#1687255 - 02/11/09 04:12 PM
Re: Turbo Interceptor project
[Re: denmah]
denmah
Loc: allentown PA
let me explain, this is not my car, nor did i do the work on this car. my friend that owns a shop built the turbo kit for this car, for a customer. i love taking pics of his interesting projects and putting them on the internet for other people to see...
it has a 60mm turbo with a .82 exhaust (a little big, but its getting swapped out with a .68)
it has precision 42lb injectors and a marauder mafs, but that is topped out easily by the turbo. they are going to use a mafia extender to get more power out of the mass air meter.
it is totally stock motor throttle body to oilpan, 140k miles 2v.
the trans is the same way.
tuning is with SCT xcal.
they plan to put a pump in it also, and shoot for more power.
on 6psi it easily pegged the mafs and made 320rwhp the car made 206rwhp stock so it gained roughly 19hp per psi, pretty good for a turbo thats a bit too large.
more updates on it as they get more done, i will get some in car video also.
i dont know your rules on advertising so i will not post the name of the shop or try to dress this up like an advertisement, its not meant to be.
but if you are intrested in asking about it, i would say a PM is the best way, if thats ok with the site owners/admins.
thanks guys! enjoy!
#1687263 - 02/11/09 04:22 PM
[Re: denmah]
1_Man_Army
Loc: (260) Indiana, US
Amazing!! How much was the Total cost of this project?
2001 Ford CVPI w/ 2005 4.6L 2v, 31k miles  ~Pioneer Stereo, ~3.27w/t~loc(x5),~Bridgestone Potenza's[4],~New set of 8 C.O.P's(DG508),~New headlights,~ Sharkless Plenum, ~1/2' Intake Plenum Spacer,~75mm TB & Comb spacer, ~Thrush 2.25' welded mufflers, ~Rear Cat Delete ~17' glasspacks ~15% tint all around. ~MM Maf (80mm),~BOC tune/tuner (93 octane), "TRUE" CAI ,Coming Soon: Rear shocks, 3.73 r & trak lok rebuild kit, SW Long Tubes (ADTR) Leadership is the art of getting someone else to do something you want done because he wants to do it.-Dwight Eisenhower
#1687266 - 02/11/09 04:26 PM
[Re: 1_Man_Army]
denmah
Loc: allentown PA
im not sure yet, as they are still working out some things.
he wanted to try it out on the cheap initially and see how he liked it, at least thats what i perceived. but you need a decent mass air meter and injectors right away, and pretty much a pump at this point because the turbo actually makes alot more power than we had thought.
i can see when its done, they should be putting on the other exhaust housing and doing another tune later this week, i can update you guys and see if frank can give me a ballpark price for completed kit.
#1687269 - 02/11/09 04:29 PM
[Re: denmah]
denmah
Loc: allentown PA
oh yes, and there are all 4 cats (2 on each side) still intact
#1687358 - 02/11/09 06:06 PM
[Re: CodenameVIC]
04RauderDTR
Loc: NEPA/Central NJ
are there vids of this car on youtube or something... seems fimalar.
Edit: doh, thats the vid i saw...
BTW, NJ, nice
#1687366 - 02/11/09 06:15 PM
[Re: 04RauderDTR]
denmah
Loc: allentown PA
yes, new jersey owned
#1687375 - 02/11/09 06:30 PM
[Re: denmah]
1_Man_Army
I like how the Turbo is concealed in the one pic. I would only reroute the BOV back into the exhaust pipe.
#1687608 - 02/11/09 10:15 PM
[Re: 1_Man_Army]
panther service advisor
Loc: Ft. Lauderdale, FL
This is an excellent alternative, because a well tuned turbo system is this best power adder. Is this a STS Turbo kit or is it his own design? If he gets this kit dialed in, easily reproduced it and support it. It would be a nice addition to our options when it comes to force induction. I only see a couple of things that I would change and add to this set up.
1. Heat shield for the floor pan. 2. Install a shroud connecting the front bumper to the lower radiator support to direct more air into the intercooler and radiator. 3. Use steel braided lines on the oil supply lines for the turbo. 4. Have the blow off valve vent back into the exhaust. 5. Add an Accusump to guard against low oil pressure to protect the turbo.
But I must say, well down and please have your friend continue the good work. Please keep us posted.
03 CV Sport with Scan Gauge II, 21 mm rear sway bar, 02B02 fuel tank shield, awaiting tune from http://www.blueovalchips.com for my MM mas and 04 CVPI ziptube that is sitting in my garage. 96 CV LX with every option including memory seat and air suspension, except HPP. mods:98+ front brakes, 98-02 CVPI wheels, CVPI front springs, anti-sway bars, 02B02 fuel tank shield, CVPI TC and flywheel and CVPI PCM. (sold) 99 Dodge Dakota R/T 5.9 Club Cab 1 of 1100
#1687625 - 02/11/09 10:25 PM
[Re: panther service advisor]
1_Man_Army
PSA You are a very picky individual! Just kidding. I guess i would change those things as well, but the rerouting would be first. Blowing off into the atmosphere sounds like crap.
#1687657 - 02/11/09 10:47 PM
[Re: 1_Man_Army]
I have always been picky, I use to drive my technicians crazy. But, later on they all thanked me because we all shared in bonus checks when we didn't have come-backs. This turbo kit shows great promise, they just need to send me one for hot weather testing.
#1687676 - 02/11/09 11:00 PM
[Re: Dan The Vic Man]
1_Man_Army
You could y pipe the single back into a dual exhaust if you wanted. I would probably add some resonators as well.
Moderator: JohnG, dRock96Marquis, Liquid
The Tire Decision Guide
