#1423303 - 03/14/08 02:05 PM seat belt/ door chime disable
Nitronoise Offline
Loc: Lake County Illinois
Hello everyone , Ineed to know how to disable the door open / seat belt chime for one of my village's squad cars ,
not too safe when my offer gets out and the door chime is going DING DING DING when looking for bad guys
thanks in advance
Nitronoise
Got Nitro?????
#1423319 - 03/14/08 02:30 PM Re: seat belt/ door chime disable [Re: Nitronoise]
Sepiroth Offline
Loc: Kouts, Indiana
I am unsure on how to type this but I would use the search button and key in dark mode.
#1423323 - 03/14/08 02:33 PM Re: seat belt/ door chime disable [Re: Sepiroth]
Diller Offline
Loc: Cedarburg, WI
Actually the seat belt "dinger" is separate from Dark Mode. In my old '00, I was able to unplug the sensor at the base of the seal belt (on floor). Not sure if the newer models are the same???
Diller
'03 P71
#1423335 - 03/14/08 02:50 PM Re: seat belt/ door chime disable [Re: Diller]
Sepiroth Offline
Loc: Kouts, Indiana
D'oh, I was cornfused.
#1423383 - 03/14/08 03:39 PM Re: seat belt/ door chime disable [Re: Sepiroth]
tackleberry Offline
Loc: Las Vegas
i think diller is right...there is a plug that is connected to the seatbelt under the seat which contolls the chime and dashlight.
#1424521 - 03/15/08 09:26 PM Re: seat belt/ door chime disable [Re: tackleberry]
Nitronoise Offline
will that affect the air bags ????
Got Nitro?????
#1424547 - 03/15/08 09:51 PM Re: seat belt/ door chime disable [Re: Nitronoise]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
It's a sequence you have to do with the seat belt, IIRC
Turn key to accessories mode
Wait for the belt light to go off, takes a minute
when it goes off plug and unplug the belt three times
then turn the headlights on for a sec, then off
then buckle and unbuckle 3 more times and the belt light should flash and it will be gone, no more DING DING DING DING
#1424725 - 03/16/08 02:31 AM Re: seat belt/ door chime disable [Re: Nitronoise]
tackleberry Offline
Loc: Las Vegas
i dont think so...the airbag module is seperate from seatbelts....but then again these newer cars they wire all this crap together
#1424899 - 03/16/08 10:46 AM Re: seat belt/ door chime disable [Re: tackleberry]
Nitronoise Offline
ok so you mean the plug under the seat or the actual seat belt??
THANKS again
Nitronoise
Got Nitro?????
#1430948 - 03/23/08 11:53 AM Re: seat belt/ door chime disable [Re: Quickvic30]
denali81 Offline
Loc: Walworth Co. Wisconsin
was this little jig described above a joke or no? I did it, I think my neighbors think I have OCD, but it did not work.
I have like a little mission control under my seat, Im afraid to touch any wires and plugs under there.
I'll just have to keep the radio turned up... err I mean I always buckle my seat belt.
2003 Crown Victoria LX Sport
#1431118 - 03/23/08 03:34 PM Re: seat belt/ door chime disable [Re: denali81]
alex904 Offline
Loc: Florida
Yeah my friend disconnected his plug on his 04 lx and the airbag light came on! Why is that?
2000 Black CVPI with 138,000 mls. when purchased in AUG. 06
#1436247 - 03/29/08 11:21 AM Re: seat belt/ door chime disable [Re: alex904]
denali81 Offline
look in the owners manual-
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
for the seat belt (beltminder) to disable/enable
in the safety belt section.
-nothing here on the door chime. I still want to turn mine off.
#1436342 - 03/29/08 02:14 PM Re: seat belt/ door chime disable [Re: denali81]
AtwMerc6491 Offline
Loc: Massachusetts
For my 00 MGM i unplugged the seatbelt under the seat and both the chime and seatbelt light never comes on anymore. But the chime will still ring if i leave the keys in the ignition and open the door as well as leave the lights on and open the door.
#2536656 - 06/06/12 02:52 PM Re: seat belt/ door chime disable [Re: Nitronoise]
IanMoone Offline
Loc: MN
on my 00 i removed the plug thats at the base of the seatbelt and theres two ways to get rid of that dinging, one, theres a wire that has a brass tip that goes into the ignition cylinder that dings when ur cars on but not turned over u can just pull it out of the cylinder and theres a wire that is part of the LCM its the furthest black wire on the drivers side. that wire when clipped deactivates the door open ding and the dome/cabin light.
2000 Crown Vic Police Interceptor 4.6 V8
#2536691 - 06/06/12 04:11 PM Re: seat belt/ door chime disable [Re: Quickvic30]
torotoro Offline
Loc: NJ
IIRC the key should go from the OFF position to th ON position. The On position is closest to the START position, ACC is the furthest from START.
Edited by torotoro (06/06/12 04:12 PM)
2002 LX Spruce Green/Tan Cloth 91,000 miles
Bilsteins, 17mm rear sway bar, BH1976 headlight relay harness, side marker/blinker mod
BC4E Dead Pedal, Upgraded Speakers, 35% Window Tint, De-chromed Exterior, Soundproofing.
6 registered (RF_Overlord, tinpin, GrandMarq9807, Chevyguy, 2 invisible), 62 Guests and 107 Spiders online.
Moby_Vic 191
a_d_a_m 157
BigMerc96 142
EZlivin11 111
Chaplian 111
White99MGM 111
DudeAbides 96
charlieD 89
RF_Overlord 87
SocalSam 78
