#1704214 - 03/03/09 07:05 PM Engine/Tranny pull question?
woug Offline
Loc: MN
Is it possible to pull the motor and tranny out the top of our cars?
Or do you drop the tranny and pull the motor seperate..?
Got PI heads and have to put in my new tranny, just thought I'd ask if that would be easier, pull it out at once. I DO know you don't have to pull the motor to swap the heads.
1999 Crown Victoria Police Interceptor
#1704363 - 03/03/09 08:55 PM Re: Engine/Tranny pull question? [Re: woug]
93_Marquis Offline
Loc: Norwood, OH, USA
Yep:
Saves time and you don't have to re-align the engine and transmission. I've even heard you can do it without taking the hood off.
Ray
Car: 2004 Mercury Marauder
Engine/Tranny: 49k and bone stock...for now wink
#1704852 - 03/04/09 11:10 AM Re: Engine/Tranny pull question? [Re: 93_Marquis]
woug Offline
Loc: MN
Sweet!
But you still have to remove the crossmember, correct?
#1705098 - 03/04/09 02:30 PM Re: Engine/Tranny pull question? [Re: woug]
93_Marquis Offline
Yes, you will have to remove the transmission cross member.
#1705603 - 03/04/09 11:10 PM Re: Engine/Tranny pull question? [Re: 93_Marquis]
Ruski Offline
Loc: California
Not to mention you will need to remove the fan, and the radiator. Do remove the radiator, it will give you more room to pull the engine, and doing so will save your radiator from being crushed.
I did it the other way, I just secured the tranny, and pulled the engine, even then I still needed more room, so I had to remove the radiator and the fan, it wasn't hard. Putting the engine back was hell, It was very difficult to connect the engine back to the tranny.
Edited by RussianBadBoyLB (03/04/09 11:13 PM)
#1706199 - 03/05/09 08:14 PM Re: Engine/Tranny pull question? [Re: Ruski]
Kinger87 Offline
Loc: Gladstone MI
it also helps to jack the back of the car up when doin it that way, if you cant get enough clearance.
2003 Grand marquis all stock
5 registered (mrti, Gee_Oh_Dee, MIAMI-DADE, Sakoulas, 1 invisible), 45 Guests and 116 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
