#1453116 - 04/18/08 12:46 PM
Re: Ok Exhaust Truth or Dare?
[Re: JCG1]
Cougrrcj
All Panther, all the time!!!
Loc: N.E. Ohio
First off, what year Vic are we talking - Box or Aero/Whale?
On my '89 BxVic 351W-VV, I went with BBK shorty headers, 2-1/4" Mustang H-pipe with hi-flow cats, custom bent 2-1/4" midpipes, true 2-1/4" core DynoMax Super Turbo mufflers (they even use the stock hangers), and custom bent 2-1/4" tailpipes ending with a factory-type angled turndown...
Sounded nice and deep even with the 351, and I can't wait to hear it with the new 393 stroker motor!
If I did it again, I would have gone 2-1/2" back to the mufflers, and 2-1/4" tails...
 89 Crown Vic LX - daily driver - 393 stroker/ WR-AOD!!!
#1453135 - 04/18/08 01:09 PM
[Re: Cougrrcj]
JCG1
Loc: Chicago
I presumed 4.6/modular, obviously none of what I wrote applies to a proper small block, which can indeed be made to sound quite nice!
Former Ford Projects: 1967 Mustang w/transplant 351W : 1984 302 T-Bird : 1987 5.0 T-Bird : 1989 5.0 Mustang : 1992 5.0 T-Bird : Current: 2000 CVPIRenegade Racing 4.6 SOHC: Cobra Crank, Manley Rods, Coated Diamond Pistons 10.5:1 comp w/valve reliefs, PnP npi heads, PI intake, Comp Cams, 70mm TB, MM Airbox/80mmMAF/04 Zip, 190lph walbro, FRPP shortys, custom 2.25 duals, Xcal2, Jmod RoadmasterTranz, Dirtyd0g TC. 14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive Watch a 14.58 @ 94.13 Vid by DJChicago HERE
#1453143 - 04/18/08 01:15 PM
[Re: JCG1]
98VicP71
223 RWHP/ 257 RWTQ
Loc: ATL
I love the sound of my vic with 40 series flow masters. I also have turn downs at the mufflers. the mufflers are 2 1/2" inlet and outlet.
I don't get any raspy sound and the drone is not really that bad. There is some if the car shifts into OD at like 35-40MPH but I tend to just lock OD out unless I am going above 45.
I get compliments all the time on my exhaust sound and am always getting asked questions about it.
"Today is the tomorrow that you worried about yesterday!" 01 CVPI, (Count Blackula)155k mi, 3:73w/T-Lok w/Carbon Clutch upgrade, Typhoon intake, BBK 75MM TB, ADTR P&P plenum, Steeda 1/4" Spacer, HiTech Stage II Cams, MZT w/Dyno Tune 93, 22c plugs, 180* T-Stat, TRE 255LPH Fuel Pump, Custom 2.5" Madrel exhuast w/single spun cats, Magnaflow mufflers, Blacked out rear, JMOD, Steeda Underdrives, Scanguage II, Custom Gauges, and 35% tint all around. (11/07/09) 14.88@90.036MPH 4180#'s R/T .032
#1453156 - 04/18/08 01:39 PM
[Re: 98VicP71]
hotrodjcc
Sir Speedsalot
Loc: Ennis, TX, also Dubai U.A.E
I'm hearing good things on the cherry bomb vortex mufflers. borla is too expensive and Im doubting the 25hp difference. unless the swap was from a 3 chamber rv muffler to a borla xr1. I have seen the reverse, my buddys current mod saleen went from borlas to flows. When it gets finished we will dyno and see whats going on, maybe slip on the old borlas. Problem is everyone has "preferences".
#1453163 - 04/18/08 01:51 PM
[Re: hotrodjcc]
Mario
Loc: Los Atzlan
I'm hearing good things on the cherry bomb vortex mufflers. Ditto. Quite the rage 'round here with foug bangers and short exhausts. I imagine the principle will also work on real full bodied cars but haven't seen nor heard one yet.
Big American Cars are the Envy of the World
#1453243 - 04/18/08 04:37 PM
[Re: Mario]
JaxRhapsody
Loc: L-Ville,KY
Thats what I plan to run, a cherrybomb system.
#1453248 - 04/18/08 04:41 PM
[Re: JaxRhapsody]
hotrodjcc
Sir Speedsalot
I think i wish i had. I paid 400 to the muffler shop for 2 40s and larger 2 1/4 pipes with h pipe. Want to change to x pipe when i install headers.
#1453296 - 04/18/08 05:53 PM
[Re: ubervic]
hotrodjcc
Sir Speedsalot
oh yeah i forgot when they did my setup they removed my rear resonators. I forgot all about that
#1453879 - 04/19/08 11:32 AM
[Re: hotrodjcc]
03slickvic
Loc: greenacres ,florida
i am going to run spintech mufflers with moroso resonators.
Aluminum mach1 short block, forged 17cc dished pistons, AMS rods, 8 bolt crank, patroit stage 2 heads, com cams 270, MMR oil pump & 9q pan,kooks long tubes, typhoon intake, 75mm throttle body, built trans, 2500 stall converter, sct programmer, 39lb injectors = N/A 291RWHP & 301 RWTQ
#1454213 - 04/19/08 08:44 PM
[Re: 03slickvic]
Beast
Loc: tennessee
I currently have flow masters, as ive had them since I first got my car, but i sure plan to get rid of them shortly, although it sounds good. Im going to try dynomax
http://www.dynomax.com/products/ultrafloweld.html
here is a vid a while back of how my car sounds.
Edited by Beast (04/19/08 08:46 PM)
#1454250 - 04/19/08 10:26 PM
[Re: JCG1]
sharpeusn
Loc: Lemoore, CA
Thound quality kinda sucks on this one but this is what I want but with a little less rasp and just a LITTLE more subtle. What is the sound difference if I just put dumps before the axle vs. some MM style tips where the original tips were?
http://videos.streetfire.net/Player.aspx?fileid=655C83ED-0836-4956-BEE9-BDD7D033DC08
#1454542 - 04/20/08 12:05 PM
[Re: 02fastvic]
luv-my-2002-p71
Loc: Itchycoo park
okay guys yall are talking about all these different types of mufflers... I would find out if there fully stainless steel or has a good coating on them that will last you.. those cherrybomb ones ten to rust quite fast and those spin tech mufflers sound like it has a freaking exhaust leak lol. Oh and about headers. yes it improves the sound but not much at all really unless you get long tubes. the only thing headers do really for the sound is that if you want to hear it more in the engine comparment.
I feel my setup is very good, and I'd recommend it to others. It's quiet driving and at idle, zero drone. Link in sig
 Got an 03 Marauder with 45K - Very nice indeed -- 14.0250 @ 97.99 with all mods below  FRPP 3.73's - Trick Flow Girdle - Reinhart Trak-Lok with CF clutches - Alcoa MMC Driveshaft Amsoil 75W-110 Gear oil - PML Deep sand cast pan - Magnafine inline ATF Filter - TR6 Plugs - Motorcraft Severe Duty Pads & Rotors - GMS Ropes - EMP Stewart Pump - SG II - Fed Sig CHMSL - Command Auto Rear Rotors - KarKraft plenum spacer - Self installed: 9.5" PI 2800 Triple Disc & Newer Transmission - Tuned by Lonnie at BOC - Genuine FoMoCo Remote Starter with keyless entry 2002 P71 - gone but not forgotten!
#1456617 - 04/22/08 07:18 PM
[Re: 03slickvic]
DodgeRider
Formerly 2004CVPIDave
Loc: Kansas City
The extra length in our exhaust systems enhances the raspiness. When I had flowmaster 40s with an x pipe and it was dumped... well that was just grand! But I'd say stick to some quieter mufflers with the X if you want to avoid raspiness.
Real men do it in 4 doors! - 1991 Suzuki Katana 750 (Cyan/Magenta) - 21K - 748cc, 13,000RPM 2006 F150 SuperCab 4x4 (Black) - 55K - 5.4L 3V, 3.73 LSD, Chrome Pkg 2005 Chebby Malibu (2.2L) - 65K - Lady's Car (Mods: RainX, Winter Washer Fluid, Anco Wipers)
Moderator: JohnG, dRock96Marquis, Liquid
The Tire Decision Guide
