#1473215 - 05/14/08 01:18 PM Rear defrost switch stopped working?
null Offline
Loc: Ontario, Canada
went to turn on my rear window defrost switch this morning it doesnt seem to turn on (doesnt light up, and it doesnt heat up the back window)
anyone know whats wrong?
04 Crown Vic p71
#1473271 - 05/14/08 02:29 PM Re: Rear defrost switch stopped working? [Re: null]
LTDteether Offline
Check the fuse
check the switch
Check the relay in the battery junction box
check the wires in between
IIRC, the switch directs the LCM to turn energize the defroster relay which in turn powers the defroster and heated mirrors. The dash switch grounds a pin on the LCM. Since the neither the light or heat works, I say switch, relay, fuse or wiring in between these. Hope it is not the LCM.
Do you have heated mirrors? If yes, do they heat up?
'99 GM GS HPP.
#1473287 - 05/14/08 02:38 PM Re: Rear defrost switch stopped working? [Re: LTDteether]
null Offline
i do have heated mirrors, i havnt checked them yet, but its like the button isnt working, but ill check in a bit
btw have any idea what fuse it is?.....wonder if my haynes manual has any info
04 Crown Vic p71
#1473320 - 05/14/08 03:32 PM Re: Rear defrost switch stopped working? [Re: null]
null Offline
well it seems that the fuses located in the drivers side are ok
any idea how i get at the switch? do i have to take the dash apart?
Edited by null (05/14/08 03:35 PM)
04 Crown Vic p71
#1473328 - 05/14/08 03:43 PM Re: Rear defrost switch stopped working? [Re: null]
bjorkmae Offline
Loc: Chicago Area, IL
Look at the trim around the dash, it wraps around the driver's side of the dash towards the door jamb, its about 10 inches wide and 2 inches tall. Grasp the trim on the edge towards the door jamb and pry it off. Its as simple as that. No screws. Easy to take off easy to put on.
Sold:
SUPERCHARGED 1998 CVPI with 2001 5.4 PI swap, V2 S-trim Vortech @ 8PSI, 2.5" duals with X-pipe & a lot of other goodies.
#1473364 - 05/14/08 04:35 PM Re: Rear defrost switch stopped working? [Re: bjorkmae]
null Offline
ok well i popped off the trim, popped off the defroster switch (it just didnt wanna come out) and tested the voltage in the metal inserts
they read 12.80ish volts, so that seems ok, i still dont know whats up its getting power...
Edited by null (05/14/08 04:35 PM)
04 Crown Vic p71
#1473559 - 05/14/08 08:39 PM Re: Rear defrost switch stopped working? [Re: null]
victor152 Offline
Loc: Oklahoma
On my 2005 CVPI, the Central Junction Box only provides the power to the coil of the Rear Window Defrost Relay. The actual power to make the element hot, the mirrors hot and the switch lamps light up is provided from the Battery Junction Box. On the 2005 CVPI it is fuse F1.107 (40 amp). The switch only turns on the relay. The relay powers everything else.
#1474167 - 05/15/08 02:48 PM Re: Rear defrost switch stopped working? [Re: null]
LTDteether Offline
If it is the switch that is bad, and you ground the correct wire leading to the LCM from the switch, you should get the light to come on and the defroster to work.
If you don't have an owner manual to look up fuses, download one at https://www.fleet.ford.com/maintenance/maintenance.asp
Edited by LTDteether (05/15/08 02:50 PM)
'99 GM GS HPP.
#1474242 - 05/15/08 04:09 PM Re: Rear defrost switch stopped working? [Re: LTDteether]
null Offline
ive check all the fuses, they're ok even the high voltage ones in the engine compartment the relays seem ok too
so i dunno =/
04 Crown Vic p71
#1474897 - 05/16/08 11:00 AM Re: Rear defrost switch stopped working? [Re: null]
victor152 Offline
Loc: Oklahoma
Time to do some voltage measurements.
#1484348 - 05/27/08 03:09 PM Re: Rear defrost switch stopped working? [Re: victor152]
null Offline
update: got a new defroster button from the wreckers, plugged it in and.....
still nothing...
bah
04 Crown Vic p71
#1484949 - 05/28/08 07:40 AM Re: Rear defrost switch stopped working? [Re: null]
victor152 Offline
Loc: Oklahoma
Time to measure and see if you are getting voltage at the rear window.
Moderator:  BigMerc96, Quasar
8 registered (09P71VIC, DudeAbides, a_d_a_m, hyoomen, garndreadz, 1 invisible), 307 Guests and 8 Spiders online.
BigMerc96 141
a_d_a_m 139
dpk 129
Ponyguy 91
Moby_Vic 81
charlieD 79
RF_Overlord 71
SocalSam 65
Bellwestern80 53
EZlivin11 52
