#1586900 - 10/17/08 10:55 PM Differences between Alpine Audiophile and Standard
Carter Offline
Loc: Michigan
I know that the Alpine Audiophile System comes with a sub, but are the other speakers (in the door, and in the rear deck) different too?
Current Cars: 2015 Chevrolet Impala LTZ LZ2 V6, 2006 Mercury Grand Marquis LS Ultimate Edition
Former Cars: 2012 Chevrolet Impala LT, 2003 Mercury Grand Marquis GS
EATC Repair Video: https://www.youtube.com/watch?v=5IsDs-N1mvE
#1586925 - 10/17/08 11:20 PM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Da Governator
The Alpine-audiophile system was never offered in the CV/GM, only the Town Car and a variation in the Marauder.
They still used only 4 speakers (front doors and parcel shelf), and the subwoofer which is essentially the same as the old JBL system subwoofer found in the equipped aero panthers. The speakers are better than the base system, but you're way better off with a quality aftermarket one.
RIP 2vmodular
#1587016 - 10/18/08 01:17 AM Re: Differences between Alpine Audiophile and Stan [Re: dRock96Marquis]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
+1 for less money and easier installation you can insall an aftermarket system with 4 new speakers and subwoofer and amplifiers with a better sound.
Id do that instead of trying to retrofit a wire crazy OEM system.
2002 CV P73
#1587272 - 10/18/08 12:38 PM Re: Differences between Alpine Audiophile and Stan [Re: coldfusion11]
TheDriver959 Offline
Loc: Oshawa, ON
If you DID want to install the Audiophile system, for OEM sake, the Town Car's system will NOT work. The head unit uses SCP Databus to determine dimming and lighting, and the subwoofer physically will NOT fit into position on the CV/GM package tray. You will need to find one from a Marauder. Or just locate the JBL sub from an Aero; it'll be about as difficult.
2004 Ford Crown Victoria Police Interceptor
LX Sport Console & Floor Shifter, Gentex Electrochromic Mirror w/compass, Marauder Cluster, Speed Control w/leather wheel, LED turn signals, HID headlights (projectors coming), EATC (DIY, in progress), Marauder corners, Rewired DRL, Rewired turn signals, Maraudered headlights, Grille Mounted Driving Lights, Bullitt Wheels, Pirelli Tires and a Custom Ram Air System. More to come!
#1587349 - 10/18/08 03:44 PM Re: Differences between Alpine Audiophile and Stan [Re: TheDriver959]
Carter Offline
Loc: Michigan
I got got a Audiophile Set from a marauder. That should go in nicely? The only reason is that I wanted the sub box, cause eventually I am going to get bostons to put in there.
#1587445 - 10/18/08 06:17 PM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Loc: Oshawa, ON
Physically, it will all bolt right in. Wiring is the only big concern.
#1587676 - 10/18/08 11:58 PM Re: Differences between Alpine Audiophile and Stan [Re: TheDriver959]
Carter Offline
Loc: Michigan
whats the difference in wiring? I have the sub prewired, thats it right?
#1587799 - 10/19/08 09:11 AM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Da Governator
You GS is probably not wired for the sub, but you can take a look.
It's the only un-used connector clipped to the middle back of the rear seat frame. It's 6 pin.
Also, since you have a base model you MAY have the standard 16pin radio connector. The MM, like all upper model 03+, use the new 24 pin connector
http://www.p71interceptor.com/radio/
You will also have AT LEAST 2 plugs at the radio if it was pre-wired for the sub.
The radio sub connector is 8 pin.
Aside from the radio connector itself, the wiring to the 4 speakers is the same. All 98+ radios are internally amplified, no external inline amps like the old -96 JBL systems.
RIP 2vmodular
#1587947 - 10/19/08 02:31 PM Re: Differences between Alpine Audiophile and Stan [Re: dRock96Marquis]
Carter Offline
Loc: Michigan
I have the 6 Pin in the trunk, for the sub, (found that stuffed behind my backseat) and at my Radio I have the 24, 16, and 8 pin, all connected to my radio. Which is stange it being a base model.
#1588214 - 10/19/08 07:39 PM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Da Governator
Then you're good to go ;\)
Your radio may not have the sub output enabled. If that's the case the MM radio is a direct swap and does have the output. Seeing as you already had the harnesses and they were plugged in - I imagine the radio will work fine.
RIP 2vmodular
#1588514 - 10/20/08 03:18 AM Re: Differences between Alpine Audiophile and Stan [Re: dRock96Marquis]
Carter Offline
Loc: Michigan
I will let you guys know when it gets installed along with the pics. Thanks Derek.
In addition, it is also coming with an alpine head unit, looks exactly like mine, except it has the DSP button shared with RDS
#1592043 - 10/23/08 05:52 PM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Carter Offline
Loc: Michigan
it looks like the Speakers are no different between the alpine and standard speakers, am I correct?
#1594227 - 10/26/08 02:15 AM Re: Differences between Alpine Audiophile and Stan [Re: Carter]
Carter Offline
Loc: Michigan
Ok, got the system installed, after I found the non-connected ground, what a big job, pull the entire backseat out, connected the ground, then connected the sub, everything went well and really makes a difference in sound quality. I know that some of you out there like a bigger punch, but I think the factory sub does that for you. I find it real wierd, my car being a base model, came with the sub wiring, but not the cd-changer wiring.
Another question comes to mind, why didn't they hook up the ground for the sub?
For anyone that's looking to do a swap, the sub will not work, unless you have a Audiophile Head-unit or someone knows how to enable subwoofer on the standard cd/cass head unit.
10 registered (gearmaker, Flashburn, DES, Car_54, garndreadz, 1 invisible), 58 Guests and 81 Spiders online.
Moby_Vic 194
a_d_a_m 159
BigMerc96 136
Chaplian 113
EZlivin11 111
White99MGM 106
charlieD 96
DudeAbides 92
RF_Overlord 84
SocalSam 79
