#1252712 - 08/10/07 09:59 PM p71 steel wheels
tikdcrown Offline
Loc: minnesota
will a crown vic 7 HOLE MODEL 2003+ steel wheel rim fit on a 1999 crown vic that has the 16 hole rims, and if not are there any modifications that can be done?
#1252713 - 08/10/07 10:00 PM Re: p71 steel wheels [Re: tikdcrown]
money_makin_taxi Offline
Not allowed to buy or sell on CVN
Loc: fl
you will need wheel spacers
#1252761 - 08/10/07 11:35 PM Re: p71 steel wheels [Re: money_makin_taxi]
99crownvicp71 Offline
Loc: Long Island, NY
i was also wondering the same thing. will the chrome rings fit the same way on both of these wheels?
#1252802 - 08/11/07 12:17 AM Re: p71 steel wheels [Re: 99crownvicp71]
FunkRider Offline
Loc: Whitecourt, Alberta, Canada
Regular trim rings don't fit the 03-04 P71 wheels.
2008 GMC Sierra Crew Cab 2500HD 6.0 SLT Z71
1970 Chrysler Newport Cordoba 2dr hardtop 383-727-8.75
1970 Chrysler Newport Base 4dr Sedan 383-727-8.75
#1252803 - 08/11/07 12:19 AM Re: p71 steel wheels [Re: 99crownvicp71]
Quasar Offline
Loc: Milwaukee, WI
Yes, Wheel spacers are required to run 2003+ wheels on anything older than a 2003, they do make chrome trim rings for 2003+ wheels but they are not the same as the ones on your 1999. Leaving for work now but I will try to post a pic of 03+ chrome trim rings unless someone beats me too it.
2011 Lincoln MKS 41K miles
#1252819 - 08/11/07 12:31 AM Re: p71 steel wheels [Re: Quasar]
theredlineboss Offline
Loc: Taylor, MI
It'd be a lot cheaper to get a set of 17" Charger steelies. They look a lot like the newer 17" wheels on CV's, with an offset and bolt pattern which works pretty well on pre-'03's. You can even use the Ford collared lugnuts and install a set of the Ford "pancake" style center caps.
Yes, I do realize that you were asking about the 16" '03-06 (?) steelies. I just think the 17's look a lot better. \:\)
Rob
1996 Police Interceptor-Glory days are over frown - old specs below **216K miles**; Daily driver now a stock '97 Vic **157K miles**
Engine: '03 4.6 w/ underdrives, shorties, custom downpipes, MZT, 70MM T/B, ADTR ported plenum, & Dyno Tuned.
Trans: Y2K 4r70w w/ J-mod, Spiral Lock clip, '04 Marauder TC, and an Econoline trans cooler.
Suspension/steering/brakes: '02 PI steering box, 17" 'stang wheels, '95 ABS master cyl., ADDCO bars, and Big Brake Upgrade!
Misc: '98+ Heated mirrors, 2-tone Gray interior, 98+ gauges, oil cooler-delete, and LX Sport console w/ floor shift!
#1253369 - 08/11/07 10:31 PM Re: p71 steel wheels [Re: theredlineboss]
tikdcrown Offline
Loc: minnesota
what size wheel spacers and are there any advantages over the 16-18 hole crown vic steel wheels?
#1269929 - 09/04/07 12:21 AM Re: p71 steel wheels [Re: tikdcrown]
tikdcrown Offline
Loc: minnesota
can anyone tell me what size wheel spacers i will need to put 2006 p71 rims on my 1999 p71? they are both the 12 slit kind, not the 7.
thank you.
#1269943 - 09/04/07 12:41 AM Re: p71 steel wheels [Re: tikdcrown]
Da Governator
thank you.
1.25" all around
take a look at the faq
RIP 2vmodular
#1270130 - 09/04/07 08:57 AM Re: p71 steel wheels [Re: FunkRider]
Cooper Offline
Loc: Massachusetts
 Originally Posted By: FunkRider
"Regular trim rings don't fit the 03-04 P71 wheels."
I beg to differ... I've used these on the snow tire steelies on my '02 as well as my '04. The clips just slip over the outside edge of the wheel so they work fine for both.
#1728890 - 03/30/09 10:05 AM Re: p71 steel wheels [Re: Cooper]
W4LTD Offline
Protect the Panther
Loc: Brevard County, Florida
This may be a stupid question, but...
I currently have the stock 16x7 steelies on my 2007 CV P74 (civilian) and would like to upgrade to the 17x7 OEM steelies.
Is this a direct swap with no modifications?
What is the correct tire size for the 17" wheels on a CVPI?
Edited by W4LTD (03/30/09 10:07 AM)
.selur eht daeR .devomer giS
#1728964 - 03/30/09 11:51 AM Re: p71 steel wheels [Re: W4LTD]
Ask_The_Shack Offline
You know this thread is 2 years old, right?
P73/4 steal rims are the same as P71.
The Blue Falcon
Car pics located here
Fog light pics located here
Find out how to paint your grille here
#1728973 - 03/30/09 12:00 PM Re: p71 steel wheels [Re: Ask_The_Shack]
adamaul Offline
Loc: Pennsylvania
hey whacker are you sure you don't have 17's on your car already?
#1729109 - 03/30/09 02:20 PM Re: p71 steel wheels [Re: adamaul]
W4LTD Offline
Protect the Panther
Nope, 16's.
#1729230 - 03/30/09 05:01 PM Re: p71 steel wheels [Re: W4LTD]
sanco Offline
fo shizzle
Loc: chicago, illinois
17s will bolt right on to the 03+ vics
you can also use charger 17" steel wheels that look exactly like the ford ones except have a bigger offset. i use them on my car and i like the way it lines up with the fender.
Moderator:  a_d_a_m
7 registered (dpk, garndreadz, LSE_Dave, JulianL85, 2 invisible), 68 Guests and 11 Spiders online.
a_d_a_m 193
Ezbok58a 156
charlieD 153
BigMerc96 138
dpk 120
Ponyguy 119
White99MGM 101
SocalSam 81
reminc70 74
Moby_Vic 74
