#1331297 - 11/25/07 06:03 PM Fuel Pump Reset Button?
UnmarkedSedan Offline
Loc: Orange County, CA
Can anyone tell me what this is?
The box with the red button and the ground wire going to the trunk lid?
I'm pretty sure it's the fuel pump reset button? What is the purpose of a reset button? What If I push it just because? I have an Idea in mind but I don't want to embarrass myself before I say something? I do know it's not the ejector seat button.
Thanks!
I don't always drive anything newer than 1965, but when I do, it's a full size Panther.
#1331341 - 11/25/07 06:46 PM Re: Fuel Pump Reset Button? [Re: UnmarkedSedan]
DriftingVic Offline
Loc: Nolensville, TN
its an inertia cut off switch so if your in an accident it cuts the fuel pump off.
'08 Crown Vic P71
White, Push Bar, spotlight and lots of hail damage(aka speed bumps).
'90 Crown Vic (SOLD)
Dual Exhaust, CAI, HO intake and TB..
Stiff suspension on all 4 corners
'89 Crown Vic (deceased)
310 HO WR-AOD
I break it, I fix it.
#1331344 - 11/25/07 06:49 PM Re: Fuel Pump Reset Button? [Re: UnmarkedSedan]
TheBlunderbuss Offline
Loc: CHAMPAIGN, IL
Fuel pump inertia switch reset button.
The inertia switch is literally a ball in a cup that bumps into a lever, when in an accident.
Pushing the button resets the lever.
No need to push it unless you're not getting power to the pump.
Pushing it otherwise won't hurt the car, unless you push too hard and break it ;\)
02/88 LTD Crown Victoria - 860 miles (hehe)
Don't forget that Throttle valve cable clip update!
#1331496 - 11/25/07 10:34 PM Re: Fuel Pump Reset Button? [Re: TheBlunderbuss]
89LTDBoy Offline
Loc: Mandeville, LA, USA
Yup, looks like the Fuel Pump Inertia switch.
Is that in a box? Cuz mine looked a little different...
Current Vehicle-1999 Ford Explorer
#1331511 - 11/25/07 10:59 PM Re: Fuel Pump Reset Button? [Re: 89LTDBoy]
DriftingVic Offline
they used a couple different styles.
'08 Crown Vic P71
310 HO WR-AOD
#1331587 - 11/26/07 12:35 AM Re: Fuel Pump Reset Button? [Re: DriftingVic]
Loc: CHAMPAIGN, IL
Yeah mine looked different too, but I surmised it couldn't be the air ride on/off, because that's an on-off switch.
#1332086 - 11/26/07 05:21 PM Re: Fuel Pump Reset Button? [Re: TheBlunderbuss]
89LTDBoy Offline
Yeah it definitely looks like the fuel pump switch, and it's in the right spot, but it just looked different than the one they used in mine.
#1332092 - 11/26/07 05:27 PM Re: Fuel Pump Reset Button? [Re: 89LTDBoy]
The ground wire is part of some fleet wiring that adds extra grounds to the hood and trunk to keep things happy with two-way radios.
ALex.
#1333507 - 11/28/07 12:12 PM Re: Fuel Pump Reset Button? [Re: GM_Guy]
Thanks everyone for the replies, that's what I figured it was. So the ground wire I don't really need for the reset button to work? I was thinking about replacing it in case I ever need to use that button.
There's an identical ground wire on the same location on the other side of the trunk lid.
Thanks!
Moderator:  88grandmarq, Stu
21 registered (01GRANDMARQUIS, BloodCleansedSou, backyardmechanix, BigMerc96, Bellwestern80, 2 invisible), 89 Guests and 69 Spiders online.
KayTar 582
CNGInterceptor 394
sm41 346
Black_Sunshine 281
BlackVic_P71 277
Ezbok58a 257
ajdereicup 238
Moby_Vic 233
BigMerc96 232
Superhobo 220
