#1654362 - 01/04/09 11:26 PM
body lift
Loc: Tucson, AZ
thinking of lifting the vic 3 maybe 4 inches with a body lift and adding 30-31 inch tires has anyone ever done this?i have lifted trucks but not a car.this is not my daily driver any more and i take it into the desert alot riding dirt bikes and atvs im not wanting a mud bogger just more clearance
#1654375 - 01/04/09 11:37 PM
Re: body lift
[Re: broncoblues]
Loc: Pinellas Park, Fl.
GoodSamaritan lifted his, dont think he did a body lift. but you can fit 31's on the car with no body lift
#1654382 - 01/04/09 11:42 PM
Re: body lift
[Re: DuceAnAHalf]
Loc: Tucson, AZ
do you know where i could find a picture?
#1654728 - 01/05/09 01:16 PM
Re: body lift
[Re: broncoblues]
not sure, you could search for his username on here
#1659765 - 01/10/09 01:00 PM
Re: body lift
[Re: DuceAnAHalf]
u can use a STIFFER suspension setup police interceptors use this to lift there cruisers 1 inch but if u go real stiff i am only guessin u will get a higher lift. but thats my 2 cents man only tryin to help.
$Up3Rch@R3d Wr3NcH H3aD
#1660122 - 01/10/09 06:11 PM
Re: body lift
[Re: BiddieGibbs]
Loc: Tucson, AZ
i think mine is already lifted from the factory it is taller than the other vics ive seen
#1660149 - 01/10/09 06:32 PM
Re: body lift
[Re: broncoblues]
how about spacers. spacers compress the shocks but mine u that it does have long term disadvantages such as possible shock breakage. and ur ride quality will drop consiterabley
#1660160 - 01/10/09 06:39 PM
Re: body lift
[Re: BiddieGibbs]
Loc: Tucson, AZ
i havnt thought of spacers i wonder if i could go 3 or 4 inches?it would be easier than making new bumper brackets with the body lift,or maybe longer springs? f-150 or something
#1660368 - 01/10/09 09:48 PM
Re: body lift
[Re: 01vicon3s]
Loc: Tucson, AZ
what kind of spacers?the ones that twist into the spring or fit above it? thanks
#1660374 - 01/10/09 09:53 PM
Re: body lift
[Re: broncoblues]
Loc: Atlanta
just get f150 springs or do the spacers the springs would give you a smoother ride than the spacers, spacers can be found at auto zone for about 8bucks
"Stop Hating & Start Congratulating" 99 Crown Vic, Viper Red, 23"Davin Abyss, Projector Headlights w/LED eye brows, Floor Shifter, Custom Interior w/Driver Side Pillar gauges,Vertical/Horizontal Doors,Omega Max Motion detected alarm w/GPS tracking,Premium Sound
#1660387 - 01/10/09 10:06 PM
Re: body lift
[Re: 01vicon3s]
Loc: Atlanta
what kind of spacers?the ones that twist into the spring or fit above it? thanks The ones that twist into the springs are easier, I havent had any experience with the other ones. On my car I have a 2" lift on the back and 1.5 on the front with them. I could have went higher but I dont like alot of space between my tires and my fenders the ones you twist in its a cheap route but it works
#1660426 - 01/10/09 10:47 PM
Re: body lift
[Re: ViperRedVic]
Loc: Tucson, AZ
i found a 5 inch spacer kit at universal lift includes all 4 steel spacers for $100 do you guys think i would be able to get it aligned up right?
#1660428 - 01/10/09 10:51 PM
Re: body lift
[Re: broncoblues]
Loc: Stuntworld,USA
i found a 5 inch spacer kit at universal lift includes all 4 steel spacers for $100 do you guys think i would be able to get it aligned up right? I think that should do what you need it to do. I heard they have good kits, I dont see why not.
2001 p71
1 registered (RF_Overlord),
135
39
