#1496110 - 06/12/08 07:50 PM NGK plugs, or Autolite Double Plats in an '04 P71?
Virginiamountainman Offline
Loc: North Carolina
I tried a search for NGK, and got nothing back. Is there anything to be gained by using NGK iridiums instead of Autolite Double Plats? If so, could someone please give me a part number for the standard heat range, and a good source? Also, can you set the gap on NGKs, and, if so, is the gap still .044?
Thanks,
VMM
#1496160 - 06/12/08 09:16 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Virginiamountainman]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
44 WTF...Your about 10 short dude.
IIRC its .052-.056 So shoot for .054
The Jmod video is done! LINK!
#1496163 - 06/12/08 09:22 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Rizzo]
Loc: North Carolina
OOPS. You're right. My mistake.
#1496185 - 06/12/08 09:48 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Virginiamountainman]
Fordiesel69 Offline
Loc: Erie, PA
Both are excellent, I use the double plats with great success.
-'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 174K
-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 130K / 3427 Hrs
-'07 F-150 4x4 - Extended Cab, 3.55's, White w/ Grey interior, 124K
#1496191 - 06/12/08 10:10 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Fordiesel69]
kustomizingkid Offline
Loc: Minnesota
NGK FTW!
2000 CVPI 121,000 miles
#1496305 - 06/13/08 12:44 AM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Virginiamountainman]
harpster Offline
Loc: from the BannedLands
Ummmm, anything to be gained by using NGK iridiums?
NO !!
Except maybe a lighter wallet !!
This is one of those "can 'o worms" qustions on this site, bro.
But for my money, and I have a kid in college, it's either Motorcraft or Autolite in any FoMoCo product.
1996 MGM GS
#1496355 - 06/13/08 02:24 AM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Virginiamountainman]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
http://www.ngksparkplugs.com/part_finder/car_truck_suv/
2004 FORD CROWN VICTORIA 4.6 V8 W FI Plugs - SOHC
Spark Plug Part No. Stock No. Plug Gap Photo
V-Power TR55 3951 .054
G-Power TR55GP 3403 .054
Laser Platinum PTR5F-11 * 6579 .054
OE Laser Iridium ITR5F13 ^ 6044 .054 n/a
Iridium IX TR55IX 7164 .054
* “Laser Series” Platinum center electrode, and Platinum pad ground electrode
Oxygen Sensor Part No. Location Note Photo
Oxygen Sensor 22060 Upstream Left n/a
Oxygen Sensor 22060 Upstream Right n/a
Oxygen Sensor 22004 Downstream Left n/a
Oxygen Sensor 22004 Downstream Right n/a
#1496580 - 06/13/08 01:40 PM Re: NGK plugs, or Autolite Double Plats in an '04 [Re: Virginiamountainman]
LTDteether Offline
autolite/motorcraft irridium or platinum
'99 GM GS HPP.
#1497715 - 06/15/08 03:01 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: Virginiamountainman]
gord_bolton Offline
"Is there anything to be gained by using NGK iridiums instead of Autolite Double Plats?"
I just changed the plugs on my 03 Windstar van. Last changed fall of 07. I have put on a little over 100K on the van since last fall.
I used autolite iridium extreme performance plugs on the firewall side because it is a major operation to get to the plugs on the inside.
I used autolite double platinums on the radiator side.
Long story short--iridium plugs showed no visible or measurable sign of wear. Double platinums were virtually missing the center electrode.
The van now has new iridiums all the way around.
I have never seen a panther totally eat the center electrode but non the less on a side to side comparison the iridium was the way to go on the windstar.
BTW even with the center electrode worn right down there was no misfire registered. I will tell you later if there is a big improvement in fuel economy.
My knuckles look like they went 5 rounds in the cage.
#1497826 - 06/15/08 05:06 PM Re: NGK plugs, or Autolite Double Plats in an '04 P71? [Re: gord_bolton]
Fordiesel69 Offline
Loc: Erie, PA
Iridiums will last longer, but with our modulars, you don't "set it and forget it". You should religiously check your spark plug torque anyways at least every 30k.
So what if you only get 60k optimal use out of double plats. Technically if you gap to the lower number, at 100k you should be right at the highest number which will still be in spec.
6 registered (Tenevic_P71, MGDriver, Kitsuna, H3LlIoN, 2 invisible), 84 Guests and 93 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
