#1623001 - 11/25/08 07:08 PM Motor Oil Capacity
cfrank Offline
Loc: North Florida
Being these P71's have oil coolers does that increase the oil capacity or is it still the normal 5 quarts with filter?
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1623010 - 11/25/08 07:14 PM Re: Motor Oil Capacity [Re: cfrank]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
I always buy 6 and have one to top off and then save that for the next lawn mower oil change
The Jmod video is done! LINK!
#1623054 - 11/25/08 07:48 PM Re: Motor Oil Capacity [Re: Rizzo]
Panther71 Offline
Loc: New Mexico
Ford says 5 quarts with filter..........
2000 P71 Former Ridgecrest,CA PD Captains Unit -- 125K -- P71 Pic in link below...
http://4.bp.blogspot.com/_M4HMCCz1jm8/SUVu1QY70iI/AAAAAAAAAAU/iMXwNDv8eGk/s1600-h/DSC_0028.JPG
#1623080 - 11/25/08 08:05 PM Re: Motor Oil Capacity [Re: Panther71]
mustang_zulu Offline
I am not
Loc: Garland, TX
x2, and with them selling oil in those 5 quart jugs makes it easy for us \:\)
#1623087 - 11/25/08 08:10 PM Re: Motor Oil Capacity [Re: mustang_zulu]
cfrank Offline
Loc: North Florida
Well, it makes sense. But it is still kind of hard to believe that the same car without oil cooler would still hold the same amount so how big is the oil cooler/how much does it hold?
#1623116 - 11/25/08 08:32 PM Re: Motor Oil Capacity [Re: cfrank]
99vicnerd Offline
Loc: NA
actually, i looked up how much they hold before i did my first oil change in my 99 p71. Some site said they held 7 quarts, but I am thinking when you drain the pan out, you aren't draining the cooler, so its prolly still holding a good quart in itself.
#1623132 - 11/25/08 08:39 PM Re: Motor Oil Capacity [Re: 99vicnerd]
Da Governator
A lot of the oil in the cooler lines and cooler will remain. Even if you did drain them out you wouldn't get as much as you'd expect.
Definitely don't dump in 7 quarts!
If you have an oil cooler (p71, Tow) expect to use ~5.25 for -'02 and ~6.25 for '03+
Non oil cooler cars - 5 quarts -02, 6 quarts 03+
RIP 2vmodular
#1623166 - 11/25/08 09:05 PM Re: Motor Oil Capacity [Re: dRock96Marquis]
99vicnerd Offline
Loc: NA
I didn't use 7, i used 5. There was just some site that said 6-7 or something.
#1623295 - 11/25/08 10:31 PM Re: Motor Oil Capacity [Re: 99vicnerd]
Fordiesel69 Offline
Loc: Erie, PA
I always let my oil stop dripping which usually take 30 minutes unless it is a hot summer day. EVERY P71 I owned took 5.5 to reach the full mark. On the 04 I had, it took 6.5 to hit the full mark. If you just drain and fill quickly and don;t wait for it to stop dripping, then maybe 5 would be fine.
-'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 179K
-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 132K / 3427 Hrs
-'05 F-150 4x4 - Extended Cab, 3.55's, Dark Blue w/ Grey interior, 221K
#1626156 - 11/29/08 01:07 PM Re: Motor Oil Capacity [Re: dRock96Marquis]
R03 Offline
Loc: Land of the Free.
Hold on, can you please clarify this for me.
I might be reading this wrong.
6.25 quarts for 03+ non oil cooler equipped.
5 quarts for 02- oil cooler equipped.
6 quarts for 03+ oil cooler equipped.
Claudine.
2006 / P71 / 150,000km
#1626160 - 11/29/08 01:15 PM Re: Motor Oil Capacity [Re: R03]
flyboy Offline
Ret US Army Medic
Loc: Chillicothe, Mo
My 04 Sport & the 04 LTC both use only 6 qts. Never had experience with oil cooler.
#1626396 - 11/29/08 07:46 PM Re: Motor Oil Capacity [Re: flyboy]
ford05 Offline
Loc: New Jersey
I USE 6 QTS
(BOC tune for 93 octane/3.73 gears/shift points for j-mod and Marauder MAF sensor) sunroof,ported & polished factory DBW TB and Plenum, 1" TB spacer and 1/2" plenum spacer, rear cat delet with 14" magnaflow mufflers and 3.5" rolled edge tips, custom gauges from Scott Hrbacek at www.customgaugefaces.com, LED interior bulbs, reverse and brake light bulbs, custom SPORT decal for 3rd brake light with led bulb, JLT cone filter, 06 p71 intake tube, 5% tints, 09 200amp alternator, Marauder front and rear swaybar and moog links, turn signal mod, glowshift rpm and volt gauge, motive cross and drilled front/rear rotors with ceramic pads, steeda underdrive pullys, crystal clear headlights and corners and complete interior changed from light flint to dark charcoal/midnight black with a very loud sound system
coming mods:
2.5" exhaust waiting to be installed
#1626504 - 11/29/08 11:34 PM Re: Motor Oil Capacity [Re: ford05]
Fordiesel69 Offline
Loc: Erie, PA
Keep it simple.
Police cars:
98-02 takes 5.5
03-08 takes 6.5
And if I am off by 0.25, no problem. The oil pan has a shield welded into it to prevent the crank from splashing the oil.
This is what it takes to get mine exactly on the full mark. I have owned enough to know it is not a miscalibrated dipstick. However I do let mine drain a long to get as much old out as possible.
#1626514 - 11/30/08 12:06 AM Re: Motor Oil Capacity [Re: Fordiesel69]
KSPEED Offline
Loc: Kansas
Oops. I put in 6 last time! Dipstick looked okay...
2001 P71 SAP -- More Stuff Click!
#2262817 - 03/20/11 09:31 PM Re: Motor Oil Capacity [Re: cfrank]
Steveo989 Offline
Loc: Minnesota
I think the best course of action is to buy (2) five-quart jugs of your choice oil. Dump 5 quarts in, start it up, check for leaks, drop the car, and then top off to desired amount. It's always going to be a slightly different amount.
The important part is making sure you get enough oil in the crankcase so it won't run dry then you can always top it off to spec.
I always like filling it up as high on the hashes as it goes. I think the extra capacity helps to absorb heat due to the increased oil volume, I am pretty sure it makes a difference.
2005 Ford Crown Victoria 130,000 Engine:G-Oil 5w-30 w/ Purolator Pureone, Rear Diff. Valvoline Synpower 75w-140, Transmission Valvoline Mercon V.
1999 Ford Crown Vic 125,000 Engine: Mobil 1 5w-30 w/ Wix, Rear Diff Royal Purple 80w-90, Transmission OEM Motorcraft Mercon V.
2001 Dodge Intrepid 134,000 Engine Valvoline Nextgen 10w-30 w/ Purolator Pureone.
11 registered (pintobean, KayTar, Nick_03_p71, hischuckness, Ltd4all, HarrisonCreek, 1 invisible), 77 Guests and 14 Spiders online.
a_d_a_m 189
Ezbok58a 165
BigMerc96 147
charlieD 146
Ponyguy 118
dpk 115
White99MGM 104
SocalSam 86
Moby_Vic 82
reminc70 70
