#1649798 - 12/30/08 01:23 AM PO173 & PO174
Tony Offline
Hello all,
I have '99 CVLX that starts hard in the cold and won't idle properly unless I keep giving it gas, it also runs a little messy after warm-up. The check engine light is on and returns codes PO173 & PO174 at autozone. Any help will be greatly appreciated.
#1649807 - 12/30/08 02:02 AM Re: PO173 & PO174 [Re: Tony]
TechnoWeenie Offline
Loc: The perimeter
disconnect the MAF sensor. If nothing changes, clean and/or replace the MAF sensor.
#1649871 - 12/30/08 08:04 AM Re: PO173 & PO174 [Re: TechnoWeenie]
Timmn1 Offline
Loc: Near I-80 & I-57
PO173 code: fuel trim bank 2, O2 (oxygen sensor) control limit
PO174 code: system too lean, bank 2
1997 Grand Marquis GS - Died
#1650300 - 12/30/08 07:15 PM Re: PO173 & PO174 [Re: Timmn1]
Tony Offline
Had it checked again today at checkers...gave me a code po171 & po174 this time...I'm cleaning the MAF today...
#1650622 - 12/31/08 01:07 AM Re: PO173 & PO174 [Re: Tony]
Loc: The perimeter
Also, if you haven't done them, replace the plugs and fuel filter.
#1651030 - 12/31/08 02:05 PM Re: PO173 & PO174 [Re: TechnoWeenie]
njstatepd03cv Offline
Loc: NJ
may need to get ur fuel tank cleaned... heres the bulliten from ford.. although it does show diffrent codes your having the same problem...
SERVICE BULLETIN:0322 NHTSA ITEM NUMBER:10002472
MFG Bulletin Date: 20030203
Component: ENGINE AND ENGINE COOLING:ENGINE
Bulletin Summary: STREAMLINED DIAGNOSTIC PROCEDURE FOR VEHICLES WITH MALFUNCTION INDICATOR LAMP (MIL) ON AND DIAGNOSTIC TROUBLE CODES (DTCS) P0401, P0402, P1400 OR P1401, OR RUNS ROUGH, LACKS POWER, SURGE, POOR FUEL ECONOMY, AND THE ABOVE LISTED DTCS WITHOUT
Sig removed. See rules.
