#1691427 - 02/17/09 03:06 AM rear axle ratio
98P73_IRAQ Offline
hello everybody.
i dont know what is the ratio for my 92cvlx axle.i knew there are 2.73 or 3.55 etc.?what is that mean and which one is mine?
2007 toyota yaris 1.3L wife vehicle
#1691548 - 02/17/09 10:25 AM Re: rear axle ratio [Re: 98P73_IRAQ]
larryo340 Offline
Loc: Long Island
Probably a 3.08
MOD List for MGM
...Marquis sold frown
#1691581 - 02/17/09 11:43 AM Re: rear axle ratio [Re: larryo340]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Look for this
Right there... Upper right corner
Yeah yeah..It's not exactly ours
The Jmod video is done! LINK!
#1691611 - 02/17/09 12:24 PM Re: rear axle ratio [Re: Rizzo]
98P73_IRAQ Offline
thanks.i removed the cover today because it was leaking some oil. and i placed new oil (sae90).but i think i failed after i found some leaks ,,,again.
#1692138 - 02/17/09 11:50 PM Re: rear axle ratio [Re: 98P73_IRAQ]
Kinger87 Offline
Loc: Gladstone MI
i would almost guarantee 3.08 gears, that was standard on the early cars.
2003 Grand marquis all stock
#1692252 - 02/18/09 07:41 AM Re: rear axle ratio [Re: Kinger87]
98P73_IRAQ Offline
what is the difference between them?(2.37,3.05,3.55) etc.and what this code means?.
thanks,,again
#1692930 - 02/19/09 04:14 AM Re: rear axle ratio [Re: 98P73_IRAQ]
Ciffer Offline
Loc: Southeast MN
the number expresses the rear axle ratio.
2.73:1 (2.73 revolutions of the driveshaft to 1 revolution of the axles)
3.08:1 (3.08 revolutions of the driveshaft to 1 revolution of the axles)
3.27:1 (3.27 revolutions of the driveshaft to 1 revolution of the axles)
etc.
the 2.73 gears were used on later base panthers that were equipped with 4r70w transmission. 3.08 gears were used on the early aero (and box?) panthers that were equipped with AOD/AODE transmissions.
i believe the AOD/AODE transmissions used a higher overdrive gear. 0.67:1 compared to 0.70:1 on the 4r70w if i remember correctly. which means that 2.73 in a later panther will behave similar to an earlier panther equipped with 3.08 gears.
the 3.27 and 3.55 gears were used on police and taxi models as well as HPP and towing package panthers. lincoln town car used the same range of ratios (2.73-3.55 i believe), but i do not know what ratio was used on what packages.
2.73 and 3.08 gears are considered better for highway use because they result in a lower engine speed for a given vehicle speed, which results in somewhat better highway mileage. some people experience slightly lower city mileage.
3.27 and 3.55 gears are considered better for city use, towing, acceleration and 'spirited' driving. they produce higher engine speeds at a given vehicle speed, generally produce poorer highway mileage. some people experience slightly better city mileage with these ratios.
Edited by Ciffer (02/19/09 04:16 AM)
-Carl
1997 Crown Victoria p71. 140,000 miles.
MZT, T-45, ENS bushings, magnaflow cat pipes, Truetrac, 02 brakes, 99 TC rims, 97 TC seats, Mark VIII fan.
#1693119 - 02/19/09 12:03 PM Re: rear axle ratio [Re: Ciffer]
99musclemerc Offline
Loc: Kansas City
So out of curiosity, I've got a 99 MGM all stock, was looking at 3.55 and 3.27 gears but I don't know which would be best? and what about the speedometer, will it need adjustment? If so how is that done?
99 Mercury Grand Marquis: Dual exhaust with Thrush welded mufflers, P&P plenum, 70mm throttle body, bottomless filter mod, 20% tint, vic front and rear with badgeless honeycomb grill, putco relay harness with Nokya 80/100W bulbs, bumper tuck, BOSS 335 wheels
#1693164 - 02/19/09 12:59 PM Re: rear axle ratio [Re: 99musclemerc]
98VicP71 Offline
13.97@99MPH
Loc: ATL
well what are you looking for? do you do more highway or more city driving.
3:27's are probably the best all around gear. 3:55's are starting to push it with the highway mileage (if that is a concern) if you want all out acceleration then go 3:73 and make sure you have a trac-loc.
as for the speedo yes you will need to get a new speedo gear that goes in the side of the trans. These can be purchased through the board sponsored vendors or a dealership. If you do a search you can find out what color speedo gear you will need depending on what gear ration you want.
#1693193 - 02/19/09 01:27 PM Re: rear axle ratio [Re: 98VicP71]
Loc: Kansas City
basically all around I'm looking to be quicker, kind of looking for the performance of a mustang GT but I do both City and highway driving. if I do the gear will the stock motor handle it fine? or do I need to beef other things up before I do the gear? Also if I find an interceptor at the junk yard I could pull off the 3.55 and the speedo gear all in one shot and it would work with my stock setup right? I've got single exhaust but cold air from afe on there plus about to throw an airaid throttle body spacer
#1693243 - 02/19/09 02:36 PM Re: rear axle ratio [Re: Ciffer]
98P73_IRAQ Offline
thanks alot Ciffer.
final question:i need an information about the transmition of my car too,in the same detail you gave it about axel.
thanks again.
#1693342 - 02/19/09 04:30 PM Re: rear axle ratio [Re: 98P73_IRAQ]
Ciffer Offline
Loc: Southeast MN
 Originally Posted By: vic1992LX
thanks alot Ciffer.
thanks again.
your signature shows AOD transmission, so you have the 0.67:1 overdrive gear. details about the transmission are not as important because there isn't really anything you can change with the ratios.
the AOD (automatic overdrive) was used in pre-92 panthers and for the first part of the 92 model year. AOD-E was used in the later part of 92 and through the 94 model year.
because you have the AOD transmission, you almost certainly have 3.08:1 gears.
-Carl
#1693438 - 02/19/09 06:07 PM Re: rear axle ratio [Re: Ciffer]
98P73_IRAQ Offline
well,i got more useful info about my car ,my signature will be updated too.thanks
#1696024 - 02/22/09 07:55 PM Re: rear axle ratio [Re: Rizzo]
Loc: Kansas City
THanks rizzo without this tag info I wouldn't have known what I was looking for at the yard today! (Even though I only found 3.27 and 3.73 gears can't find any 3,55's but plenty of 3.73's with trac lock!) Since I didn't have any luck at the yard on gears cause I don't want to tune and everything for the 3.73 that's why I'm going for the 3.55 so I can still run basically a stock setup; I did grab a police drive shaft for 25 and a full exhaust with mufflers for 28 bucks Now if only someone would wreck something with that 3.55 gear ratio I'll almost be set!
1 registered (bigltc), 26 Guests and 85 Spiders online.
NM117 333
Moby_Vic 129
EZlivin11 127
RF_Overlord 125
BigMerc96 120
Chaplian 115
Ezbok58a 99
mdnos 98
a_d_a_m 97
09P71VIC 91
