#1293371 - 10/05/07 10:22 PM ABS light on
KYF350 Offline
Hello All,
I posted a thread sometime back about an ABS light that was on on mom's '96 Grand Marquis. I was advised to get the code read on the module due to the fact that it could be myriad issues and nearly impossible to diagnose with just a light illuminated.
Well, today I took the car to the local Ford dealer. They told me that the entire module is crapped-out and that a replacement would be needed. The parts and labor on this job is $780.00. Do I have "idiot" stamped on my forehead or is this about right for this type of repair? Is it me, or is this a bit pricey? Thanks in advance for your responses. Craig.
2005 Ford Excursion Eddie Bauer, 4X4, True Blue/Arizona Beige, 6.0 liter PSD, all bells and whistles, 30mm Ford rear anti-sway bar.
2005 Ford F-350 Superduty, 4X4, 6.0 liter PSD, Red, SC, SRW, Lariat, B&W Turnover hitch, all bells and whistles.
2004 Ford Crown Victoria LX Sport, Dark shadow grey, SOLD.
1996 Mercury Grand Marquis LS, Mocha, HPP, 173A package, traction assist. Mom's car.
#1293456 - 10/06/07 12:41 AM Re: ABS light on [Re: KYF350]
Dan The Vic Man Offline
Loc: Coon Rapids MN
Whats the code and why dod they say its bad?
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1295850 - 10/09/07 12:06 AM Re: ABS light on [Re: KYF350]
KYF350 Offline
Hi Dan,
I apologize for taking so long to reply, and I do appreciate your response.
This is what is on the work order:
CHECK ABS LIGHT ON--EST.
RAN SELF TEST-DTC C1095 PUMP MOTOR CIRCUIT FAILURE.
RAN PINPOINT TEST. NEEDS ABS CONTROL MODULE.
Whatever that means. I'm sure it will mean something to you; it sure doesn't to me. Thanks in advance for your reply. Craig.
#1296011 - 10/09/07 07:06 AM Re: ABS light on [Re: KYF350]
KYF350 Offline
Hi Dan,
Turns out, the actual amount of the estimate is $751.53; not $780.00 like I originally posted. Seems someone in accounting messed up. It looks like $132.95 for labor and $571.08 for parts plus tax and shop supplies. Craig.
#1296179 - 10/09/07 12:47 PM Re: ABS light on [Re: KYF350]
Da Governator
The motor may be bad.
I assume the light always comes on once you hit ~13mph on the initial drive?
RIP 2vmodular
#1296185 - 10/09/07 01:01 PM Re: ABS light on [Re: dRock96Marquis]
Loc: Coon Rapids MN
The motor is toast, which is why its so expensive. Do you really want abs, other wise just disconnect it and have regualar non abs brakes. Unless you have $751 to spend.
RIP 99 CVPI
#1296190 - 10/09/07 01:07 PM Re: ABS light on [Re: Dan The Vic Man]
Blue95 Offline
Loc: Past the Horizon
Probably not related to the failure, but I follow the recommendation of loosening the bleed screw at the brake calipers before compressing them to install new brake pads. That is instead of pushing the fluid back through the system into the master cylinder reservoir if the bleed screws are not loosened.
It seemed that there was a higher failure rate of abs modules due to dirty brake fluid being forced back through them. The debris in the fluid (especially from the larger reservoirs in the front calipers) was messing up the abs module.
Just fyi.
1995 P71-SOLD
2002 HPP-SOLD
#1296710 - 10/09/07 10:04 PM Re: ABS light on [Re: KYF350]
KYF350 Offline
Hi Guys,
Thanks for all the good information.
'drock: Yes, you know it is funny, I would start that car up and the ABS light was nowhere to be found. I have that "disco" digital dash and once I would start moving that angry little light would come on. I'll be willing to bet it was about 13 mph. This car I'm talking about looks EXACTLY like yours on the OUTSIDE. The INSIDE, well, that is a different story.
Dan: I went ahead and paid them to replace that motor. My 80-year-old mother drives it and I'd feel better if it is as it should be.
I have one other question: That car has traction assist. From what I understand, that works up to 25 mph, and gradually tapers off until it doesn't work at all above 35 mph. I also understand that the motor could overheat due to overuse, but has thermal protection that shuts down the unit until it can cool down. Mom recently attended a county fair and it rained and turned the field she was parked in to mud. Could she have revved the engine, spun the tires, and burned that motor up? Just a thought. Thanks again for the info. Craig.
Edited by KYF350 (10/09/07 10:09 PM)
#1296838 - 10/10/07 12:45 AM Re: ABS light on [Re: KYF350]
spaz Offline
my '94 had the abs light come on once and grandpa brought it into the local linc-merc service and they "replaced some sensors" when i got the car i decided to see how the abs felt and nailed the brakes on an empty street after a rainstorm. Apparently, "replacing some sensors" meant disconnecting the warning light because it doesnt even come on when i turn the key. My cruise light doesnt come on anymore but t least that still works though (and hopefully when the fire related recall parts are replaced they wont mess it up)
'94 Grand Marquis LS
#1297172 - 10/10/07 01:26 PM Re: ABS light on [Re: spaz]
03CrownVicPI Offline
Loc: Evergreen Park, IL
$571.08? It's like closer to $300.00 from Ford. I needed one. I just took the light bulb out of the dash. I don't need ABS. The brakes work fine.
#1298186 - 10/11/07 05:41 PM Re: ABS light on [Re: 03CrownVicPI]
SandersP71 Offline
Loc: Indianapolis, IN
Wow. That seems steep. I was lucking in that the police department that originally ordered my CVPI ordered it without ABS.
2001 Crown Victoria Police Interceptor Pretty Much Stock Rebuilt Engine at 133,000 Miles
#1298319 - 10/11/07 09:23 PM Re: ABS light on [Re: SandersP71]
Loc: Coon Rapids MN
ABS sucks anyways, lol.
RIP 99 CVPI
#1298459 - 10/11/07 11:14 PM Re: ABS light on [Re: Dan The Vic Man]
KYF350 Offline
Especially when it costs $571.00 to fix. At least we'll get the cruise repaired for free-I hope! It seems there is a recall on some of those years for that cruise control switch that causes fires.
Anyway, thanks for the info. Craig.
#1298582 - 10/12/07 12:47 AM Re: ABS light on [Re: Dan The Vic Man]
SandersP71 Offline
No kidding. My CVPI with rear wheel drive, V8 engine, and no ABS reminds me a lot of my 1971 Ford Torino I had when I was a teenager. It feels and handles the way a car should.
#1298652 - 10/12/07 01:57 AM Re: ABS light on [Re: SandersP71]
Da Governator
You should get some pics of it ;\)
RIP 2vmodular
6 registered (Sakoulas, mrti, DC_Dave, MIAMI-DADE, olschoolsteel, 1 invisible), 47 Guests and 118 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
