#1451409 - 04/16/08 12:21 PM The starter is a PAIN to replace.
RWDForever Offline
Loc: Mercedes Stadium
Pray that your's does not die.
After 4 hours I replaced the GM's starter with 172K miles on it. For anyone attempting this...you HAVE to buy two 3/8 inch flex extension connectors for your socket extensions to flex around frame and engine components. AND you will need a variety of lengths of extensions to make a snake that will go around the motor mount and A/C compressor to do that 3rd inside-most bolt next to the block.
Without the flex connectors I could not get a straight extension to fit and attach a rachet to it to get the bolt off.
I had to play with different lengths and placement of the flex joints to finally get it to work to remove the bolts. My total length to do that inside-close to the block 3rd bolt was an extension about 2 feet long using both flex connectors.
I hope the newer 2003+ models with the redesigned front frame is better than this design.
FYI: I took the old starter apart and the seals had gone bad and let dirt inside, all the brushes and contacts were fine but grit had done too much damage to the rest of the starter.
1995 GM/LS -- 364K miles, engine rebuilt in my garage at 310K miles, 3rd plastic intake, 4th steering box, 2nd front suspension rebuild. MODS:1998 transmission, 1996 PCM, 1996 engine/trans wiring harness spliced in. A/C compressor cutoff dash switch, leather seats recovered with NOS cloth, dash switch for heater core shutoff valve. HPP springs installed front, police springs installed rear. 1997 steering box upgrade. My clearcoat is peeling off.
1992 Taurus LX -- 108k miles, added transmission cooler. Rear heavy duty springs.
#1451420 - 04/16/08 12:44 PM Re: The starter is a PAIN to replace. [Re: RWDForever]
theredlineboss Offline
Loc: Taylor, MI
Did you attempt to remove the solenoid before removing the starter? Removing that makes the procedure go quite a bit faster.
Rob
1996 Police Interceptor-Glory days are over frown - old specs below **216K miles**; Moved to a stock '97 Vic...sold to my brother **184K miles**
Engine: '03 4.6 w/ underdrives, shorties, custom downpipes, MZT, 70MM T/B, ADTR ported plenum, & Dyno Tuned.
Trans: Y2K 4r70w w/ J-mod, Spiral Lock clip, '04 Marauder TC, and an Econoline trans cooler.
Suspension/steering/brakes: '02 PI steering box, 17" 'stang wheels, '95 ABS master cyl., ADDCO bars, and Big Brake Upgrade!
Misc: '98+ Heated mirrors, 2-tone Gray interior, 98+ gauges, oil cooler-delete, and LX Sport console w/ floor shift!
#1451836 - 04/16/08 09:46 PM Re: The starter is a PAIN to replace. [Re: theredlineboss]
Sepiroth Offline
Loc: Kouts, Indiana
I dont know why so many people have such a b!tch of a time with starters on these mod motors. On average, it takes me less that a half hour to swap them out.
#1451840 - 04/16/08 09:48 PM Re: The starter is a PAIN to replace. [Re: Sepiroth]
Fordiesel69 Offline
Loc: Erie, PA
I opt to remove the A/C compressor and just move it off to the side. No need to disconnect or discharge.
-'14 Fusion S - 160K
#1451867 - 04/16/08 10:21 PM Re: The starter is a PAIN to replace. [Re: Fordiesel69]
DuceAnAHalf Offline
Loc: Pinellas Park, Fl.
i did the starter on my 97 in about 30 minutes. luckilly it had been done before and whoever did it did not reinstall the third bolt
#1451942 - 04/16/08 11:23 PM Re: The starter is a PAIN to replace. [Re: DuceAnAHalf]
kustomizingkid Offline
Loc: Minnesota
I also don't understand people issues, mine took 15 out 15 in.
2000 CVPI 121,000 miles
#1451953 - 04/16/08 11:32 PM Re: The starter is a PAIN to replace. [Re: RWDForever]
MarkLamport Offline
Loc: Peculiar, Missouri
It comes out easy with a 1/4 inch rachet with extention, no need for u joint. I have changed them on CV, GM, and TC with no problem. Good luck
2005 Crown Victoria LX Sport
#1451959 - 04/16/08 11:43 PM Re: The starter is a PAIN to replace. [Re: MarkLamport]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
AAAAAAAARRRRRRRRRGGGGGGGGGGHHHHHHH the 3rd bolt...Its about as useful as a 3rd eye. On your forehead.
The Jmod video is done! LINK!
#1452038 - 04/17/08 01:21 AM Re: The starter is a PAIN to replace. [Re: Rizzo]
SteelCityMarquis Offline
Fomerly 93MGMGS
Loc: Pittsburgh Area
Did you reinstall the third bolt?
2002 Mercury Grand Marquis LS. - 80k GF's Daily Driver
1991 Honda Accord LX Wagon 5 Speed - 258k My Daily Driver
1980 Oldsmobile Delta 88 Royal Diesel - 96k
#1452040 - 04/17/08 01:25 AM Re: The starter is a PAIN to replace. [Re: SteelCityMarquis]
Dan The Vic Man Offline
Loc: Coon Rapids MN
In did when i did mine \:\) now i get to do a motor swap soon and have a 3rd bolt on the starter to look forward too.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1452832 - 04/18/08 12:12 AM Re: The starter is a PAIN to replace. [Re: Dan The Vic Man]
Fomerly 93MGMGS
Only two for me
#1454219 - 04/19/08 09:01 PM Re: The starter is a PAIN to replace. [Re: SteelCityMarquis]
keith96p71 Offline
for me it wasnt the third bolt.. my f150 had that same starter. it was trying to find the right angle to slide it out of there.
Edited by keith96p71 (04/19/08 09:03 PM)
#1454389 - 04/20/08 03:27 AM Re: The starter is a PAIN to replace. [Re: keith96p71]
FunkRider Offline
Loc: Whitecourt, Alberta, Canada
Nothing like my 03 with the updated frame and suspension for a quick 5 minute starter change. ha
2008 GMC Sierra Crew Cab 2500HD 6.0 SLT Z71
1970 Chrysler Newport Cordoba 2dr hardtop 383-727-8.75
1970 Chrysler Newport Base 4dr Sedan 383-727-8.75
#1454837 - 04/20/08 08:23 PM Re: The starter is a PAIN to replace. [Re: FunkRider]
Eagle_Keeper Offline
Loc: massachusetts USA
I got a stupid "Snake Driver" screwdriver handle, 1/4" dr. flex shaft Taiwan thing from my mother-in law 4 yrs. ago for x-mas. After collecting dust since then-I finally had the light go on in my gourd to try and use it. Ten minutes later the frigging starter was out and in my hot little hands for a bendix spring replacement....go figger.....The screw driver handle and flex shaft worked great after I got the top bolt started coming out with my Snap-on 1/4" ratchet and numerous extensions. same on putting it in....
#1641906 - 12/18/08 04:11 PM Re: The starter is a PAIN to replace. [Re: Eagle_Keeper]
Great_Wun Offline
Loc: Central Florida
If I was to use the extensions to remove the bolts, do I still have to remove the a/c compressor to get the extensions through? Its been 2 hours and im still stuck on the second bolt.
2 registered (Old_Guy_Stu, D_nor), 76 Guests and 30 Spiders online.
