#1729087 - 03/30/09 01:55 PM 1991 Ford LTD CrownVictoria 351(5.8) carburetor
Willys Offline
Loc: Los Angeles, CA
need help to find good description and images of 7200/2700 VV model carb adjustments and home diagnosis and repair. i've downloaded few pdfs, but looking for total clarity
2000 Ford Crown Victoria P73
#1729100 - 03/30/09 02:09 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
larryo340 Offline
Loc: Long Island
Hi, and Welcome !!!
Those carbs are very tricky to set up, but if I were you I would buy THIS inorder to do the job right.
MOD List for MGM
...Marquis sold frown
#1729806 - 03/31/09 07:30 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: larryo340]
Willys Offline
Does anyone know smth about edelbrock (not sure in correct name and model type). my friend when had grandmarquis90 replaced my type of carb with this one. he says it's much better in performance, adjustment and maintenance. please advise
#1730097 - 03/31/09 02:31 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
Mperson Offline
Loc: US
I've tried both Edelbrock and Holley carburetors on my 5.8.
Purchasing a reman 7200VV and returning to a 2-bbl intake was the best investment I have ever made in terms of drivability and fuel economy with the '91. My advice is to stay stock, and pay the money for a professionally remanufactured variable venturi.
#1730289 - 03/31/09 06:12 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Mperson]
Cougrrcj Offline
All Panther, all the time!!!
Loc: N.E. Ohio
Stu,
The one I sent you didn't work??? It was fine on my car when I removed it.
#1730834 - 04/01/09 05:00 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Cougrrcj]
Willys Offline
i already bought almost new 7200VV carb for 80 usd. it looks good and engine sounds but more than week can't find electrician to set it up. so like i was told these carbs are hard to adjust due to the emissions demand.
at present time trying to handle on myself. it all gets great, but still can't make up my mind about how to correctly set idle.
#1730835 - 04/01/09 05:04 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
Willys Offline
moreover i found not bad short description and adjustment tips on this type of carbs. if anyone interested, i can lay it out or post. it's quite clear but needs self discoveries to fit the adjustment to a certain vehicle. maybe it's all coz of absence of the emissions ctrl label under hood- i never had it there. so that's why i have to do custom settings.
maybe anyone knows if it's possible to restore the label eg with the help of vin or some other details. please advise.
#1731105 - 04/01/09 11:19 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Mperson]
Philboski Offline
Where can these be found? I have thought about this a few times.
#1731240 - 04/01/09 01:17 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Philboski]
Willys Offline
what you mean? can't find reman carbs? i mentioned that i bought almost new (taken from other vehicle while disassembly), a lot could be found longterm used but also remanufactured. owner was about to let em for average 30 usd each.
#1731427 - 04/01/09 04:11 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
Philboski Offline
I am talking about a carb where one would either take it in to get it professionally rebuilt, or buy one already rebuilt, returning the old one as a core.
Where did you get yours?
#1731933 - 04/02/09 12:40 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Philboski]
Willys Offline
my friend bought my carb in Saint Thomas, where ford cars are produced. He said everywhere around it's not a problem to find a carb that matches 5.8 engine.actually my old carb is still with me.
#1732127 - 04/02/09 09:43 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
Philboski Offline
Yes, but is the carb rebuilt professionally? Or just used? I already have a used one sitting on my engine.
#1732418 - 04/02/09 02:18 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Philboski]
Willys Offline
the carb actually on my engine seems to be new (anyway I was told so and still don't have reasons to doubt). Is that on your engine performs bad? Yesterday I undertook to adjust it on myself and today quite satisfied. Moreover,I replaced old vacuum hoses and simplified the routing. So I got 550rpm in drive, stable idling even with old sparkplugs and perfect acceleration even during uphill.
Maybe you should try to use maintenance kit to replace old rubbers and springs etc? If you understand mechanics well, this should do the job.
#1736192 - 04/06/09 03:30 PM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Willys]
Philboski Offline
It's hard to start, gives a really high idle, and some run-on after killing the engine. She blows super clean on emissions though. I have a non-ford VV repair manual, but no experience with carbs. This lack of experience makes a professional rebuild very appealing.
#1736821 - 04/07/09 01:21 AM Re: 1991 Ford LTD CrownVictoria 351(5.8) carburetor [Re: Philboski]
Willys Offline
when i first started my engine with that new carb, the idling was very high and erratic too. on my tach it showed 1700 rotation per min, and the car was really noisy. Today the car drives well.
If you still wish to try to adjust your carb yourself, start first with the vacuum routing, check if anything's right, ain't there a vacuum leakage(what also procudes high idling and unstable performance). if interested, i can send you diagrams of vacuum (both by manual and designed by myself)
6 registered (MinnesotaP71, Hambone, RyderPhan, WalterL, akr619, cv83), 106 Guests and 13 Spiders online.
