#1716170 - 03/16/09 03:25 PM Installing outside-of-tank fuel pump?
pakrat Offline
Loc: Kansas City, MO
86 Crown Vic 302 EFI. Fuel pump apparently getting weak. Low pressure at injector rail test port. Car won't start now.
Rather than spend $200 for a new in-tank OEM fuel pump, plus shop charges for installing it, plus tow bill to shop, I'm considering installing an aftermarket in-line high pressure electric fuel pump designed for fuel injected engines.
Questons:
1) The aftermarket pump is rated at 80 psi. I believe injector rail pressure is supposed to be about 45 psi. Does this car already have a downstream fuel pressure regulator that would dump anything over 45 psi back to the fuel tank?
2) Any other issues I might run into installing an aftermarket in-line fuel pump?
Thanks in advance for any info you can provide.
#1716177 - 03/16/09 03:34 PM Re: Installing outside-of-tank fuel pump? [Re: pakrat]
JeffBoudah Offline
Loc: Holland,MI
1) you have a fuel pressure regulator, look behind your TB on the fuel rail. It is not adjustable, and i think the factory setting is like 39.5psi w/o vacuum applied.
2) without the intank pump running, it is now an obstruction. So it would need to be removed. In doing so, you perform 85% of the work required to replace it. I only paid $99 for a new 255lph intank a while back... a fox body fuel pump is the same pump is the same design, so look around they are everywhere.
1979 LTD 2-Door, 64k miles - Restomod W.I.P.
1979 LTD Wagon, 120k miles - Ratrod W.I.P.
2005 Honda CR-V, 92k miles AWD 5-speed - Daily Driver
2003 Exploder XLT, Lawn Art - $600 obo CVN Special
#1716195 - 03/16/09 03:49 PM Re: Installing outside-of-tank fuel pump? [Re: JeffBoudah]
pakrat Offline
"Fox body"? Is that a brand name? Model or stock number?
#1716196 - 03/16/09 03:52 PM Re: Installing outside-of-tank fuel pump? [Re: pakrat]
JeffBoudah Offline
Loc: Holland,MI
Sorry, fox body mustang.
any 86-93 mustang fuel pump will work...
#1716200 - 03/16/09 03:57 PM Re: Installing outside-of-tank fuel pump? [Re: JeffBoudah]
pakrat Offline
Hmmmm.... sounds like a trip to U-pull-it parts yard! \:\)
#1716368 - 03/16/09 07:33 PM Re: Installing outside-of-tank fuel pump? [Re: pakrat]
pakrat Offline
Ok, change of plans. New plan is to leave the existing pump in the fuel tank. It runs and pumps, but won't build up sufficent pressure on the injector rail. So I'm planning to take the easy way out and add an in-line pump to boost the pressure on up to whatever that engine needs. I'm looking at Bosch, Walbro, and Vortech in-line pumps. Probably any one of them would work.
I can't go to the parts yard, as my car isn't running. I can't drop the tank as I live in an apartment. I'll just order an inline pump, wait for it to get here, put it on, and wire it in parallel with the existing in-tank fuel pump, that way it runs when the in-tank pump runs.
This is a temporary fix until I can get another car. This 86 has 290k miles, I've gotten my money's worth out of it several times over, and it's probably going to the salvage yard soon as I can get another vehicle. Naturally I'll pull the new inline pump off.
Moderator:  88grandmarq, MAFpilot
11 registered (Kickingwing519, charlieD, Clark, Hobo321, CrownBen, a_d_a_m), 110 Guests and 78 Spiders online.
NM117 334
Moby_Vic 146
EZlivin11 120
BigMerc96 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
