#1446462 - 04/10/08 10:46 AM PO171 code
hawkmaneg Offline
Loc: utah , usa
I have checked all my vacumm lines and I still get a p0171 code , bank 1 too lean . I am wondering if this could be caused by a leaking o-ring on a fuel injector for that bank. On the code list all 02 sensors have there own code and it seems everything else does except this any ideas ? Thanks Scott
97 p71 4.6l
1997 p71 4.6l 95000 mi
#1446466 - 04/10/08 10:57 AM Re: PO171 code [Re: hawkmaneg]
98VicP71 Offline
13.97@99MPH
Loc: ATL
you could also have a leak at the manifold. does your car idle fine? When was the last time you replaced the fuel filter?
Have you tried changing the O2 sensors could just be a faulty sensor.
Does your exhaust manifold leak?
#1446477 - 04/10/08 11:09 AM Re: PO171 code [Re: 98VicP71]
hawkmaneg Offline
Loc: utah , usa
I have ordered and recieved the new intake manifold and will be installing it next week because of a plug that fouled due to coolant #8 , I thought it could be a leak in the manifold also , I replaced the filter 2 weeks ago . Idleing is pretty smooth with just a little hesitation sometimes but not much , Thanks for the input !
#1446480 - 04/10/08 11:14 AM Re: PO171 code [Re: hawkmaneg]
98VicP71 Offline
13.97@99MPH
Loc: ATL
I would try to drive as little as possible as a lean condition can damage the engine. But once you get the intake swapped out clear your codes and see if your problem goes away.
9 registered (BigKev, bobb, BigMerc96, GoldPanther, BLFW, 2007CrownVic), 98 Guests and 84 Spiders online.
a_d_a_m 227
BigMerc96 140
EZlivin11 103
Chaplian 99
RF_Overlord 96
dpk 94
Ezbok58a 87
Ponyguy 85
SocalSam 83
