#1358853 - 01/01/08 06:26 PM oil cooler o-rings leaking
tomtuna Offline
my 2000 p71 is leaking oil at the oil cooler line o-rings,the leak is not bad enuff to spend the 150$ for the new lines the dealer wants to sell me. my question is can i just get the o-rings? i really dont want to buy the lines,they arnt leaking,its just the o-rings. anny help would be apricated.
#1358905 - 01/01/08 07:29 PM Re: oil cooler o-rings leaking [Re: tomtuna]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
#1359024 - 01/01/08 09:50 PM Re: oil cooler o-rings leaking [Re: Quickvic30]
tomtuna Offline
thanks quickvic !!!!! ill spend 25 bucks on them... thats a hole lot better.
#1359097 - 01/01/08 11:03 PM Re: oil cooler o-rings leaking [Re: tomtuna]
Quickvic30 Offline
Just watchin
your welcome \:\)
CVN also has a site disount number you can enter and get another 5% off. I think thats what it is \:\)
#1359176 - 01/02/08 12:08 AM Re: oil cooler o-rings leaking [Re: Quickvic30]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
The "O" rings are part # YF-2958
#1359184 - 01/02/08 12:13 AM Re: oil cooler o-rings leaking [Re: gord_bolton]
vicfan_00 Offline
Loc: Quad Cities,IL
Just replaced my lines with the ones from rock auto last month... no problems so far.
http://www.supermotors.net/17311
2000 CVPI 118K miles (6/2013). Steeda UDs,EMP Water Pump,Ported Plenum,FRPP 70MM TB,PI Intake,
PI cams,180 stat,NGK TR6IX Iridiums,3500 stall converter from Darrin,Dual Trans Coolers,
J-Mod,MMX Driveshaft,3.55 with T-lok,Full Magnaflow Exhaust,Marauder Cluster,
Console with floor shift. 14.9 with no tune.SOLD 11/14
Living vicariously through brothers 93 and 03
Currently in the garage- 2011 edge, 62 t-bird.
#1359187 - 01/02/08 12:16 AM Re: oil cooler o-rings leaking [Re: vicfan_00]
kustomizingkid Offline
Loc: Minnesota
I just put Dorman lines in my car after the oem ones took a major crap on me. So far I'm completly leak free.
2000 CVPI 121,000 miles
#1504086 - 06/24/08 12:47 PM Re: oil cooler o-rings leaking [Re: gord_bolton]
gm95 Offline
Hi gord_bolton
YF2958 O-ring is also for 1996 crowvic ?
#1504369 - 06/24/08 09:02 PM Re: oil cooler o-rings leaking [Re: gm95]
Da Governator
Considering how cheap the replacement lines are (under $30) I'm not sure if it's worth replacing the o-rings, as the next place to fail will be the crimps. Personally I'd feel better with all new lines.
RIP 2vmodular
#1504372 - 06/24/08 09:04 PM Re: oil cooler o-rings leaking [Re: gm95]
Da Governator
Oops, didn't notice how old this thread was LOL
 Originally Posted By: gm95
Hi gord_bolton
Probably, BUT, in my notes I have a different number listed for the 95-97 lines: YF-2371, which is a 6 pack. There are two seals on each end of each hose.
BTW gm95, if you decide to replace your lines as well there is one catch - the Dorman lines do not have the correct fittings on one end for -97s, which use spring locks at the adapter side. The opposite end spring lock can be removed from the adapter leaving you with 1/2" NPT female threads. Your local Napa, or a hydraulic shop can then crimp on 1/2" NPT fittings in place of the Dorman 98+ line pinch bolt/o-ring setup so you can thread them into your adapter (Though I don't know how much they'd charge you)
Make sure they are swivel style so the hoses don't have to rotate to tighten
RIP 2vmodular
#1504378 - 06/24/08 09:14 PM Re: oil cooler o-rings leaking [Re: dRock96Marquis]
Da Governator
Found the write-up I wanted to show you, gm95:
http://www.crownvic.net/ubbthreads/ubbth...rue#Post1160074
RIP 2vmodular
#1504428 - 06/24/08 11:08 PM Re: oil cooler o-rings leaking [Re: dRock96Marquis]
MrEvil Offline
Loc: Austin TX
I have the same problem on my '98. Will I have to drain the pan to change the oil cooler lines? Or are they pretty much dry when the engine's been stopped?
1998 Ford CVPI formerly an unmarked for the Potter County TX Sheriff's department
2012 Ford F150 XLT 2x4 with Ecoboost
1966 Ford Thunderbird
1961 Ford F100
#1504464 - 06/24/08 11:44 PM Re: oil cooler o-rings leaking [Re: MrEvil]
Da Governator
You don't have to drain the pan, but there will be some oil in the lines and cooler.
I'd highly recommend to change the oil and filter at the same time though, in case anything got in (and it's cheap, easy and you're right there)
RIP 2vmodular
#1504517 - 06/25/08 02:20 AM Re: oil cooler o-rings leaking [Re: dRock96Marquis]
bjorkmae Offline
Loc: Chicago Area, IL
The old lines tend to harden up with age, so removing them to install new O-rings may cause the hoses to crack and leak. I also have the dorman hoses and I am happy with them too.
Sold:
SUPERCHARGED 1998 CVPI with 2001 5.4 PI swap, V2 S-trim Vortech @ 8PSI, 2.5" duals with X-pipe & a lot of other goodies.
#1505682 - 06/26/08 04:14 PM Re: oil cooler o-rings leaking [Re: dRock96Marquis]
gm95 Offline
Thinks for the all replies. I just bought this car. The oil pressure is low (4 PM ) Then I try pull the oil sender and cannot reach it except taking out the cooler hose. There is some oil on the hose and do not know if it leaks. Thus I thought buy some new oil rings to install after took the hose off. After read post about low oil pressure post, I know the sender is on/off switch and my oil pressure is above 6 psi regardless where is needle. After reading oil cooler hose problem, I decide I do not do anything right now because it is not easy task to do with cooler hose such as new one, U shape bypass or delete the cooler.I think it might be cheap solution to custom made rubber bypass hose made by hydralic shop if I can locate one.
10 registered (Jay_08_SAP, Jacksknight, 502vic, JaxRhapsody, casey67, ChrisM_NY, 3 invisible), 79 Guests and 83 Spiders online.
Moby_Vic 182
a_d_a_m 153
BigMerc96 137
EZlivin11 106
Chaplian 104
White99MGM 98
charlieD 93
RF_Overlord 87
DudeAbides 81
SocalSam 76
