#1631917 - 12/06/08 10:30 AM
Wipers not returning to park any help?
Loc: Massachusetts
When wipers are turned off on they stop mid windshield. if you turn them on and off quickly at some point they will go back in the normal off position. any advice what to try first?
#1632220 - 12/06/08 06:16 PM
Re: Wipers not returning to park any help?
[Re: Donnylaw]
Loc: Fraser Valley, BC
Welcome to CVN.  I have the same problem occasionally. The advice on here seems to be the problem is related to the multi-function switch. Do a search on it and you'll come up with lots of info. Also, to get better help, you should post info about your year and model.
 2011 Midnight Blue Pearl Charger Pursuit. 10k miles. Yeah it's got a Hemi. AND a Cabin Air Filter  Immaculate Harvest Gold '99 P73...Gone but not forgotten...
#1632849 - 12/07/08 06:02 PM
[Re: TrrR]
Loc: Erie, PA
Nope, most problems is the wiper motor itself. It is not servicable.
******Need your heater core replaced? Click Here****** -99' Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 155K-00' Crown Vic Police Interceptor (SAP), 3.55 (R2), Cloth Interior, Black PI Trunk Bezel, 03+ Full Wheel Covers, Silverstars, 109K-96' Lincoln Town Car - Executive Series, 3.08's, White w/ blue leather interior, 155K-99' Lincoln Town Car - Signature Series, 3.08's, Silver Frost Metallic, 94K
#1633425 - 12/08/08 12:19 PM
[Re: Fordiesel69]
I had to replace my wiper motor. Don't buy a cardone unit! I bought a doorman replacement and couldn't be happier.
#1637443 - 12/12/08 07:42 PM
[Re: fastsvo]
Loc: Massachusetts
thanks guys, im going to replace the motor this week. and appreciate the welcome
#1639838 - 12/16/08 02:51 AM
[Re: Donnylaw]
Loc: Near Manassas Va.
I had the same problem and after reading this site, bought a reman motor and replaced it. One problem I ran into was the passenger side crank had rotated 180 deg from its normal position. I took care of that and now my wipers work fine. There was a lot of leaf debris under the cover which I vacuumed out. it took me a while to go all this thought, I'm new at repairing my CVPI. I usually work on my Mercedes and the hood goes vertical and is much easier to repair windshield wipers etc. Maybe Ford can change the design to add that feature.
Thanks for the 'Body of Knowledge' forum.
2002 CV PI > 240K miles, 1989 MB 420SEL >250K miles, 1965 MB 220S ? miles, 1965 MB 220SEb ? Miles
#1639992 - 12/16/08 09:51 AM
[Re: W Bain]
Loc: Stadium District Tacoma
I have the same problem from time to time, either they don't park or they don't work at all from the not-parked position. All I've ever done is open the cover, clean out the leaves and junk that's built up (clogging the drain), and sprayed some WD40 on the mechanism. Works immediately every time.
2005 Jeep Grand Cherokee WK Hemi
#1646263 - 12/24/08 06:06 PM
[Re: Mainsail]
very urgent: if the wiper still in this state you described and no change happened till today that meanes you just need to clean the wiper motor's clutch from mud: 1-NEVER dont use the wiper AGAIN or else you will damage the clutch 2-remove the wiper motor fuse in driver side under steering (after disconnecting negative battery) 3-you need to clean and maintain the hole wiper system use BOTH following links as they sequenced: a- http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1426479#Post1426479b- http://www.supermotors.net/19772
Edited by vic1992LX (12/24/08 06:07 PM)
http://www.supermotors.net/users/vic1992LX @@IRAQ FREEDOM PANTHER@@ hello, my CVN name was "vic1992LX" and im dreaming to see america! 1998 crown vic P73, 120XXX miles, 180F tstat, AWSF22C plugs, 5w40 liqui moly high tech,2.73 conventional axle, , still working on it. she is rusting. Best thing i did is 235*17*60 tires with 17" 06 charger steelies. best in the world!
#1654932 - 01/05/09 03:06 PM
[Re: 01vicon3s]
#1654939 - 01/05/09 03:11 PM
[Re: 98P73_IRAQ]
GOOD advice If the Clutch mechanism is jamming then the wiper motor is drawing power the entire time the car is on. I would just shut the switch off when the wiper was near the lowest point and did not think much of it. A few weeks later...... The motor burst into flames!!!11!!
#1655604 - 01/06/09 09:52 AM
[Re: 01vicon3s]
Didnt realize that i had it on caps lock.lol funny picture! I see you have to have tough skin on this site!!! Noobs need proper hazing!! This is one of the NICER forums on CVN!!
