#1579272 - 10/08/08 05:18 PM Lower Ball-joint Replacement?
Logix7 Offline
Loc: West of Chicago
Tried searching on here as well google.
Can anybody offer any information as how to replace a Lower Ball Joint (92-97)?
Thanks
#1579291 - 10/08/08 05:43 PM Re: Lower Ball-joint Replacement? [Re: Logix7]
troyco Offline
Loc: Ontario, Canada
it needs to be pressed out, something that's better done in a shop. takes less than an hour. i did mine with a ball joint press tool and torches. or you can buy the whole lower control arm complete with a new ball joint AND bushings and fix it yourself in your driveway, whichever is easier for you.
1996 Mercury Grand Marquis GS
UPCOMING MODS:
Snow tires and an oil change.
#1579417 - 10/08/08 08:11 PM Re: Lower Ball-joint Replacement? [Re: troyco]
Logix7 Offline
Well I planned on renting/buying the balljoint press to do the job myself.
I'm looking for specifics as to how to go about doing it.
#1579483 - 10/08/08 09:58 PM Re: Lower Ball-joint Replacement? [Re: Logix7]
DeadHeadP71 Offline
Loc: Indianapolis, IN
Jack stand under frame, jack under lower ball joint. Raise to unload the ball joint, undo from knuckle. SLOWLY, SLOWLY, SLOWLY lower the jack to unload the spring and remove. Undo control arm bolts, and press out the old one.
Edited by DeadHeadP71 (10/09/08 01:34 AM)
BF Goodrich Control Plus
#1580531 - 10/10/08 01:34 PM Re: Lower Ball-joint Replacement? [Re: DeadHeadP71]
mblazakep Offline
Insert Title Here
This will work but I wanted to add a few things.
You need to first remove the shock.
When you go to remove the LBJ from the knuckle loosen the nut but do not remove it completely. Leave about a half inch gap between the bottom of the nut and the knuckle. This will let you separate the BJ from the knuckle with a hammer but the nut will keep the control arm and spring from flying. After the BJ is seperated you can jack the control arm up, remove the nut completely and follow the above instructions.
Doing any spring work with a jack is very dangerous (I'm not saying don't do it, just be careful). The safest way to remove the spring is with an internal spring compressor.
I would also recommend running a chain through the spring and around the frame just as a precaution while you lower the jack.
#1580594 - 10/10/08 03:21 PM Re: Lower Ball-joint Replacement? [Re: mblazakep]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Or do like my buddy...Listen to me tell you its the Lower ball joint....DONT FIX IT...Let it drop the control arm unexpectedly.
That was actually very easy to fix for him.
Would you believe me if I told you it dropped in the parking spot in front of his Apt !
God favors the foolish.
The Jmod video is done! LINK!
#1580609 - 10/10/08 03:52 PM Re: Lower Ball-joint Replacement? [Re: Rizzo]
Logix7 Offline
Would you believe me if I told you that I had my Driver side lower break on me while going over train-tracks?
.scary.
#1580611 - 10/10/08 03:56 PM Re: Lower Ball-joint Replacement? [Re: Logix7]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
OH WOW
#1580618 - 10/10/08 04:11 PM Re: Lower Ball-joint Replacement? [Re: Rizzo]
mblazakep Offline
Insert Title Here
This thread sounds like an episode of Get Smart.
#1580665 - 10/10/08 05:56 PM Re: Lower Ball-joint Replacement? [Re: mblazakep]
DeadHeadP71 Offline
Those "on car" spring compressors are not safe in my opinion. I have seen them 'bannana' backwards and let the spring go. Very scary. It would be safer to put a jack stand under the lower ball joint, then jack up the frame to release the spring tension slowly.
#1582427 - 10/12/08 09:19 PM Re: Lower Ball-joint Replacement? [Re: DeadHeadP71]
logan126 Offline
Loc: Jefferson, Ga
^^^agreed. Although when I replaced both on my car, I did not remove the spring. I used a bottle jack to raise then lower the control arm and used a ball joint press from Auto Zone to remove the BJ.
'93 cvlx P74 240k+(not sure anymore. odo quit working a while back..)
dual exhaust
headlight relay upgrade
Moderator:  BigMerc96, Liquid
6 registered (Tenevic_P71, H3LlIoN, albertaglen, 3 invisible), 87 Guests and 88 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
