#1687681 - 02/11/09 11:03 PM
Re: Turbo Interceptor project
[Re: 1_Man_Army]
Dan The Vic Man
I broke it
Loc: Coon Rapids MN
You could y pipe the single back into a dual exhaust if you wanted. I would probably add some resonators as well. I take it thats how the exhuast also goes from dual into one pipe into the turbo also huh. I would love to have a rear mount turbo and am pretty much stock with that option only because im not getting rid of my custom long tubes i just had made.
#1687951 - 02/12/09 09:26 AM
[Re: Dan The Vic Man]
AM_Dann
Loc: Downingtown, PA
Hey man, just sayin hi! Didn't know you were on here. This is 240sxdann from TST. I said it before, I'll say it again, awesome project.
 AmericanMuscle.com 1997 Crown Victoria LX 4.10's, SCT Tuned, and ghetto exhaust
#1688124 - 02/12/09 12:54 PM
[Re: AM_Dann]
BlownMerc
Loc: Carrsville, VA
Does look nice. For dual exhaust, you could run twin turbos Also, correct me if I'm wrong, but a BOV is on the intake side, to vent boost on closed throttle back to the intake side of the compressor. A waste gate is on the exhaust side. But I do agree, I would want it routed to the exhaust outlet. But I guess the fabrication would be a little more involved.
 98 Mercury GM--forged internals, PI heads, Allen Supercharger M90 355rwhp/430rwtq 12.87 @ 104.8  PI 3000 2000 F250 7.3L TDI oil burner 2008 Taurus X
#1688155 - 02/12/09 01:36 PM
[Re: BlownMerc]
bjorkmae
Loc: Troutdale, OR
Having actually installed turbos the blow off valve is designed for the extra air pumped into the charge pipes because the turbo has built up boost and the throttle had closed. The blow off valve vents the extra pressurized air to atmosphere so its easier on the turbo bearings and so that the turbo doesn't get slowed down as much by the pressurized air. That way it spins up more quickly when the gas pedal is pressed for the next gear. Venting the blow off valve to the exhaust is CRAZY. Now as far as sound I prefer venting the blow off valve to atmosphere directly and not into the intake tube. Also if you have a big enough turbo, venting the blow off valve into the intake tube before the turbo can cause tuning problems because it can actually blow air back out of the intake filter fooling the MAF and causing driveability problems. Been there done that. Waste gates bleed off extra exhaust gases so that the turbo doesn't produce too much boost, adjusting at what PSI the waste gate opens is how do set the boost that the turbo will produce. Venting the waste gate to atmosphere sounds like ass and I prefer that to be blown back into the exhaust after the turbo. Also an FYI a blow off valve is the name for valves that blow extra compressed air from the turbo to atmosphere and not into the intake tube before the turbo. A bypass valve is the same as a blow off valve except it blows the air back into the intake tube before the turbo.
SOLD: for $4400 I will miss it  SUPERCHARGED 1998 CVPI with 2001 5.4 PI swap, V2 S-trim Vortech @ 8PSI, 2.5" duals with X-pipe, Magnaflow mufflers and down pipes, ported TB & plenum, PI intake manifold, 2000 10k miles trans w/J-mod, AEM FPR w/gauge, 55lb low impedance injectors, LC-1 Wide band O2, XCal2 w/Pro-Racer software, KYB gas-adjusts, new upper & lower ball joints, new inner & outer tie rods, new steering box and pitman arm, rebuilt rear end w/locker, new alternator and starter, Sealed dry cell battery in the trunk, new external high performance fuel pump, 17" 06 GT wheels with 245/45/17 Blizzaks, Rear Fascia Tuck, tinted windows, new rear brakes, Sony Cd w/remote and HD radio, Marquis power seats, spot light. http://s412.photobucket.com/albums/pp202/bjorkmae/
#1688165 - 02/12/09 01:47 PM
[Re: bjorkmae]
JeffBoudah
Loc: Holland,MI
were you be running a BOV with a draw threw MAF? the compressed air being released to the atmosphere has been meetered already, no wonder you had tuning issues.
BOV before a blow-threw MAF... is the correct way to run a turbo setup.
1985 Crown Victoria 2-door 2003 Explorer XLT 81k miles, bone stock and staying that way... maybe 1990 Grand Marquis LS, In the junk yard, RIP!
#1688219 - 02/12/09 03:02 PM
[Re: JeffBoudah]
1_Man_Army
Loc: (260) Indiana, US
Yea, that what i meant, the waste gate. not the blow off valve. sorry for the confusion
2001 Ford CVPI w/ 2005 4.6L 2v,( The 141) 31k miles  ~Pioneer Stereo, ~3.27w/t~loc(x5),~Bridgestone Potenza's[4],~New set of 8 C.O.P's(DG508),~New headlights,~ Sharkless Plenum, ~1/2' Intake Plenum Spacer,~75mm TB & Comb spacer, ~Thrush 2.25' welded mufflers, ~Rear Cat Delete ~17' glasspacks ~15% tint all around. ~MM Maf (80mm),~BOC tune/tuner (93 octane), "TRUE" CAI ,Coming Soon: Rear shocks, 3.73 r & trak lok rebuild kit, SW Long Tubes (ADTR) Leadership is the art of getting someone else to do something you want done because he wants to do it.-Dwight Eisenhower
#1688247 - 02/12/09 03:35 PM
[Re: 1_Man_Army]
interceptor09
Loc: Just this side of Hell
Sweet car, saw the video on youtube a couple weeks ago.
#1688317 - 02/12/09 05:00 PM
[Re: interceptor09]
P71CVMAN
Loc: Beaver Dam, WI
FWIW: I ran my TA-49 turbo without a BOV for 4 years on my old GN without any problems. Almost all of the GN guys don't run a BOV(at least when I last owned my car). The sounds of the turbo "sneezing" back into the atmosphere through the MAF/cone filter would scare everyone.  This is definatly a cool project! Reminds me of the LS1/LS2 guys I see around here with rear mounted turbos.
#1688417 - 02/12/09 07:06 PM
[Re: JeffBoudah]
bjorkmae
Loc: Troutdale, OR
Also if you have a big enough turbo, venting the blow off valve into the intake tube before the turbo can cause tuning problems because it can actually blow air back out of the intake filter fooling the MAF and causing driveability problems. Been there done that. were you be running a BOV with a draw threw MAF? the compressed air being released to the atmosphere has been meetered already, no wonder you had tuning issues. BOV before a blow-threw MAF... is the correct way to run a turbo setup. No I am not that dumb, I have done too many boosted projects to screw up that badly If you read my posts you would understand what the problem was, but there are too many of them to expect that kind of home work. OK so originally I ran the by pass valve just like the vortech setup up was intended on the mustang. THe intake stream went this way: Cone filter, MAF, bypass valve return, breather tube, supercharger, charge pipe, by pass valve exit, idle control motor, then throttle body. The way I had it set up originally the MAF did measure all of the air going into the engine and the by pass return occurred between the MAF and the supercharger input. This is exactly how the vortech was intended on the mustang. Unfortunately what happens is that the extra air produced by the supercharger that is released when you let off the gas is let off through the by pass valve and if there is too much air it will actually blow dirt off of the cone filter. Of course in the process the air excess air blows past the MAF. This is enough of an issue that there is actually adjustments in the pro racer software specifically made to remedy that by using the failed maf table when this occurs. Now the way I have the intake system is in this order: cone filter, breather tube, supercharger, charger tube, by pass valve exit, MAF, idle control motor, throttle body. That way any extra compressed air gets vented to atmosphere and can't blow backwards across the MAF. Doing it this way avoids having to reference the failed maf table during blow off and this of course makes the programming much easier and makes the datalogging easier to interpret since there aren't crazy MAF readings when you let off the gas.
#1696537 - 02/23/09 10:37 AM
[Re: 9psicvpi]
STPchild
Loc: Boston, MA
Did he run that # on the stock injectors, or with 42's? I am confused.
Also tell your bud, great car. Comming from the mustang world, and now with the Vic. I already have the itch, and this is right up my alley. So tired of the normal, Vortech, Paxton, Kenne Bell, Whipple crowd.
Had alot of ecxperience building my mustang, so I dont think this would be such a big deal. LOW BUCK STYLE
Did pete build and tune the kit? I have a few questions before I start mine...
2001 White CVPI
JMOD, MAGNAFLOWS
GONE BUT NOT FORGOTEN 1999 GT Blown, Cammed, Cooled, 518rwhp 468rwtq
#1696548 - 02/23/09 10:47 AM
[Re: STPchild]
JeffBoudah
Loc: Holland,MI
Well you're in luck... cuz we have none of those around here. lol
#1696659 - 02/23/09 01:06 PM
[Re: Big_Bad_Joe]
Dan The Vic Man
I broke it
Loc: Coon Rapids MN
Hey Dan
Your car is pretty nice right now all NA and you have done a nice job on the overall package you have...
I would go with an S/C like Drock (or a radical procharger if you wanted to get stupid on us...)... Drock's set up would look very nice under the hood and scoot to boot...
I just think that would be a very nice DD with a ton of guts.... lots of low end...
Thanks bud! The hp bug got to me lol.
#1696719 - 02/23/09 02:09 PM
[Re: JeffBoudah]
bjorkmae
Loc: Troutdale, OR
Well you're in luck... cuz we have none of those around here. lol We don't?? Where have you been? Drock's car is a roots style like those mentioned above and mine is a vortech.
Moderator: JohnG, dRock96Marquis, Liquid
The Tire Decision Guide
