#1400545 - 02/18/08 03:51 PM best way to remove fuel from tank?
modified93tc Offline
Loc: indianapolis
I'm getting ready to junk my 93tc but would like to remove the aprox. 15gal of gas in the tank. Any suggestions? The battery is not hooked up and no battery terminals so would like to do without power. If I have to I can hook battery up temp. Thanks
93tc 240k miles RETIRED
97 CVPI-- $1200 for @140k sold 7/11 with 240k for $1200
03 CVPI 178k miles bought 7/11 UD pulleys, 70mm TB, more soon
96 Formula Firebird--LT1
#1400678 - 02/18/08 06:29 PM Re: best way to remove fuel from tank? [Re: modified93tc]
Sonders Offline
Loc: Laval, Quebec, Canada
Drill a hole in the gas tank?
2006 Ford Crown Victoria P71
#1400679 - 02/18/08 06:31 PM Re: best way to remove fuel from tank? [Re: Sonders]
Bobert2647 Offline
Former Vic Owner
Loc: West TN
Put a clean catch can of some sorts, large enough to hold the fuel in the tank and punch a whole in the tank with a phillips head screw driver.
#1400720 - 02/18/08 07:22 PM Re: best way to remove fuel from tank? [Re: Bobert2647]
99_03PantherS Offline
Loc: NW side Chicago
I was going to say just drive,,,
but yeah, gorge it.
Jason G.
'81 Mark VI 2 door
'88 Towncar Cartier
#1400813 - 02/18/08 09:04 PM Re: best way to remove fuel from tank? [Re: 99_03PantherS]
DodgeRider Offline
Formerly 2004CVPIDave
Loc: Kansas City
You can also remove the fuel filler neck (by cutting it off right at the tank) and then siphon it out with a pipe. You can also remove the pump and siphon from there too.
Real men do it in 4 doors! -
1991 Suzuki Katana 750 (Cyan/Magenta) - 21K - 748cc, 13,000RPM
2006 F150 SuperCab 4x4 (Black) - 55K - 5.4L 3V, 3.73 LSD, Chrome Pkg
2005 Chebby Malibu (2.2L) - 65K - Lady's Car (Mods: RainX, Winter Washer Fluid, Anco Wipers)
#1400958 - 02/18/08 10:40 PM Re: best way to remove fuel from tank? [Re: BigNSlow]
BMFer Offline
I'm your huckleberry
Loc: 30106
Why not just disconnect the fuel line under the car and stick it in a can, then turn on the ignition a several times? Let the pump do all the work.
or rather than turn on the ignition several times, simply plug a jumper wire into the fuel pump relay socket.
When junking old vics, I usually disconnect the pressure line at the fuel rail and connect a hose to it and into a gas can.
'13 Coyote 5.0
#1401017 - 02/18/08 11:38 PM Re: best way to remove fuel from tank? [Re: BMFer]
kustomizingkid Offline
Loc: Minnesota
How long does it take for the pump to drain the tank?
2000 CVPI 121,000 miles
#1401020 - 02/18/08 11:40 PM Re: best way to remove fuel from tank? [Re: Bobert2647]
Da Governator
And if the metal screwdriver sparks against the steel fuel tank?
Serge and BMFer's ideas sound the best to me. You could probably unhook it right at the fuel filter inlet if you wanted as well.
The fuel pump relay is in the relay bank by the cruise servo, attached to the vacuum reservoir
RIP 2vmodular
#1401043 - 02/19/08 12:01 AM Re: best way to remove fuel from tank? [Re: dRock96Marquis]
Loc: Minnesota
At the junkyard they punch every single tank with an air chisel, been doin that for as long as the yard has been around, haven't ever had an issue.
#1460724 - 04/27/08 07:32 PM Re: best way to remove fuel from tank? [Re: kustomizingkid]
Loc: indianapolis
Tomorrow is doomsday for my 93tc so I decided to try a $3 Siphon from Walmart and it worked great. It comes with a 6 foot hose which you will need to get all the way into the tank. Pumped out about 8gal.
Someone posted that our Panthers have an anti siphon valve but that is not the case. The only thing I had to do was prop open the flapper at the gas nozzle with a screwdriver and insert siphon hose. I guess from now on I will be more wary of gas thieves. Thanks for all the suggestions
BTW--someone is coming to pick up the TC for scrap and giving me $200.
Edited by modified93tc (04/27/08 07:32 PM)
NM117 334
Moby_Vic 146
BigMerc96 120
EZlivin11 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
