#1357386 - 12/30/07 07:31 PM Recommended posi-traction Unit
crown_vic_driver Offline
Loc: Greensboro, NC
What do any of ya'll recommend to get for a posi-traction unit? What all different units do you all have in your cars that didn't come with it in the factory rear end.
1999 Ford Crown Victoria P73
3.27 gears, aluminum driveshaft, Dual Delta 40-series Flowmaster Exhaust without H-Pipe, Tint, new upgraded PI intake manifold, Michelin Defender Tires
http://www.cardomain.com/ride/801867
2005 Dodge Ram 1500 Crew Cab
1966 Ford Galaxie 500 2 Door Fastback - 390 FE Motor
#1357400 - 12/30/07 08:23 PM Re: Recommended posi-traction Unit [Re: crown_vic_driver]
metroplex Offline
Loc: Motor City, USA
Ford Traction-Lok differential.
Auburn, Eaton, Traction-Tech/Detroit Locker/Detroit TrueTrac and other limited slip differentials are popular, but the Ford Traction-Lok differential is hard to beat. The Ford units are used on the 03-04 Terminator Cobras, the 05-up Mustang GT, and the Shelby GT500. If it is good enough for 500+ hp, it's good enough for a Crown Vic.
#1357445 - 12/30/07 09:34 PM Re: Recommended posi-traction Unit [Re: metroplex]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
Agreed, fords unit does the job well \:\)
#1357452 - 12/30/07 09:42 PM Re: Recommended posi-traction Unit [Re: Quickvic30]
JohnG Offline
Tech Admin
Loc: Socialist state of MN
Because the Trac-Lok is completely rebuildable w/o removing the carrier, and one of the best units for everything BUT rock-crawling (which no Panther can do anyway) I too believe that they are the best option.
The Trac-Lok does require carrier and ring-gear removal for installation, but in many cases the new carrier bolt in w/o any changes in shimming. Therefore, installation is very straightforward.
#1357546 - 12/30/07 11:53 PM Re: Recommended posi-traction Unit [Re: JohnG]
Da Governator
I completely agree with the above. The Ford (FRPP is same) traction lok is really your best choice. OEM reliability and driveability, very easy and cheap to rebuild, and is a BREEZE to install (especially since, usually the tolerances will be right on with factory shims)
...everything BUT rock-crawling (which no Panther can do anyway)
I dunno, SUVic's aero might of been able to climb some small boulders
RIP 2vmodular
#1357835 - 12/31/07 09:59 AM Re: Recommended posi-traction Unit [Re: dRock96Marquis]
robs Offline
Loc: O'Fallon, IL
If I had an extra $600... Got one in my Jeep... They're harsh, make scary noises at times, and have bad road manners... I absolutely LOVE it.
Unfortunately, I've got a Trac-Loc from a Mustang to install instead. Just can't justify the extra cash for the Detroit Locker.
#1357862 - 12/31/07 10:40 AM Re: Recommended posi-traction Unit [Re: robs]
metroplex Offline
I would not recommend a Detroit Locker for a Crown Vic unless it is for drag racing only, or for dry summer roads.
A Ford Traction-Lok differential is about $230 new retail, while takeoff units cost anywhere from free to $100.
The rebuild kit that includes carbon-fiber clutches (OEM on 03-04 Cobra, 05-up Mustang GT, and 07-up GT500) is only $90 while the rebuild kit with standard clutches (OEM since ~1986 in T-Lok units) is $30+.
Generally speaking, you can just swap the ring gear over to the new carrier and not worry about backlash or shimming. It's necessary to check the backlash and bearing pre-load, but again, generally speaking, it is an easy swap as John mentioned.
FRPP has a ring-gear/flywheel bolt kit for $10 that will cut your install time SIGNIFICANTLY since you don't have to wait for the threadlocker to cure.
#1357963 - 12/31/07 01:25 PM Re: Recommended posi-traction Unit [Re: metroplex]
Dan The Vic Man Offline
Loc: Coon Rapids MN
I have an arburn diff and i absolutely love it, cone clutches instead of the flat ones in the stock trac loc units from ford, i am extremely hard on my vic and the ford trac lock takes a hell of a beating, but i decided to upgrade diffs when i did my gear upgrade.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1358066 - 12/31/07 03:48 PM Re: Recommended posi-traction Unit [Re: Dan The Vic Man]
Quickvic30 Offline
Just watchin
the ford 8.8 will be plenty for you CVD \:\)
#1359560 - 01/02/08 03:35 PM Re: Recommended posi-traction Unit [Re: Quickvic30]
Loc: Greensboro, NC
After reading all of your comments I'm probably gonna go with teh ford racing traction lock.
I wish I would have got one and just got it all put in when I got my gears done. The guy who did my gears said he might have to take the pinion back out if they are not lined up correctly after he puts my ring on the traction lock carrier.
#1359986 - 01/03/08 01:21 AM Re: Recommended posi-traction Unit [Re: crown_vic_driver]
Da Governator
He shouldn't have to, especially if you go with the FRPP unit. Normally it will slide right in with the same shims and be spot on ;\)
You still need to check the backlash, though - and if it's off he may need to reshim the carrier. But he shouldn't have to mess with the pinion at all.
RIP 2vmodular
#1360018 - 01/03/08 02:20 AM Re: Recommended posi-traction Unit [Re: dRock96Marquis]
BigJon Offline
Loc: Upstate NY
unfortunately his car is no more. \:\(
10 registered (garndreadz, DudeAbides, EZMoney95, ford05, DES, 1 invisible), 280 Guests and 6 Spiders online.
BigMerc96 141
a_d_a_m 139
dpk 129
Ponyguy 91
Moby_Vic 81
charlieD 79
RF_Overlord 71
SocalSam 65
Bellwestern80 53
EZlivin11 52
