#1630014 - 12/03/08 06:25 PM P0420 Catalyst System Efficiency Below Threshold
Timmn1 Offline
Loc: Near I-80 & I-57
So, about 1200 miles after the installation of the Shark plenum, I get a CEL. I don't suppose I can blame that on the plenum.
I used my scanner to reset the light, but when it comes back, what should I try first, O2 sensors, cat, or both?
1997 Grand Marquis - Started out life as a rental car in Milwaukee.
Mods:
Functional oil pressure gauge
Shark Plenum + Aviator throttle body
Headlight wiring
"Life after death is as improbable as sex after marriage!"
#1630076 - 12/03/08 07:39 PM Re: P0420 Catalyst System Efficiency Below Threshold [Re: Timmn1]
TechnoWeenie Offline
Loc: UTL
Time to replace o2 sensors and cats
#1630086 - 12/03/08 07:47 PM Re: P0420 Catalyst System Efficiency Below Threshold [Re: TechnoWeenie]
Colt45 Offline
less is moreŠ
Loc: Moses Lake, Wa
Try O2s first, they are the cheapest and may be it if they have many miles on them.
-Colton
STRENGTH THROUGH HARMONY
HARMONY THROUGH FRIENDSHIP
EQUESTRIA PREVAILS
2004 Ford Crown Victoria LX - 65k "Tank"
#1630798 - 12/04/08 07:42 PM Re: P0420 Catalyst System Efficiency Below Threshold [Re: Colt45]
cfrank Offline
Loc: North Florida
X2, the o2 sensors are cheaper and with higher mileage they do go bad or at least get "slow". repalce the sensors, clear the code and go from there. But in my experience it is usually the cat. converters
Edited by cfrank (12/04/08 07:43 PM)
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1632629 - 12/07/08 01:53 PM Re: P0420 Catalyst System Efficiency Below Threshold [Re: cfrank]
Steve83 Offline
Blindly throwing part$ at a CEL is the least effective and most expensive thing you can do.
If the cat is bad, then the HO2S is GOOD because it's accurately reporting the problem. If the HO2S is bad (reporting a nonexistent fault), then cat is GOOD.
Find out what's actually WRONG before buying ANYTHING.
#1667434 - 01/19/09 10:25 AM Re: P0420 Catalyst System Efficiency Below Threshold [Re: Steve83]
craftsmanracer Offline
Loc: Englewood,Florida
I just got this code today, I had glasspacks installed about 3 hours ago, and I installed the shark plenum about a month ago.
Help!
1998 White Crown Victoria Police interceptor.
setina pb-400 push bar, 75mm throttle body, 45$ granatelli plenum,1/2 intake spacer, home-made cold air intake, 20%tint, cherrybomb glasspacks
Oh come on man. You got no lady fingers, fuzz buttles, snicker bombs, church burners, finger blasters, gut busters, zippity do das, or crap flappers?
No, I don't.
You're gonna stand there, owning a fireworks stand, and tell me you don't have no whistling bungholes, no spleen spliters, whisker biscuits, honkey lighters, hoosker doos, hoosker donts, cherry bombs, nipsy daisers, with or without the scooter stick, or one single whistling kitty chaser?
21 registered (Allaa_Hassan, Briglad, 808interceptor, 03RedVicSport, bobby58, 3 invisible), 69 Guests and 67 Spiders online.
KayTar 590
CNGInterceptor 389
sm41 353
BlackVic_P71 274
Black_Sunshine 273
Ezbok58a 268
BigMerc96 260
Moby_Vic 235
Superhobo 227
ajdereicup 225
