#1631362 - 12/05/08 03:43 PM 2003 Front Wheel Hub Bearing
koolaid6666 Offline
Loc: LI,NY
Is there a write how to change a front Wheel Hub Bearing on a 2003 crown victoria?
How do I pop it out I got all the Bolts Off I can't get it Out.
2007 Black P71
2003 Green p74
1991 Crown Victoria
1999 Green SAP-Part Car
#1631422 - 12/05/08 04:53 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Remove wheel.
Remove caliper.
Remove brake disk.
Remove dust cap.
Remove nut. 34mm socket I think.
Slide hub assembly out.
Slide new hub in.
Preferably install new nut to 250 ft.lbs torque.
install dust cap.
Clean contact surface on rotor with wire brush and reinstall.
reinstall caliper and wheel.
#1631524 - 12/05/08 07:06 PM Re: 2003 Front Wheel Hub Bearing [Re: gord_bolton]
koolaid6666 Offline
Loc: LI,NY
Oh Ok
I didn't see the 34mm Nut
I got all the other steps.I was banging on the thing to come out.
Thank You.
2007 Black P71
2003 Green p74
1991 Crown Victoria
#1631622 - 12/05/08 09:41 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
larryo340 Offline
Loc: Long Island
On '03 and up to remove the front hub and bearing assembly after removing the caliper w/bracket/brake rotor/disconnect the abs sensor/ you unbolt the four bolts from behind the knuckle to remove the assembly. Torque the bolts to 74 lb-ft on the new assembly.
(If after removing the four bolts, and it still won't come out spray some PB Blaster or penetrating oil and use the trusty BFH)
If you want a copy of the procedure from the Ford manual PM me your email. I can't attach it to a post here.
MOD List for MGM
...Marquis sold frown
#1631801 - 12/06/08 04:10 AM Re: 2003 Front Wheel Hub Bearing [Re: larryo340]
koolaid6666 Offline
Loc: LI,NY
I thought that.I didn't see any Big Nut To Take Off.
I'm going to pull everything apart again On Saturday And Try Again.
2007 Black P71
2003 Green p74
1991 Crown Victoria
#1632023 - 12/06/08 02:05 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
gord_bolton Offline
Sorry for the bum steer. I didn't know that they went to a different hub in 2003.
#1632096 - 12/06/08 03:44 PM Re: 2003 Front Wheel Hub Bearing [Re: gord_bolton]
koolaid6666 Offline
Loc: LI,NY
It's all good.
I can't get it out.
Bang on It and everything won't come Out.
2007 Black P71
2003 Green p74
1991 Crown Victoria
#1632159 - 12/06/08 05:24 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
Bangster Offline
Look at the new one, is it a friction fit? It sorta looks like it would be, so liberal amounts of PB Blaster or other penetrating oil might be needed.
looking at
it looks like it possibly is a machined fit.
1974 Honda cb400
#1632288 - 12/06/08 10:13 PM Re: 2003 Front Wheel Hub Bearing [Re: Bangster]
larryo340 Offline
Loc: Long Island
Let it soak overnight with PB Blaster as stated in mine and the above post. It couldn't hurt to heat the knuckle, but be careful anything you sprayed on the hub will burn. It might be easier to remove the outer tie-rod from the knuckle so you can move the knuckle more freely and swing away with a B.F.H. (Big F'in Hammer)
MOD List for MGM
#1632487 - 12/07/08 10:11 AM Re: 2003 Front Wheel Hub Bearing [Re: larryo340]
PKariher Offline
Loc: Durham, North Carolina
Maybe also try a prybar. Look at where the rust made the connection in my picture. I don't remember any real friction fit when I replaced mine. Just the four bolts holding it on.
2003 Crown Victoria LX
#1633335 - 12/08/08 11:30 AM Re: 2003 Front Wheel Hub Bearing [Re: PKariher]
mblazakep Offline
Insert Title Here
You can also buy some longer bolts of the same size that hold the hub on and hit them with the BFH to help get it out.
#2387172 - 10/11/11 06:40 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
RRPILOT Offline
Loc: Upstate NY
Well folks, I'm doing one of these on my '03 CVPI, been soaking the thing all day long and it still won't come out....all the bolts are out, never seen a part seized in like this, is the hub a tight fit into the knuckle?
#2387318 - 10/11/11 10:19 PM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
hellraiser319 Offline
Loc: Moline, IL
Big hammer and hit what it goes through. Penetrating oil would be useful in large quantites
Chris H.
03 CVPI & 96 Aspire, see fquick link for info
MECP Advanced - CEA170106 - Best Buy #0023 - Moline, IL
XBL, PSN, FB, FQuick, TCG = hellraiser319
#2387494 - 10/12/11 08:13 AM Re: 2003 Front Wheel Hub Bearing [Re: koolaid6666]
RRPILOT Offline
Loc: Upstate NY
Is the hub a very tight fit into the knuckle?...If I bang on it unevenly can it get jammed in?
#2387768 - 10/12/11 05:53 PM Re: 2003 Front Wheel Hub Bearing [Re: RRPILOT]
RRPILOT Offline
Loc: Upstate NY
Finally got it done, took some of the old heat and beat, all put back together, thanks for the advice guys!
Moderator:  BigMerc96, Liquid
8 registered (FordDriver, Handsome, H3LlIoN, albertaglen, 3 invisible), 86 Guests and 84 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
