brake line assembly off the newer car and just added a connector.
the rear drum lines ran along the axle, the newer ones run across the fram and use a soft line to the calipers. the lines are long enough that they are not stressed with the axle at full droop
#1282994 - 09/22/07 01:01 AM Re: Rear Disc Brakes questions!!!~!!1???? [Re: DuceAnAHalf]
~Rob~! Offline
Loc: Jamestown, ND
So basically I just need the calipers and lines and the rotor off the 92?
#1283125 - 09/22/07 09:22 AM Re: Rear Disc Brakes questions!!!~!!1???? [Re: ~Rob~!]
DuceAnAHalf Offline
you will need the backing plate also. the backing plate is the blue part attached to the axle housing in the picture i posted
9 registered (dpk, Black_Sunshine, JDA_09Vic, Fordiesel69, hischuckness, cmiser91), 74 Guests and 11 Spiders online.
a_d_a_m 186
Ezbok58a 158
charlieD 152
BigMerc96 144
Ponyguy 119
dpk 116
White99MGM 102
SocalSam 84
Moby_Vic 76
reminc70 74
