#1386205 - 02/02/08 02:48 PM 2001 crown vic # 8 misfire
bdd Offline
Car running rough 104,000 miles. Check engine light on, and flashes sometimes. Went to autozone code PO308 cylinder #8 misfire. Suggested putting fuel injector cleaner in. maybe sticking injector. bad plug, wire or coil pack. Looked at engine,looks totally different the 1997 crown vic. Is the spark plug next to the injector? Which is the cylinder #8? ALso any suggestions.
Thanks
#1386210 - 02/02/08 02:58 PM Re: 2001 crown vic # 8 misfire [Re: bdd]
BMFer Offline
I'm your huckleberry
Loc: 30106
Cylinder 8 is the cilinder closest to the firewall on the driver side.
Radiator
5<---->1
6<---->2
7<---->3
8<---->4
Firewall
Fuel injector cleaner is not gonna fix it. Could be a # of things - plugs fouled, damaged boot & spring on COP, oil/water leakage into spark plug well, faulty COP (coil on plug), coil or injector disconnected, damaged wiring to coil or injector, faulty injector, low or no compression from damaged valve, etc. Most common issues however are with COP's, boots & springs, and plugs.
The plug is in the same place as the 97. It just has a coil sitting directly on top of it, rather than a plugwire.
'13 Coyote 5.0
#1386212 - 02/02/08 03:03 PM Re: 2001 crown vic # 8 misfire [Re: BMFer]
bdd Offline
ok thanks I will try pulling plug can you replace just the cop on the # 8 cylinder?
#1386222 - 02/02/08 03:18 PM Re: 2001 crown vic # 8 misfire [Re: bdd]
BMFer Offline
Loc: 30106
Yes, but I'd make sure that's the problem before you spend $$$ on it. If you can afford the $30-50 though, I'd say go ahead and replace it and if it solves the problem, there ya go. If not, you've got a good spare, because one will eventually die out.
'13 Coyote 5.0
#1386328 - 02/02/08 06:39 PM Re: 2001 crown vic # 8 misfire [Re: BMFer]
koolaid6666 Offline
Loc: LI,NY
 Originally Posted By: BMFer
Radiator
5<---->1
6<---->2
7<---->3
8<---->4
Firewall
This helps me Out I was just going to ask the same question I got a P0301 code cylinder #1 misfire I didn't know were it was.
2007 Black P71
2003 Green p74
1991 Crown Victoria
1999 Green SAP-Part Car
