#1769987 - 05/18/09 11:47 PM
Whining sound in radio on accelerate with new XM
Carter
Loc: Michigan
Hey All,
I am getting a whining sound out of my radio when I am accelerating when in sat mode with my new XM installation. I remember a long time ago this was a problem with older cars, but I didn't think it would do it here, any suggestions?
Edited by Carter (05/18/09 11:48 PM)
2003 Mercury Grand Marquis GS M74 47k - Current Mods- Marauder Cluster Swap w/ Autometer 9117 TA, Auto dimming Gentex Mirror, Overhead Console w/ Home link Compass, 6000K H.I.D. w/ Philips Ballasts, 06+ Audiophile CD6 Radio with XM Satillite Radio Direct Connect, Wood/Leather Steering Wheel with Redundant Controls Coming Soon - EATC, Leather Interior with Heat, Marauder Wheels.
#1770219 - 05/19/09 10:37 AM
Re: Whining sound in radio on accelerate with new XM
[Re: Carter]
capt512
Loc: KC, MO
Hmm...interested. I have this problem with a CB in my car.
  2001 CVPI - Ex-Kansas Turnpike Authority 2000 CVPI - Ex-Kansas Turnpike Authority
#1770226 - 05/19/09 10:43 AM
[Re: capt512]
ford00
Loc: New Jersey
do you have any amps and or aftermarket radio? It could a ground issue.
Edited by ford00 (05/19/09 10:43 AM)
SOLD-2000 Crown vic LX HPP-SOLD 2004 CVPI 67K miles
#1770446 - 05/19/09 03:40 PM
[Re: ford00]
trickvic
Loc: West Los Angeles
Definitely sounds like a grounding issue. Is the ground of the xm module connected to the same ground as the radio? are all the audio cables kept separate from any cables carrying power?
Depending on how its hooked into the head unit you can buy a ground loop isolator (noise filter) which should dampen the whine, but that should be second to checking all the wiring.
I had the same thing happen with a set of speakers i hooked up in the trunk, turns out i just needed to route some wires differently.
- 05 P73 - custom x-pipe no mufflers - custom 91 octane sct tune - 04 CVPI airbox/80mm MAF
- interceptor center caps, underglo, interior underglo, rear flashers, xenonworks 8000k HID's
- kenwood KVT-512 flip out dvd, 4 Kicker DS680 6x8's, 2 12" Power Akoustic 800W RMS each wired to 2 Ohms, lanzar vibe 1600W RMS 2400 PEAK 2 channel amp, 2 farad cap, 2 alpine type r 6 1/2" speakers in trunk for mid/high's while tailgaiting.
#1770844 - 05/20/09 12:52 AM
[Re: trickvic]
Carter
Loc: Michigan
It maybe the way I routed the antenna wire too. I will check it all out this weekend, and get back to all y'all. Its not bad when louder music is playing, but softer music, it gets annoying. As for the way it draws power, it gets its ground and power off the radio. Its a factory CD6 radio. My XM installation is posted here >> Factory Like XM Radio Installation
#1770858 - 05/20/09 01:25 AM
[Re: Carter]
trickvic
it might be the antenna. but isnt xm digital? I'm no expert and the antenna may be picking up stuff, but since its digital it would seem like your noise is coming from inbetween the module and the radio.
In my experience RCA cables tend to be the ones to pick up the most noise. Is everything wrapped and away from live wires?
#1771113 - 05/20/09 12:45 PM
[Re: Carter]
ford00
Loc: New Jersey
it could also be the connections on the rca out/in puts on the unit it self. I had this issue with my pioneer radio and i actually had to add a wire to the rca connection to ground.
#1771690 - 05/21/09 02:11 AM
[Re: ford00]
trickvic
yea i'm pretty sure thats what a ground loop isolator does, you can pick em up for 10-20 bucks at any car audio shop.
#1773720 - 05/24/09 02:35 AM
[Re: Carter]
JaxRhapsody
Loc: L-Ville,KY
Sounds like the problems cars have with the radio when they dont have non-interferrance sparkplug wires.
#1876259 - 10/05/09 04:45 PM
[Re: Carter]
Brock_Samson
Loc: Nor-Cal (Sac)
also avoid running speaker, antenna, etc cables along or near positive power wires. that will cause that also
2002 Interceptor (Black) Ex-Santa Clara Police Car 60k miles
Moderator: dRock96Marquis, 2vmodular, sanco
The Tire Decision Guide
