#1589385 - 10/20/08 09:34 PM
Turbocharging
LincolnLuxury
Squires Turbo Systems claims to have a remote mounted turbocharging kit that will work on any car. Anyone know what the cost would be install this system on our Panther vehicles?
http://www.ststurbo.com/ http://www.ststurbo.com/universal_system
#1589616 - 10/21/08 01:39 AM
Re: Turbocharging
[Re: LincolnLuxury]
m_j
if its priced like all their other kits then the answer is "way higher then it should be"
#1589752 - 10/21/08 08:17 AM
Re: Turbocharging
[Re: m_j]
03slickvic
Loc: greenacres ,florida
i built a universal sts kit installed and running on my 03 for $3490.00.....it made just under 400rwhp and 420 lbs of torque on 12 psi....ran a best of 12.4 at 110 with a 1.89 60 foot on DR's..
Aluminum mach 1 short block, forged 17cc dished pistons, AMS rods, 8 bolt crank, patroit stage 2 heads, comp cams 270, MMR oil pump & 9q pan,kooks long tubes,ported typhoon intake, 75mm throttle body, built trans, 2500 stall converter, sct programmer, 39lb injectors = N/A 283RWHP & 265 RWTQ
#1590466 - 10/21/08 09:30 PM
Re: Turbocharging
[Re: 05cvpi]
Quickvic30
Vic N/A king & n2o king ;)
Loc: Coon Rapids MN
even though i've seen it already its still
#1590672 - 10/22/08 12:58 AM
Re: Turbocharging
[Re: Quickvic30]
LincolnLuxury
How does it work without a manifold? If I buy that kit for my Town Car, how do I install it (I'm new to turbocharging)/What mods need to be made?
#1590731 - 10/22/08 04:35 AM
Re: Turbocharging
[Re: 46time]
watchurstep
Loc: Georiga
is that on the stock block? what size turbo are you using?
#1590765 - 10/22/08 09:03 AM
Re: Turbocharging
[Re: watchurstep]
03slickvic
is that on the stock block? what size turbo are you using? yep,stock motor and trans.....the turbo is a t-60 with sts's own exhuast turbin design,the exhaust side is a .81 AR....just keep to boost under 10psi and you will be fine...
#1590772 - 10/22/08 09:10 AM
Re: Turbocharging
[Re: 03slickvic]
03slickvic
here's some pics of the $200 exhuast system i had made up for the turbo kit...lol thats right no mufflers! who needs them?! the car sounded really good without them....
#1591049 - 10/22/08 03:35 PM
Re: Turbocharging
[Re: 03slickvic]
watchurstep
Loc: Georiga
tight work, any videos?
#1591139 - 10/22/08 05:30 PM
Re: Turbocharging
[Re: watchurstep]
03slickvic
http://videos.streetfire.net/video/turbo-crown-vic-95-psi_124046.htm http://videos.streetfire.net/video/another-short-romp-in-sts_124422.htm http://videos.streetfire.net/video/short-romp-in-sts-turbo_124047.htm
#1591168 - 10/22/08 05:59 PM
Re: Turbocharging
[Re: 03slickvic]
interceptor09
Loc: Just this side of Hell
Is there more delay in the time it takes for the turbo to spool up since there is a lot more air to get moving in the pipes between the turbo and the engine.
It's still a bada$$ setup though. Want to trade?
Edited by interceptor09 (10/22/08 06:01 PM)
Moderator: JohnG, dRock96Marquis, Liquid
The Tire Decision Guide
