#1245733 - 08/01/07 04:35 PM Flashing O/D light above 50 MPH
NASCAR_Mike Offline
On my 96 Crown Vic P74, when I drive over 50 MPH the O/D off light starts to flash.
The trans runs fine, shifts fine and only has about 8k on the fluid.
When I shut the car off and restart it, the light turns off but reappears once you hit 50MPH or higher.
I used my Actron scanner and it shows no codes. The scanner at Autozone shows no codes either. I even checked the codes with the engine running, O/D light flashing and no codes were thrown.
I know the flashing O/D off light means something is wrong with the transmission, but I am stumped as to what it can be.
I changed the VSS (vehicle speed sensor)about three months ago but that gave me a steady O/D off light and the scanner showed it as VSS failure. I replaced it and cleared the code and it has been fine ever since.
The speedometer is working correctly.
Thanks all.
1996 Ford Crown Victoria LX P74 HPP Inventor of the 98+ brake upgrade
#1246246 - 08/02/07 11:54 AM Re: Flashing O/D light above 50 MPH [Re: NASCAR_Mike]
NASCAR_Mike Offline
Anyone?
#1779446 - 05/31/09 03:18 PM Re: Flashing O/D light above 50 MPH [Re: NASCAR_Mike]
aera6413 Offline
Loc: Broward County, South Florida
When you get your answer, please let me know. I have a 98 P71. Just started this morning under the same condtions as yours.
#1779622 - 05/31/09 07:26 PM Re: Flashing O/D light above 50 MPH [Re: aera6413]
01GRANDMARQUIS Offline
Loc: MASS
maybe its a miss fire with the coil or maybe just a sensor is it do anything like bucking when you get up to speed
410 HP To The Tire, Stage 3 Cushman Blower Cams, Built Transmission From MPE, 13.3 at 102MPH 2004 Ford Crown Victoria P71 152,000 miles, 18" Mustang Wheels, MPERACING Tune, Kooks Long Tube Headers, 2.5" Exhaust into SLP PowerFlows, Power Stop Drilled And Slotted Rotors W/ Ceramic Pads, Edge Racing 3200 Stall Convertor, Ford Racing 39Lb injectors, Vortech V1 Strim, Cobra Fan Swap, 95MM MAF, SCT Tuner,MSD Blaster Coils, NGK TR6 Plugs, Metco Upper and Lower Control Arms, Ford Racing 4.10s, Ford Racing Trac Loc, Lincoln Leather Seat Swap,New Carpet,Pioneer Double Din Touch Screen, Component Boston Acoustic Speakers, 2 Solo Barracks L7 12", Kicker 1500.1 amp, and a Kicker 640.4 amp,(Tsnami Hybrid Cap and Wires)
#1779783 - 05/31/09 10:29 PM Re: Flashing O/D light above 50 MPH [Re: 01GRANDMARQUIS]
ajohn Offline
Loc: Overland Park, KS
My brother-in-law just had his trans rebuilt and the OD light began to blink at start-up. Long story short, He now has a second new trans. He was told it means there is a problem with the trans. I would take it to a shop asap.
2003 CVPI 118k
2000 Honda Civic EX 137k purchased new, have done nothing to the car except regular maintenance and cold air intake.
2002 Honda Civic EX 106k Wifes DD
#1779814 - 05/31/09 10:51 PM Re: Flashing O/D light above 50 MPH [Re: ajohn]
Chief2000P71 Offline
Loc: Ohio
This is just a guess but maybe it's the trans. fluid temp. sensor? I could be wrong though.
#1779838 - 05/31/09 11:31 PM Re: Flashing O/D light above 50 MPH [Re: Chief2000P71]
CommandPresence Offline
Loc: Granite State
The transmission control switch is a momentary contact switch. When the switch is pressed, a signal is sent to the Powertrain Control Module (PCM) to allow automatic shifts from first through fourth gears or first through third gears only. The PCM energizes the Transmission Control Indicator Lamp (TCIL) when the switch is off. The TCIL indicates overdrive cancel mode activated (lamp ON) and EPC circuit shorted (lamp flashing) or monitored sensor failure.
2003 Ford Crown Victoria Police Interceptor.
#1779868 - 06/01/09 12:45 AM Re: Flashing O/D light above 50 MPH [Re: Chief2000P71]
aera6413 Offline
After searchin around the forums, i'm inclined to agree with you.
24 registered (aknox077, BlackVic_P71, bobby58, Birdman9234, BigMerc96, BIGtito), 69 Guests and 71 Spiders online.
KayTar 589
CNGInterceptor 397
sm41 339
Ezbok58a 271
BlackVic_P71 271
BigMerc96 268
Moby_Vic 264
Superhobo 245
Black_Sunshine 232
ajdereicup 222
