#1365584 - 01/09/08 07:58 PM Trouble Code P0455
nickwithcrownvic Offline
Loc: Ohio
My 2004 cv is reading the code P0455 which is Evap Emission Control System Leak Detected (Gross Leak/No Flow). I was wondering if anyone could help me with some ideas for some fixes to try or whether i should just take it to a mechanic. thanks for any input
2009 cv p71 stock
#1367046 - 01/11/08 07:01 PM Re: Trouble Code P0455 [Re: nickwithcrownvic]
pas101 Offline
Loc: Southeastern, PA
- Gas Cap
- EVAP Filter Under Trunk
- EVAP Purge Valve
- EVAP System Hoses
Elwood: It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses.
Jake: Hit it.
2004 Ford Crown Victoria Police Interceptor P.O.B. Vehicle, Black, with Magnaflow Catalytic Converters, Magnaflow Cat-back 2 1/4" dual exhaust system with "H" pipe welded in, Deep Trans Pan/Synthetic Fluid Flush, Pre '00 Deep Wheel Center Caps with refinished black wheels, Continential Conti PRO Contact 235-60-16R H rated tires, Hi-Flow Air Intake, Superchips Micro MAX Tuner, "Six Pack" strobe kit, visor wig wags, high speed wig wag high beams, Unity 250,000 CP Post Spotlight, Nova MIRT, "Pursuit" Remote Starter/Electric Lock system and lots more...
#1367128 - 01/11/08 08:53 PM Re: Trouble Code P0455 [Re: pas101]
Dan The Vic Man Offline
Loc: Coon Rapids MN
Replace your gas cap.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1367152 - 01/11/08 09:15 PM Re: Trouble Code P0455 [Re: Dan The Vic Man]
Dirt820 Offline
Resident Alcoholic
Loc: Machesney Park, IL
Gas cap is the most likely cause. First check to make sure it's tight, then after that, I suggest just replacing the cap to be safe. If a visual inspection shows no broken hoses, and nothing else obvious, take it in and have the system fogged.
I always wanted to be somebody, but I should have been more specific.
Lily Tomlin
#1367167 - 01/11/08 09:34 PM Re: Trouble Code P0455 [Re: nickwithcrownvic]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
It caught you filling up without shutting off the engine.
$500.00 or 30 days.
#1368071 - 01/13/08 03:13 AM Re: Trouble Code P0455 [Re: gord_bolton]
Mainsail Offline
Loc: Stadium District Tacoma
I have a recurring problem with the same code. I get a different code for the gas cap though. Iím still working mine, Iíll post if I find something.
2005 Jeep Grand Cherokee WK Hemi
#1368076 - 01/13/08 03:48 AM Re: Trouble Code P0455 [Re: Mainsail]
elwood Offline
Loc: chicago burbs
mine threw the code a couple weeks ago, i cleared it and rotated the gas cap 180*, just threw a code again friday, i haven't checked/cleared it yet. the O ring on my cap looked to have a permanent indentation set into it, i think it's time for a new cap on mine for sure anyway.
does anyone think the instant fill cap is asking for more trouble? standard cap is 10832, instant fill is 41002
http://stant.com/index.cfm?location_id=5009
2003 P71
#1368221 - 01/13/08 02:16 PM Re: Trouble Code P0455 [Re: elwood]
Mainsail Offline
I purchased my problem with the car. The previous owner bought a Ford locking gas cap and replaced one of the lines under the hood, so he was aware of the issue. I was getting two codes for a while, the large leak and small leak codes. I found the small leak under the hood and replaced the line. That fixed the small leak. Iíve also blown air though the lines and thereís no blockage (no flow) and replaced the solenoid on the charcoal canister. The only thing I can think of to try next is a possible valve from the vacuum system (wherever that may be) and after that, change whatever sensor is detecting the problem (IOW, the system is good but the sensor is bad).
EDIT: that code is for a gross leak or a no-flow condition. My theory is that since I cannot find a gaping hole or disconnected/broken line, itís not a gross leak. That leaves a no-flow condition, which would indicate to me either a blockage or a valve not opening. Or the sensor is falsely reporting.
Edited by Mainsail (01/13/08 02:19 PM)
#1368245 - 01/13/08 03:10 PM Re: Trouble Code P0455 [Re: Mainsail]
elwood Offline
Loc: chicago burbs
i'd lean towards a valve not opening first, do you top off the tank to the tippy top like i do? could it be a "liquid-where-there-should-be-vapor" thing going on?
2003 P71
Moby_Vic 182
a_d_a_m 152
BigMerc96 136
EZlivin11 105
Chaplian 103
White99MGM 98
charlieD 95
RF_Overlord 86
DudeAbides 80
SocalSam 75
