#1358171 - 12/31/07 06:00 PM Wiring color code
Happy Birthday new2me2003CVPI Offline
Loc: Germantown, Wi.
Does anyone have a wiring code for under the dash for a
2003 Crown Vic. I could really use it so I can install
this remote start myself.
Thanks in advance.
2011 Candy White VW Jetta. Saweeet!
2003 CVPI with a few mods. Bumper tuck. 2001 Exploder cd player. J-Mod. Headlight relay upgrade Custom made by me. Viper 1700xl remote start. General Altimax Hp 245/50/16 tires. Gatorback belt. Underdrive pulleys(So What!!!) And now 20% tint all around!!!
#1358220 - 12/31/07 06:41 PM Re: Wiring color code [Re: new2me2003CVPI]
TechnoWeenie Offline
Loc: The perimeter
Do you know how to solder? Do you have a 100W+ soldering gun? Can you follow a wiring diagram?
#1358249 - 12/31/07 07:08 PM Re: Wiring color code [Re: new2me2003CVPI]
Da Governator
What do you mean a wiring code?
You mean a diagram? of what, the ignition switch circuit?
RIP 2vmodular
#1358285 - 12/31/07 07:46 PM Re: Wiring color code [Re: dRock96Marquis]
Yeah a wiring diagram of the ignition circuit. And
the door locks.
#1358444 - 12/31/07 11:28 PM Re: Wiring color code [Re: new2me2003CVPI]
Dan The Vic Man Offline
Loc: Coon Rapids MN
Do you have acess to alldata, im sure Drock or quickvic will have one for you.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1358463 - 12/31/07 11:46 PM Re: Wiring color code [Re: Dan The Vic Man]
jmoller Offline
Broke!!
Loc: Southern California
I put in a remote start from Bulldog security. Their website has a diagram of the wires you use to install it. it might help... http://www.bulldogsecurity.com/ . I dont know which one you have but the entire system hooked up to the wires under the steering column... not under the hood. On the website go to vehicle wire diagrams and that should help...
99 CV 126,XXX. Dream car #1 checked off the list...
#1358464 - 12/31/07 11:47 PM Re: Wiring color code [Re: Dan The Vic Man]
Loc: The perimeter
The wiring diagrams are nothing..... The 'issue' is that if he doesn't know WTF he's doing, he'll do more damage than good....
DIRECTWIRE™ WIRING INFORMATION - FORD / CROWN VICTORIA / 2003 /
[PRINT THIS PAGE]
12volts brown and lt. green + ignition harness
Starter red/lt. blue + ignition harness
Ignition white/yellow + ignition harness
Power Lock pink/yellow driver kick, door harness
Notes: Without keyless entry the door locks are 5wi (reverse polarity). With keyless entry they are positive trigger.
Power Unlock pink/lt. green driver kick, door harness
Lock Motor pink/black 5wi driver kick, door harness
Unlock Motor red/orange 5wi driver door motor in door
Parking Lights+ brown + pin 4, blk plug @ LCM
Notes: The LCM (Lighting Control Module) is to the right of the steering column.
Parking Lights- white/black - pin 13, gry 16P plug @ LCM
Hazards same as turn signals
Turn Signal(L) lt. green/orange + steering column
Turn Signal(R) orange/lt. blue + steering column
Door Trigger dk. blue and black/orange - LCM
Notes: Blue is the driver door trigger wire, it is in pin 11, gray 22 pin plug. Black/orange is the three passenger doors, it is in pin 11, gray 16 pin plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Release purple/yellow 5wi driver kick, harness to rear
Notes: The fuel door release is white/pink (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Horn Trigger dk. blue - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
http://www.p71interceptor.com/remotestart
http://www.p71interceptor.com/remotestart/0303table.html
#1358522 - 01/01/08 01:09 AM Re: Wiring color code [Re: TechnoWeenie]
I think I've stated it in another post. I have installed 3
remote starts in past vehicles. And done other wiring to my vehicles. Wiring in no prob I just needed the info.
Thanks for all the help with the info.
I think I won't send in the car and I'lll just do it myself.
#1358564 - 01/01/08 01:55 AM Re: Wiring color code [Re: new2me2003CVPI]
Loc: The perimeter
Do yourself a favor and get the 160XVL, it's about 20$ more, but has longer range remotes, up to a mile..
#1358609 - 01/01/08 10:18 AM Re: Wiring color code [Re: TechnoWeenie]
[/quote]
Do yourself a favor and get the 160XVL, it's about 20$ more, but has longer range remotes, up to a mile..[/quote]
Thats the exact one I have!!!
Moderator:  BigMerc96, Quasar
7 registered (CVJPMG, DES, 2004_p71, JaxRhapsody, IPreferDIY, 1 invisible), 85 Guests and 97 Spiders online.
NM117 324
EZlivin11 131
BigMerc96 127
Moby_Vic 126
RF_Overlord 124
Chaplian 117
mdnos 96
a_d_a_m 95
Ezbok58a 92
09P71VIC 91
