Page 1 of 3 123>
#1589385 - 10/20/08 09:34 PM Turbocharging
LincolnLuxury Offline
Squires Turbo Systems claims to have a remote mounted turbocharging kit that will work on any car. Anyone know what the cost would be install this system on our Panther vehicles?
http://www.ststurbo.com/
http://www.ststurbo.com/universal_system
#1589616 - 10/21/08 01:39 AM Re: Turbocharging [Re: LincolnLuxury]
m_j Offline
if its priced like all their other kits then the answer is "way higher then it should be"
#1589752 - 10/21/08 08:17 AM Re: Turbocharging [Re: m_j]
03slickvic Offline
Loc: greenacres ,florida
i built a universal sts kit installed and running on my 03 for $3490.00.....it made just under 400rwhp and 420 lbs of torque on 12 psi....ran a best of 12.4 at 110 with a 1.89 60 foot on DR's..
Aluminum mach 1 short block, forged 17cc dished pistons, AMS rods, 8 bolt crank, patroit stage 2 heads, comp cams 270, MMR oil pump & 9q pan,kooks long tubes,ported typhoon intake, 75mm throttle body, built trans, 2500 stall converter, sct programmer, 39lb injectors = N/A 283RWHP & 265 RWTQ
#1590420 - 10/21/08 08:55 PM Re: Turbocharging [Re: 03slickvic]
46time Offline
Loc: FLA
Nice Vic! I wish I had the time and equiptment to make my own kit. The main thing I like about remote kits is the ability to run a turbo without having to build a turbo manifold.
*1995 Crown Victoria P74 - P71 dual exhaust pipes, Magnaflow SS mufflers (14" body), P71 aluminum driveshaft.
#1590428 - 10/21/08 09:05 PM Re: Turbocharging [Re: 46time]
05cvpi Offline
Loc: minnesota
thats awesome mang, looks good
2005 P71
ex. Greenfieid Wisconsin Detective unit #104
#1590466 - 10/21/08 09:30 PM Re: Turbocharging [Re: 05cvpi]
Quickvic30 Offline
Vic N/A king & n2o king ;)
Loc: Coon Rapids MN
even though i've seen it already its still
http://www.youtube.com/watch?v=Yy5RLPNyPBM
http://www.youtube.com/watch?v=i7hSSgeKc1c
Zex wet kit forsale, PM me if your interested
#1590672 - 10/22/08 12:58 AM Re: Turbocharging [Re: Quickvic30]
How does it work without a manifold? If I buy that kit for my Town Car, how do I install it (I'm new to turbocharging)/What mods need to be made?
#1590686 - 10/22/08 01:25 AM Re: Turbocharging [Re: LincolnLuxury]
46time Offline
Loc: FLA
Normal turbo setups have the turbo scavaging directly from the exhaust manifold(s). In the type of setup above, the turbo is mounted at the rear of the exhaust system(after the exhaust manifolds). There's a lot you should know about turbos.
Read this: http://auto.howstuffworks.com/turbo.htm
And this: http://ststurbo.com/f_a_q_
#1590731 - 10/22/08 04:35 AM Re: Turbocharging [Re: 46time]
watchurstep Offline
Loc: Georiga
is that on the stock block? what size turbo are you using?
#1590765 - 10/22/08 09:03 AM Re: Turbocharging [Re: watchurstep]
03slickvic Offline
yep,stock motor and trans.....the turbo is a t-60 with sts's own exhuast turbin design,the exhaust side is a .81 AR....just keep to boost under 10psi and you will be fine...
#1590772 - 10/22/08 09:10 AM Re: Turbocharging [Re: 03slickvic]
03slickvic Offline
here's some pics of the $200 exhuast system i had made up for the turbo kit...lol thats right no mufflers! who needs them?! the car sounded really good without them....
#1591049 - 10/22/08 03:35 PM Re: Turbocharging [Re: 03slickvic]
watchurstep Offline
Loc: Georiga
tight work, any videos?
#1591139 - 10/22/08 05:30 PM Re: Turbocharging [Re: watchurstep]
03slickvic Offline
http://videos.streetfire.net/video/turbo-crown-vic-95-psi_124046.htm
http://videos.streetfire.net/video/another-short-romp-in-sts_124422.htm
http://videos.streetfire.net/video/short-romp-in-sts-turbo_124047.htm
#1591168 - 10/22/08 05:59 PM Re: Turbocharging [Re: 03slickvic]
interceptor09 Offline
Loc: Just this side of Hell
Is there more delay in the time it takes for the turbo to spool up since there is a lot more air to get moving in the pipes between the turbo and the engine.
It's still a bada$$ setup though. Want to trade?
Edited by interceptor09 (10/22/08 06:01 PM)
A Jrizzo-mod
Dumped GT500 Mufflers with a rear-cat delete
OEM GT500 Wheels and tires
GT500 Mufflers Exhaust Vid: http://www.youtube.com/watch?v=2mUcVjUEjoU
#1591396 - 10/22/08 10:38 PM Re: Turbocharging [Re: interceptor09]
46time Offline
Loc: FLA
Those videos were nice. What size piping is that? I'm surprised the stock block and trans can handle all that power.
Page 1 of 3 123>
Moderator:  JohnG, dRock96Marquis, Liquid
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
8 registered (Land_Shark, whitela3, u538, GeeMarKee, Flippy328, WSTRLNG, 2 invisible) and 76 anonymous users online.
Amazon!
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
