Page 1 of 1 1
#1728988 - 03/30/09 12:10 PM 5 speed swap: What did you use for shifter boots?
Crownvicman289 Offline
Loc: Sowth Duhkota
My 5 speed swap has begun. The C6 hangs by 2 bolts and is sitting on an unsecured tailshaft mount at the moment. What has been used for shift boots in the past? I'll be needing both, the one that seals the shifter to the trans and the one that seals the shifter to the trans tunnel.
'92 P74 w/289/T5 carb'd with bolt ons. '02 CVPI cut front springs/swaybar/brake swap.
3.73's, Trac-lock, GT40P heads awaiting install.
#1729416 - 03/30/09 08:14 PM Re: 5 speed swap: What did you use for shifter boots? [Re: Crownvicman289]
88grandmarq Moderator Offline
HO conversion Guru
Loc: Georgia
Steve did the swap on his 91 box, not sure what he used or if even got that far.
His pictures are still up on supermotors
http://www.supermotors.net/registry/1641
Also his write up on the entire event is in the archive.
#1729551 - 03/30/09 10:21 PM Re: 5 speed swap: What did you use for shifter boots? [Re: 88grandmarq]
Justin McCarter Offline
Loc: Fredericksburg VA
i used the lower plate from a mustang, bent it up a little
and the boot i got from a ranger without cup holders
it scrunches down nicely
this old, old video is the only thing that shows it
http://videos.streetfire.net/video/interior-seat-mod_145408.htm
92 murk ranchero gone to scrap
daily driver 2002 Ford Ranger no plans for modd.
1990 Crown vic GT A9L MAF computer conversion 347 stroker, F303 cam, T5 5speed trans. big brakes , disk rear._-
http://www.cardomain.com/id/mccarterjg
#1729553 - 03/30/09 10:23 PM Re: 5 speed swap: What did you use for shifter boots? [Re: Justin McCarter]
you may just as well use the cover from the ranger too
#1729648 - 03/30/09 11:26 PM Re: 5 speed swap: What did you use for shifter boots? [Re: Justin McCarter]
Loc: Sowth Duhkota
Groovy. Does it matter what kind of Ranger trans? And is the Ranger boot taller than the Stang boot or something?
#1730338 - 03/31/09 07:08 PM Re: 5 speed swap: What did you use for shifter boots? [Re: Crownvicman289]
i used the mustang sifter with the hurst handle,
just anny ranger boot, find one without the cup holders, and yep the ranger boot is too tall but it does scrunch down
Page 1 of 1 1
Moderator:  88grandmarq, Stu
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
6 registered (P71BB, dalame, CV_p71_W, DavidVT, Dan04Merc, 1 invisible) and 18 anonymous users online.
Amazon!
February
Su M Tu W Th F Sa
1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28
