#1688636 - 02/12/09 10:41 PM Oil Pressure
rbtlen Offline
Loc: virginia
I bought a 97 crown vic with "no oil pressure". I put in a new oil sending unit and I also grounded out the sending unit wire and the gauge went to half way so I replaced the oil pump (not fun). After I replaced the oil pump the gauge still shows no pressure. I pulled the sending unit and oil gushed out. When I had the front timing cover and valve covers off there was no scoring on the cam lobes. I will pick up a real oil pressure guage on Friday.
How far does the factory oil "pressure" gauge normaly go when grounded out? Any thing I should look for as the possible cause.
#1688645 - 02/12/09 10:49 PM Re: Oil Pressure [Re: rbtlen]
Timmn1 Offline
Loc: Near I-80 & I-57
As you may have discovered by now, the oil pressure gauge is little more than an idiot light with a pointer.
If you ground the wire going to the sending unit, the "oil pressure gauge" will go to it's midpoint.
1997 Grand Marquis - Started out life as a rental car in Milwaukee.
Mods:
Functional oil pressure gauge
Shark Plenum + Aviator throttle body
Headlight wiring
"Life after death is as improbable as sex after marriage!"
#1688819 - 02/13/09 07:33 AM Re: Oil Pressure [Re: Timmn1]
98P73_IRAQ Offline
yeah my 1992 cvlx change readings every month up and down so i bought a new motorcraft oil pressure sending unit (22$) but decided not to install it.
#1688873 - 02/13/09 09:42 AM Re: Oil Pressure [Re: 98P73_IRAQ]
IZ1111 Offline
Loc: Houston, TX
My oil gauge is 3/4 every time now. I had the no oil pressure problem too. I replaced the sending unit and then the oil pump, still no difference. Turned out that the oil pump pickup tube was 98% blocked with sludge. Once I fixed that. A nice 3/4 every time.
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1688880 - 02/13/09 09:51 AM Re: Oil Pressure [Re: IZ1111]
98P73_IRAQ Offline
5 months before one bad technician cleaned this pipe and filter, i found that the engine oil pan is so hard to remove.
#1689278 - 02/13/09 06:11 PM Re: Oil Pressure [Re: 98P73_IRAQ]
rbtlen Offline
Loc: virginia
Found something interesting when I pulled off the plastic shield underneath the car to change the oil and put the power steering pump back on. The factory oil cooler lines were removed and blocked off, could this possibly cause my problem. I am not sure that sludge in the pan is causing it since under the valve covers was very clean with no sludge of any kind.
#1690675 - 02/16/09 08:59 AM Re: Oil Pressure [Re: rbtlen]
JRD281 Offline
Loc: Ohioville, PA
I am having the oil pressure issue right now. I haven't tried much for diagnosis yet, but I would like a few opinions before I go tear into it tonite. Saturday morning, when I started the car up, the oil pressure guage was "dancing around." I guess since this is only a glorified light that it means it was getting pressure and then losing it. Or kept dropping below 6psi or whatever pressure the switch trips the guage. After about a minute of warmup, it was fine. The next morning, I started it up and had NO pressure. I got scared and shut it off. Re-started it and shut it off a few more times...nothing. I got a flashlight and shined it in the oil hole and could see oil slinging off the cam. When I walked back over to look at the guage it was back to normal. Same thing today...it took about 3 minutes of idling for the guage to come up to normal. I am slightly confused, because it only does this on cold startups, which almost sounds like mechanical problems...but the engine is not noisy when the guage shows that it has no pressure, and I can see oil moving around. I can't imagine the pickup tube being sludged up on a 9 year-old police car because the departments usually keep up on maintenance. It just seems too consistant to be a bad sender. I am going to put a pressure guage on it tonite and see what it has. I am hoping I haven't been driving around on like 7psi or something.
2000 P71
135,000 miles
20MPG City/26MPG Highway
3.55 Trac Lok, K&N FIPK, '99 PCM & MAF, Champion 7963 plugs, GMS upper plenum & 1/2" spacer, Gatorback belt, Pioneer head unit & speakers, center console, rear bumper tuck, AeroForce Scangauge, Wagner Xenon Headlight bulbs, Steeda Underdrives, GPS, WeatherTech visors, All synthetic fluids...
AND a 1999 Wedgewood Blue P71
124,000 miles
Completely Stock
"Wife's Car"
#1690680 - 02/16/09 09:06 AM Re: Oil Pressure [Re: JRD281]
98VicP71 Offline
13.97@99MPH
Loc: ATL
sounds to me like the sending unit is going bad.
#1690956 - 02/16/09 02:44 PM Re: Oil Pressure [Re: rbtlen]
LTDteether Offline
Absolutely causing trouble! Stop running this engine now. I hope it is not too late.
Please see under "notes" way down on this page:
http://www.p71interceptor.com/oilcooler/index.html
'99 GM GS HPP.
#1691165 - 02/16/09 07:49 PM Re: Oil Pressure [Re: LTDteether]
JRD281 Offline
Loc: Ohioville, PA
I just hooked the mechanical oil pressure guage to my car and was relieved to see that it had pressure. 75psi on a cold start, then it tapered down to 60 when the car warmed up. I'd say that's pretty good for 112k miles. I am pretty confident the $7 oil pressure switch fixed it, but I won't know till morning if the problem has gone away because it has to sit all night to duplicate what it was doing the past few days. Just curious of what you guys have gotten for oil pressure readings...please contribute.
2000 P71
135,000 miles
124,000 miles
Completely Stock
"Wife's Car"
#1691243 - 02/16/09 09:47 PM Re: Oil Pressure [Re: LTDteether]
rbtlen Offline
Loc: virginia
Don't worry when I bought the car I picked it up on a car trailer and I did replace the oil filter adapter today and now I have pressure. Wish I would have seen the oil cooler blocked off earlier it would have saved me a lot of time and a few bucks. Luckly the guy I bought the car from bought the oil pump and gave it to me. Atleast now it has a new pump and new valve cover gaskets as well as the front timing cover gasket.
Edited by rbtlen (02/16/09 09:53 PM)
#1691433 - 02/17/09 04:14 AM Re: Oil Pressure [Re: rbtlen]
mustang_zulu Offline
I am not
Loc: Garland, TX
hey at least you have a oil pressure guage.... LOL, i don't have one and i don't like it :P a CVHPP and no oil pressure guage??? FAIL :P maybe its time to add another guage pod??? \:\)
4 registered (2007CrownVic, doozii13, Moby_Vic, 1 invisible), 107 Guests and 92 Spiders online.
a_d_a_m 229
BigMerc96 144
Ezbok58a 104
dpk 100
EZlivin11 97
RF_Overlord 96
Chaplian 92
Ponyguy 88
JeffBoudah 87
SocalSam 80
