#1489108 - 06/03/08 09:36 AM Fuel Leak At Fuel-Fill-Tube-To-Tank Joint
CarMon Offline
Loc: Southwest Florida
97 CV (Aero); 62,000mi; HPP
Filling the fuel tank today I noticed a stream of fuel flowing out of the joint where the fill tube meets the tank.
Is this common, and how hard is it to fix that (I assume some sort of seal needs replacement).
Thanks in advance.
#1489132 - 06/03/08 10:15 AM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
Ask_The_Shack Offline
Loc: Long Island, NY
I'd say track down exactly where the leak is, and go buck wild with the JB weld.
I had a small vapor leak that a shop smoke-tested to that same tube. It cost me around $300~ to get it fixed.
The Blue Falcon
Car pics located here
Fog light pics located here
Find out how to paint your grille here
#1489632 - 06/03/08 09:17 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: Ask_The_Shack]
CarMon Offline
Good idea; thanks.
#1489736 - 06/03/08 11:33 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
TrickedVic Offline
Loc: Hollywood,FL
i have the same problem with my 04 marauder. let me know how that j/b weld works out for you! thanks.
<a href="http://s44.photobucket.com/albums/f46/onelioperez/Marauder/?action=viewĄt=Marauder012.jpg" target="_blank"><img src="http://i44.photobucket.com/albums/f46/onelioperez/Marauder/Marauder012.jpg" border="0" alt="Photobucket"></a>
<a href="http://s44.photobucket.com/albums/f46/onelioperez/?action=view&current=CIMG1832.jpg" target="_blank"><img src="http://i44.photobucket.com/albums/f46/onelioperez/CIMG1832.jpg" border="0" alt="Photobucket"></a>
#1491100 - 06/05/08 08:37 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: TrickedVic]
CarMon Offline
If possible I'd like to find a replacement seal and do it myself. I'll start calling around soon to find the part (s).
#1491130 - 06/05/08 09:03 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
Dan The Vic Man Offline
Loc: Coon Rapids MN
The rubber seal that is on the take hole is broken, i acidently broke mine when i did a fuel pump job and i had to drop the tank again to replace the seal, its like $8 from ford, thats if im thinking your problem was the same as mine.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1491310 - 06/06/08 01:29 AM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: Dan The Vic Man]
Ruski Offline
Loc: California
My 01 crown vic got the same thing, i cant fill up more than half a tank or else it will leak, but i came to a conclusion thats its the rubber o ring that goes in between the fuel pump and the tank that is leaking
heres what i need and maybe your the same way
http://www.autozone.com/R,APP1317834/veh...oductDetail.htm
If your leak when you fill up then you have a diffrent problem, if your does not leak untill you reach more than half a tank then you will need to drop the tank, which is not eazy and then remove the fuel pump then you can replace that rubber thing, i have no idea why they go bad, but i know for a fact that mines is craked.
#1491561 - 06/06/08 12:56 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
BillyRay Offline
Loc: Alabama
I would drop the tank, the filler tube goes a good 8-10 inches inside the tank, it might not be that seal that is leaking.
I had to driop mine 2 months ago when I accidentally drilled a hole in it whiole mounting subs in the tunk. Dropping the tank is easy, getting it back in there is a royal pain in the a$$.
If it isn't empty hook up a hose to the fuel pump out put and hot wire the fuel pump and pump all the gas out. Either pump it into a can or another vehicle, or if you aren't environmentally conscious just pump it on to the ground.
To drop it jack up the rear and put it on jack stands, put a jack under the tank. Follow the instructions to disconnect the wires, fuel lines and filler tube, straps and then it drops right out. If you already have it empty it comes out in about 20-30 minutes.
I would highly recommend getting new tank mounting bolts from Ford to put it back in. I didn't get them and it took me about 5 hours to get those freaking straps on.
#1494193 - 06/10/08 09:37 AM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: BillyRay]
CarMon Offline
I nearly filled the tank yesterday again, (about 2 gal shy of "full"), and fuel still streamed out all the way home and in my driveway. "Dollars on the ground."
@Billy
Holy sheis, Pump it into the ground! But I do appreciate the advice on how to get the fuel out of the tank. Is your CV an Aero or Whale? Mine is an Aero and it seems, based on what I can see, that I won't have to drop the tank (I hope) but I am not sure.
I called Ford this morning and the "Filler Neck Seal" is $41.35 Part # F4ZZ9072DA .
Thanks for the advice so far everyone.
#1495066 - 06/11/08 12:56 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
CarMon Offline
Anybody know where I can get a cheaper "after market" replacement gas filler neck seal equivalent to
Ford part # F4ZZ9072DA?
I can get one from thefordsource.com (Ford deal in the north)$25 + $11 shipping = $36.
Or, I'll just have to bite the bullet on this one.
Also, the service tech. I spoke with at thefordsource.com said the tank will NOT have to be dropped. Just unbolt the filler neck and move it to gain access.
Thanks!
#1503726 - 06/23/08 09:24 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
CarMon Offline
Update for anyone interested.
I purchased the replacement gas filler neck seal and received it today. Then I installed it.
Here are some pictures of the new seal, and before and after pictures:
Project: Stop Fuel Leak Where Fill Neck Meets Fuel Tank
After inspecting the old seal, it appears to be in excellent shape. Interestingly, it had a thin layer of gray rubbery sealant of some sort on the bottom of it, where the leak was. I am not convinced that the replacement seal I installed today is going to solve the problem. I will fill the fuel tank soon and test. But I believe I will need to find some sort of gas-resistant goop to surround and seal the union between the tank and the outter portion of the new rubber fuel fill neck seal. We'll see.
#1504048 - 06/24/08 11:16 AM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
CarMon Offline
Update
I filled the fuel tank as full as possible today, and to my surprise there was no leaking from the new seal whatsoever, even after driving 20 miles.
#2683655 - 03/18/13 01:27 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
iMotoPilot Offline
Loc: Texas
Awesome write up! I just noticed the same leak from my CVPI today. Ordering part today.
Thank you!
Beer is proof that God wants us to be happy. ~Benjamin F.
#2686081 - 03/23/13 11:53 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
iMotoPilot Offline
Loc: Texas
Just finished my repair on my 2000 CVPI, there was a hard plastic spacer behind hanger of the filler tube before it feeds into the the rubber gasket into the tank. Made it difficult to remove the filler tube so I had to cut it slightly to remove it. Finished the gasket replacement and reinstalled the spacer. Will check in if any issues.
#2693052 - 04/07/13 12:32 PM Re: Fuel Leak At Fuel-Fill-Tube-To-Tank Joint [Re: CarMon]
iMotoPilot Offline
Loc: Texas
Wanted to add that this repair also got rid of the check engine light issue I had. Trouble code pointed towards the gas cap but the tube to tank seal was the culprit. All is well again.
NM117 335
Moby_Vic 147
BigMerc96 121
Ezbok58a 116
Chaplian 116
RF_Overlord 115
EZlivin11 115
a_d_a_m 96
mdnos 96
Ponyguy 93
