#1619554 - 11/21/08 07:17 PM I swapped pcm's and now my car will won't start
46time Offline
Loc: Florida
Would a 1997 pcm not work in a 1995?
I put a 97 p71 pcm in my car and it wouldn't start. I put my 95 pcm back in and the car still wouldn't start. Then, after disconnecting the battery and messing with the pcm and harness, I started. I shut the car off and started it up 3 more times to be sure. I then tried the 97 pcm again and it wouldn't start the car. Once again, I put the 95 pcm back in and the car didn't start. I'm done for tonight, it's getting cold. I'll be back on it tomorrow morning.
Also, does the pcm harness "snap" into the pcm? Mine just slides into the pcm. It seemed like it locked into place when I did get the car to start with the 95 pcm that one time. It didn't do that on all the other attempts.
Any help is appreciated.
SOLD. 2008 P71. 19" 2014 Mustang GT optional wheels, J-Mod, chambered mufflers, Town Car seats, LSE console/floor shifter, steering wheel controls, and other premium interior upgrades, headlamp blackout, projector retrofit, Marauder corners, remote window control, spotlight delete, color matched trim.
1994 Roadmaster. Impala SS springs, 20" Staggered wheels, FX-R projector retrofit + LED angle eyes, self-cleared lenses, 2.5" Aerochamber catback, shaved body parts, PCM tune, etc.
#1619578 - 11/21/08 07:56 PM Re: I swapped pcm's and now my car will won't start [Re: 46time]
JohnG Offline
Tech Admin
Loc: Socialist state of MN
No, a '97 PCM will not work in a '95 car.
The 104 pin connector is retained by a 10mm bolt, it does NOT "snap in" to place.
#1619589 - 11/21/08 08:21 PM Re: I swapped pcm's and now my car will won't start [Re: JohnG]
46time Offline
Loc: Florida
Okay, thanks. I have no idea why my original pcm didn't start the car. I will look into that in the morning.
#1619697 - 11/21/08 11:20 PM Re: I swapped pcm's and now my car will won't start [Re: 46time]
Da Governator
97 PCM can't be used.
As for the '95 no longer working, probably a connection issue.
Check for bent pins.
RIP 2vmodular
#1619882 - 11/22/08 05:27 AM Re: I swapped pcm's and now my car will won't start [Re: dRock96Marquis]
mustang_zulu Offline
I am not
Loc: Garland, TX
yea i did the swap but got a 98 P71 PCM. try to find one of the same year. then u should be good to go... u should like the upgrade too... well worth it if you dont got the $$$ for a Lonnie tune \:\)
#1620621 - 11/23/08 01:42 AM Re: I swapped pcm's and now my car will won't start [Re: mustang_zulu]
46time Offline
Loc: Florida
I went to the car this morning and it started right up. It seemed like the 97 pcm caused a relay or something to shut down. When I went back to the original pcm right after, it wouldn't start. After letting the car sit for some time, it started.
I will get the xcal one of these days. I have a Marauder airbox and maf collecting dust. I'm going to make an intake tube for it because I really dislike the 95 air tube.
#1620667 - 11/23/08 06:50 AM Re: I swapped pcm's and now my car will won't start [Re: 46time]
I am not
Loc: Garland, TX
do u have a way to buy a P71 PCM from your year car? u should not have to pay more than like $50 for it... i love mine \:\)
#1621006 - 11/23/08 05:01 PM Re: I swapped pcm's and now my car will won't start [Re: mustang_zulu]
ford05 Offline
Loc: New Jersey
it has to be the same year pcm. I did the swap on my car from a 2000 lx to a 1999 p71 and it worked great.
(BOC tune for 93 octane/3.73 gears/shift points for j-mod and Marauder MAF sensor) sunroof,ported & polished factory DBW TB and Plenum, 1" TB spacer and 1/2" plenum spacer, rear cat delet with 14" magnaflow mufflers and 3.5" rolled edge tips, custom gauges from Scott Hrbacek at www.customgaugefaces.com, LED interior bulbs, reverse and brake light bulbs, custom SPORT decal for 3rd brake light with led bulb, JLT cone filter, 06 p71 intake tube, 5% tints, 09 200amp alternator, Marauder front and rear swaybar and moog links, turn signal mod, glowshift rpm and volt gauge, motive cross and drilled front/rear rotors with ceramic pads, steeda underdrive pullys, crystal clear headlights and corners and complete interior changed from light flint to dark charcoal/midnight black with a very loud sound system
coming mods:
2.5" exhaust waiting to be installed
#1626217 - 11/29/08 02:58 PM Re: I swapped pcm's and now my car will won't start [Re: mustang_zulu]
46time Offline
Loc: Florida
I just found one but I haven't gotten it yet.
4 registered (Tenevic_P71, 3 invisible), 83 Guests and 89 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
