#1718583 - 03/18/09 11:42 PM Shift Stick Wobble
p71slag Offline
Loc: Winnipeg, MB
It really hasn't ever bugged me to much, because it doesn't affect anything mechanically, shift from P>1 and so forth no problems at all. So my problem is, the shift stick lever whatever you want to call it, is quite loose, wobbley, I can switch without hesitation, and when i am in gear, say Drive, I can move the stick around quite a bit, very easily, its quite loose.
Thank you all for any replies....I dont post to much, but I have been more and well im trying to say when im not out driving, at school, fsu, with girl friend, f'ing with my car, etc...i am on cvn,...really computer gets used for music, porn, and panthers. hope that was appropriate \:\) apologies if not. thanks to everyone...ive done a lot to my car...I will have to post some more pictures soon. I love all the little things one can do with these cars to make them look better, like all the stuff to clean up in the interior after the police equipment, b pillar covers, rear shelf, dash, yaaa know.
Thank you,
Kevin
Edited by p71slag (03/18/09 11:44 PM)
Edit Reason: add text
2003 CVPI, 5.whour work in progress
1972 Mercury Cougar, 351 Cleveland, Convertible, stock
2013 Ford Edge Limited, stuff done to it
2007 Ford Focus, stuff done to it
2003 Ford Explorer Sport Trac, stuff done to it
#1718595 - 03/18/09 11:55 PM Re: Shift Stick Wobble [Re: p71slag]
RedThunder94 Offline
Loc: South Central Tx.
mine's really loose too, i drove my aunt's 2000 p71 and the shifter was really crisp and positive on the detents. hopefully somebody will chime in. it will prolly bug the crap outta me now.
2004 Mercury Grand Marquis GS
07 P71 dual exhaust h pipe cat back with 24" glass packs and chrome tips, 35% front 5% rear tint, 16x7 Konig Swurve's with Riken Raptor ZR 245-50-16's, Blacked out rear fascia and Niteshaded tails, blacked out grill, modded headlights. Pioneer DEH-P6000UB HU, Infinity 2 way 6x8's, Oz Audio 5x7 2 ways, Fultron Tweets, Hifonics Zeus ZX6400 4 channel amp, Infinity 1211a 1200 watt rms class d, and 1 12" Alpine Type R 12 in a slot ported enclosure laugh
#1718611 - 03/19/09 12:16 AM Re: Shift Stick Wobble [Re: RedThunder94]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Check the BOK for an article on "Shift boot R&R"
You will see directions and pictures to help you find 2 torx screws on either side of the shift tube.
Those are loose.
The Jmod video is done! LINK!
#1718633 - 03/19/09 12:34 AM Re: Shift Stick Wobble [Re: Rizzo]
thank you sir, i found it,
#1718649 - 03/19/09 12:48 AM Re: Shift Stick Wobble [Re: RedThunder94]
p71slag Offline
Loc: Winnipeg, MB
ditto
#1719181 - 03/19/09 03:02 PM Re: Shift Stick Wobble [Re: p71slag]
p71slag Offline
Loc: Winnipeg, MB
Those two screws werent loose, i was able to tighten them a bit, nor were any other screws in the area. the shifter itself is loose in the housing...im going to take that apart now to see...any ideas?
thnaks
#1719190 - 03/19/09 03:07 PM Re: Shift Stick Wobble [Re: p71slag]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
those two screws get loose alot so just rip it apart and give um some turns and carry on.
Maybe a dab of locktite to finish it up
2002 CV P73
#1719228 - 03/19/09 03:50 PM Re: Shift Stick Wobble [Re: coldfusion11]
p71slag Offline
Loc: Winnipeg, MB
I have it ripped apart right now, and those screws are not loose. the shifter wobblles in its housing, and the rest of the shifting mechanism there wobbles. under the bridge that those two screws down it moves a lot, and it looks like perhaps there are shredded remnants of some kind sleeve thats supposed to be there(where it goes under the bridge? and isnt one mine?
thank you
Kevin
#1719253 - 03/19/09 04:31 PM Re: Shift Stick Wobble [Re: p71slag]
larryo340 Offline
Loc: Long Island
thank you
Kevin
You probably need new shifter tube bushings, they're cheap and not hard to put in.
MOD List for MGM
...Marquis sold frown
#1719361 - 03/19/09 06:37 PM Re: Shift Stick Wobble [Re: larryo340]
p71slag Offline
Loc: Winnipeg, MB
that sounds, looks, right yes, thank you. but what is also concerning me is that the stick its self, the one piece, is wobbling also in its little housing with the pin and clip.
KEvin
#1719760 - 03/20/09 01:30 AM Re: Shift Stick Wobble [Re: p71slag]
kyle91LTDcv Offline
Loc: Pen Argyl, PA
my '03 was loose like that from the factory (my mother bought it new, and i have since then bought it from her) her new '07 has no movement to it tho. maybe its just a normal thing.
**CURRENT PANTHER** 2003 CVLX HPP -Chestnut Metallic. 16" Y-Spoke alloys (winter) 17" LX Sport wheels (summer), factory dual exhaust, 3.27 rear end, leather interior, long overhead console, and RAS. All stock. Engine failed at 184K due to broken valve spring and replaced with an '05 town car engine. Currently around 240K miles / 90K on the engine.
**CURRENT NON-PANTHER** 2019 VW Tiguan 4motion 2.0 TSI: Currently at 14K
**PREVIOUS PANTHERS** 1991 LTD CVLX (RIP): Oxford White: Mileage unknown - Odometer stopped working at 48,685miles - Succumbed to frame rust | 2003 Grand Marquis GS Convenience (RIP): Spruce Green Metallic. 90K miles (SOLD 2013), later found on a salvage website. Apparently made very close acquaintance with a pole or tree.
#1719779 - 03/20/09 02:34 AM Re: Shift Stick Wobble [Re: kyle91LTDcv]
p71slag Offline
Loc: Winnipeg, MB
hmm thats interesting...but still perhaps there could be a way to stiffen it up.
#1719861 - 03/20/09 09:12 AM Re: Shift Stick Wobble [Re: p71slag]
larryo340 Offline
Loc: Long Island
KEvin
Mine is not what I would call "tight" either. The shifter works fine, but the handle is loose. It's not a problem.
MOD List for MGM
#1719872 - 03/20/09 09:40 AM Re: Shift Stick Wobble [Re: larryo340]
Not_Gramps_Marq Offline
Loc: Southeastern, Wi
iirc where the pin connects the shifter handle to the column the pin has elongated the hole causing the shifter to to bounce around alot. I have noticed mine go from tight to loose over the past few years.
1999 Marquis LS. K&N Cone, 90mm Lightning MAF, 04 ZIP tube, Ported and polished upper plenum, Pro Prod polished intake manifold,
EGR delete, custom 2.5 inch exhaust with catless X-pipe and Magnaflow Muffs,. Stage 2 J-Mod, AMMX driveshaft, 3.73 gears with modified limited slip.
2005 GT rims with 1.5inch spacers and 255 series rubber
