#1438929 - 04/01/08 11:13 AM Headlights are pointing downward. How do I adjust?
P71Man70 Offline
Loc: Florida
I cant see the road at night. My headlights on my CVPI are pointed sharply downward towards the pavement. I need to adjust the headlights upward so i can see farther down the road at night. I have tried everything to unscrew those plastic bolts so I can adjust the headlights upward. They are impossible to take off. I have tryed a pliars and I stripped one of them. I tryed a hammer and screwdriver to budge them...i cracked the plastic bolt. Why would Ford put plastic bolts on like that where you cant even find the correct tool to unscrew them?
Can anyone help me?
2000 Crown Victoria Police Interceptor
#1438987 - 04/01/08 12:10 PM Re: Headlights are pointing downward. How do I adjust? [Re: P71Man70]
BigJon Offline
Loc: Upstate NY
put 800lbs in your trunk. hehe, j/k!
you need a headlight adjusting tool.
#1438998 - 04/01/08 12:31 PM Re: Headlights are pointing downward. How do I adjust? [Re: BigJon]
metroplex Offline
Loc: Motor City, USA
I hope you were kidding about "breaking off" the plastic nuts... Those "plastic nuts" are part of the adjusting assembly. You rotate the threaded stud to adjust the headlamps. You can use either a 4mm open/box ended wrench or a special headlight tool. I recommend the 4mm ignition wrench.
BTW, my 00 HPP came from the factory with the headlamps aimed 24" below spec. The factory uses a mechanical VHAD tool that was obsoleted decades before the 2000 MY.
#1439073 - 04/01/08 02:20 PM Re: Headlights are pointing downward. How do I adjust? [Re: metroplex]
P71Man70 Offline
Loc: Florida
No im not kidding..I cracked the f'n plastic nut. I got so mad I threw the hammer and screwdriver on the ground and walked away angry as hell....The last thing I want to do is to start breaking things on my crown vic. I love that car.
I 'll go to advance auto to get a 4mm ignition wrench. thanks.
Edited by P71Man70 (04/01/08 02:21 PM)
#1439127 - 04/01/08 03:35 PM Re: Headlights are pointing downward. How do I adjust? [Re: P71Man70]
Gone Offline
Loc: Gone
Why do great things always have to get complicated? Special tools? Special access? Difficult reach?
My 83 has some phillips head screws easily accessible without moving or removing anything. I could almost do it during a red light stop it is so easy. Don't even have to open the hood as they adjust from the front.
#1439260 - 04/01/08 06:26 PM Re: Headlights are pointing downward. How do I adjust? [Re: Gone]
Mainsail Offline
Loc: Stadium District Tacoma
It cost me $20 to have the dealership properly aim the headlights for me. Time and money well spent.
2005 Jeep Grand Cherokee WK Hemi
#1439282 - 04/01/08 06:56 PM Re: Headlights are pointing downward. How do I adjust? [Re: Mainsail]
P71Man70 Offline
Loc: Florida
I just spent 30 minutes over at Advance Auto Parts having two other guys help me loosen these crazy plastic screws with no luck. One said I needed a torc wrench. Adavance didnt have the size so we tryed every other tool under the sun.
"F" this shyt, im taking it to Ford and paying them $20 to adjust the lights. Thanks Mainsail.
#1439294 - 04/01/08 07:12 PM Re: Headlights are pointing downward. How do I adjust? [Re: P71Man70]
sanco Offline
fo shizzle
Loc: chicago, illinois
nooooo!!!!...you dont loosen the plastic, leave the plastic alone!!! lol, yea thats a good idea, just go to the dealer man lol
#1439332 - 04/01/08 08:08 PM Re: Headlights are pointing downward. How do I adj [Re: sanco]
new2me2003CVPI Offline
Loc: Germantown, Wi.
Yeah go to the dealer before they can't even do it!!!!
2011 Candy White VW Jetta. Saweeet!
2003 CVPI with a few mods. Bumper tuck. 2001 Exploder cd player. J-Mod. Headlight relay upgrade Custom made by me. Viper 1700xl remote start. General Altimax Hp 245/50/16 tires. Gatorback belt. Underdrive pulleys(So What!!!) And now 20% tint all around!!!
#1439372 - 04/01/08 09:02 PM Re: Headlights are pointing downward. How do I adj [Re: new2me2003CVPI]
GhostRider Offline
Ford will probably adjust it for nothing. Only takes them minutes.
Mom took her 2001 Windstar because the headlights were not aimed right. They did it for nothing. Same thing with my 06.
-Tim
#1439379 - 04/01/08 09:09 PM Re: Headlights are pointing downward. How do I adj [Re: GhostRider]
jaybird Offline
Loc: San Jose Ca.
too bad you did not do a search before you broke stuff off?
its a 4 mm Friction ratchet you can find them at Carquest. Its 25 bucks...The dealership here in San Jose wants $70 to adjust them..I got the tool for $25 and saved my $45
Good Luck! Next time try to do a search beforehand.
2000 CV LX HPP Loaded 3.55 RAR
189K Miles! / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
#1439383 - 04/01/08 09:13 PM Re: Headlights are pointing downward. How do I adj [Re: jaybird]
BigJon Offline
Loc: Upstate NY
or ask first, lol. that is why we are here.
#1439692 - 04/02/08 05:38 AM Re: Headlights are pointing downward. How do I adj [Re: BigJon]
metroplex Offline
A 4mm ignition wrench = 4mm combination wrench. I bought one for under $10. The special tool is a friction ratchet and is less versatile because if you back up the stud enough, you can't remove the ratchet due to inadequate fender clearance. The 4mm wrench is easier to use and less expensive. I think Sears even had a full set for $10.
You do nothing with the plastic "nuts." You adjust the METAL stud with the hex head (the thing with threads that is surrounded by the plastic nut). The top stud is for vertical aim, the bottom stud is for horizontal aim. Touch only the top stud for adjusting the height of the beam. At this point, I recommend going to the dealer. You may need to buy a new headlamp as well.
Moderator:  BigMerc96, Quasar
1 registered (bigltc), 26 Guests and 85 Spiders online.
NM117 333
Moby_Vic 129
EZlivin11 127
RF_Overlord 125
BigMerc96 120
Chaplian 115
Ezbok58a 99
mdnos 98
a_d_a_m 97
09P71VIC 91
